  3. Problem with Humidity sensors
5 Posts 3 Posters 1.4k Views 3 Watching
  • G Offline
    G Offline
    Gus8
    Hi everyone,
    I am building a automation system in order to cultivate mashrooms in a closed environment and I want to keep the humidity around 75%.
    I used DHT22 temperature/humidity sensors but after a few days the measurements were about 99% RH and I suppose that the sensors broke down due to high humidity environment. What do you think about that?
    I am thinking of buying better sensors which can hold longer. I have found these:
    https://www.adafruit.com/product/1293
    Do you have any suggestions? How can avoid the damage of the sensors by high humidity enviromnents?
    mfalkviddM D 2 Replies Last reply
    • G Gus8
      Hi everyone,
      Welcome to the MySensors community @Gus8 !
      See the study linked in https://forum.mysensors.org/post/38344 if you haven't already. it has a lot of details on accuracy.
      • G Gus8
        Hi everyone,
        @Gus8 How are you powering the sensors and what is your schematic. Are you running these as battery operated nodes?
        • G Offline
          G Offline
          Gus8
          Thank you all for your responses.
          I use an Arduino Uno and it is power by a power supply of 9V/1.5A . The sensors are power through arduino's +5V output.
          D 1 Reply Last reply
          • G Gus8
            @Gus8 Do you either have a pull-up resistor in place, 4k7 to 10k, or possibly have the internal pull-up resistors enabled for the data line that you have it connected to?
