  3. nRF5 action!
nRF5 action!
  • Mars WarriorM Mars Warrior
    @alowhum, you seem to need Jlink Commander:
    @toyman said in nRF5 Bluetooth action!:
    @alowhum I intentionally asked you because I know the problem exists.
    You need to erase the chip via Jlink Commander. Neither nrfjprog nor anything alse will work (AFAIK)
    Actually, it was @NeverDie who found it in the beginning of his quest with nrf52. "The thing that started it all" (c)
    Furthermore, It would be nice to have a small step-by-step guide to unlock and then program the ebyte module.
    @Omemanti and @NeverDie are using these modules, so should be able to write something up that works for other ppl ;-)
    (My ebyte modules are still on their way)
    O
    O
    Omemanti
    wrote on last edited by Omemanti
    #1601
    @mars-warrior @alowhum
    For uploading code onto the Ebyte modules I use an ST-Link V2 (2 dollar USB modules).
    • Install the USB-Driver using Zadig
    • Connect the DIO, CLK VCC, and GND.
      For testing purposes, I soldered just the tips of some Dupont cables to the Ebyte module and put the female parts on the ST-link.
    • The first time I want to upload code, I first "burn the bootloader" (Tools => burn Bootloader) (https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/386)
      This will give an error.
      After that, you should be able to upload sketches.
    Nca78N 1 Reply Last reply
    • O Omemanti
      Nca78N
      Nca78N
      @omemanti said in nRF5 Bluetooth action!:
      That's what I suggested earlier but it seems it didn't work. But I don't remember if it was with an stlink.
      • O
        O
        Omemanti
        #1603
        @alowhum
        maybe a very stupid question, but did you check all the wires and after that if your computer uses the right drivers.
        I took me quite a while to figure this out myself. Especially the driver part messes things up. Errors everywhere that referred to different problems, but after I used Zadig they all disappeared.
          NeverDieN
          NeverDieN
          #1604
          @mars-warrior said in nRF5 Bluetooth action!:
          As I've said many times previoiusly, I use the nRF52 DK to program external modules, and it's what I recommend for noobs because it's relatively hassle free. If you're able to use the $2 st-link v2 programmer then great, my hat's off to you. If not, I recommend the nRF52 DK rather than get frustrated and give up.
          alowhumA 1 Reply Last reply
          • NeverDieN NeverDie
            alowhumA
            alowhumA
            alowhum
            @neverdie said in nRF5 Bluetooth action!:
            nRF52 DK
            Which hardware programmer do you use with that?
            I find many of these software packages, like Segger's JLink stuff, are made for Windows (I'm on a mac).
            gohanG O 2 Replies Last reply
            • alowhumA alowhum
              nRF52 DK
              @alowhum you can still install windows on it :sweat_smile:
              • alowhumA alowhum
                nRF52 DK
                O
                O
                Omemanti
                @alowhum by programmer you mean in something like the Arduino ide? That's what I use ( I both use the nrf52dk =>j-link aswell the st-link v2 => st-link)
                • alowhumA
                  alowhumA
                  alowhum
                  #1608
                  @Omemanti I didn't realise the nRF52-DK was a hardware device. I thought it was a software program.
                  On the picture you provided (thanks!), are pin 6 and 8 connected to a serial port to read what's going on? Your ground is connected in a different place than mine (I connect it next to the VCC pin). I suspect both those side-pins near the antenna, at the top, where you have soldered something, are ground too, right?
                  O 1 Reply Last reply
                  • alowhumA alowhum
                    O
                    O
                    Omemanti
                    @alowhum said in nRF5 Bluetooth action!:
                    The nrf52 dev kit= > NRF52 Dev kit
                    To connect the DK to a module :
                    DK Ebyte module
                    GND(detect) => GND
                    SWDIO => SWDIO
                    SWDCLK => SWCLK
                    VTG => 3,3V
                    3,3V => 3,3V
                    GND =>GND
                    select J-link and there you go.
                    I used Pin 6 and 8 to connect to a FTDI to read out the serial. Since you can tell the sketch where to put the RX and TX I just connected them to 6 & 8.
                    the Ebyte module has multiple GND connections, I messed the one next to the VCC up so I connected them next to the antenna. Just because I was easy ;)
                    Indeed!
                    • alowhumA
                      alowhumA
                      alowhum
                      JLinkExe gives me this:
                      WARNING: RESET (pin 15) high, but should be low. Please check target hardware.
                      I already had some signs these EByte modules have a reset issue. As it they are constantly being reset. This points to that again. hmm.
                      • alowhumA alowhum
                        O
                        O
                        Omemanti
                        #1611
                        @alowhum
                        Hey, sorry, I'm not familiar with your error messages.
                        Can you please sum everything up what you did so far and what your setup looks like (pic)
                        • Drivers
                        • Libraries
                        • what software you use
                        • Number of modules you tested
                        • etc
                        just to retrace your steps ( It might be useful to post it in a separate topic to keep this one cleaner ) => https://forum.mysensors.org/category/5/troubleshooting
                        • Nca78N
                          Nca78N
                          wrote on last edited by Nca78
                          #1612
                          For those interested, NRF52840 is already available on AliExpress from HolyIOT, it's the revision 1 of the chip, too bad they put a chip antenna :(
                          https://www.aliexpress.com/store/product/Nordic-nRF52840-Bluetooth-module-grid-development-board-BLE5-0-Bluetooth-serial-low-power-voice-long-distance/420533_32868365660.html
                          [Edit] They also have the most compact NRF24 compatible gateway ever, for 10$ :o
                          https://www.aliexpress.com/store/product/Nordic-nRF52832-BLE-4-0-4-2-5-0-USB-UART-BLE-dongle-for-computer/420533_32862480389.html
                          • NeverDieN
                            NeverDieN
                            #1613
                            Looks as though there is also a new DK for the nRF52840 as well:
                            https://www.digikey.com/product-detail/en/nordic-semiconductor-asa/NRF52840-DK/1490-1072-ND/8593726
                            just not in stock.
                            Looks like HolyIOT is ahead of the curve on this chip.
                            JokgiJ 1 Reply Last reply
                            • alowhumA
                              alowhumA
                              alowhum
                              @nca78 said in nRF5 Bluetooth action!:
                              Cool!
                              • alowhumA alowhum
                                Cool!
                                Nca78N
                                Nca78N
                                Cool!
                                If you buy one, buy the "black" version, it's a bit bigger but it's because it has a PCB antenna, range will be better.
                                T 1 Reply Last reply
                                • Nca78N Nca78
                                  Cool!
                                  Toyman
                                  @nca78 I don't recognize any LDO on the PCB while it has USB power supply. How is 5V converted to 3.3v?
                                  • T Toyman
                                    alowhumA
                                    alowhumA
                                    alowhum
                                    I was wondering the exact same thing!
                                    • scalzS
                                      scalzS
                                      small internal dcdc converter
                                      • alowhumA alowhum
                                        Nca78N
                                        Nca78N
                                        Look at bottom of page 6 and top left of "schematic" on page 9 of the CP2104 datasheet. It can supply up to 100mA.
                                        https://www.silabs.com/documents/public/data-sheets/cp2104.pdf
                                        • NeverDieN
                                          NeverDieN
                                          Can someone please provide a link to the module being discussed? I tried looking on Aliexpress, and I don't see anything which matches.
