  3. Combine CASE and IF/ELIF
7 Posts 2 Posters 1.9k Views 3 Watching
    moskovskiy82
    Not a programmer so all the sensor through trial and error. Need to combien the codes from two nodes (RGB dimmer and Heatpump).
    The first one uses case
      if (message.isAck()) {
         return;
      Serial.print("Incoming message for: ");
      Serial.print(message.sensor);
      String recvData = message.data;
      recvData.trim();
      Serial.println(recvData);
      switch (message.type) {
        case V_HVAC_SPEED:
          Serial.println("V_HVAC_SPEED");
          if(recvData.equalsIgnoreCase("auto")) FAN_STATE = 0;
          else if(recvData.equalsIgnoreCase("min")) FAN_STATE = 1;
          else if(recvData.equalsIgnoreCase("normal")) FAN_STATE = 2;
          else if(recvData.equalsIgnoreCase("max")) FAN_STATE = 3;
        break;
        case V_HVAC_SETPOINT_COOL:
          Serial.println("V_HVAC_SETPOINT_COOL");
          TEMP_STATE = message.getFloat();
          Serial.println(TEMP_STATE);
        break;
        case V_HVAC_FLOW_STATE:
          Serial.println("V_HVAC_FLOW_STATE");
          if (recvData.equalsIgnoreCase("coolon")) {
            POWER_STATE = 1;
            MODE_STATE = MODE_COOL;
          else if (recvData.equalsIgnoreCase("heaton")) {
            POWER_STATE = 1;
            MODE_STATE = MODE_HEAT;
          else if (recvData.equalsIgnoreCase("autochangeover")) {
            POWER_STATE = 1;
            MODE_STATE = MODE_AUTO;
          else if (recvData.equalsIgnoreCase("off")){
            POWER_STATE = 0;
          break;
      sendHeatpumpCommand();
      sendNewStateToGateway();
    The second one uses ifs
      int val;
      if (message.type == V_RGB) {
        Serial.println( "V_RGB command: " );
        Serial.println(message.data);
        long number = (long) strtol( message.data, NULL, 16);
        // Save old value
        strcpy(rgbstring, message.data);
        // Split it up into r, g, b values
        red = number >> 16;
        green = number >> 8 & 0xFF;
        blue = number & 0xFF;
        send_status();
        set_hw_status();
      } else if (message.type == V_LIGHT || message.type == V_STATUS) {
        Serial.println( "V_LIGHT command: " );
        val = atoi(message.data);
        if (val == 0 or val == 1) {
          on_off_status = val;
          send_status();
          set_hw_status();
      } else if (message.type == V_DIMMER || message.type == V_PERCENTAGE) {
        Serial.print( "V_DIMMER command: " );
        if (val >= 0 and val <=100) {
          dimmerlevel = val;
          send_status();
          set_hw_status();
      } else if (message.type == V_VAR1 ) {
        Serial.print( "V_VAR1 command: " );
        if (val >= 0 and val <= 2000) {
          fadespeed = val;
      } else {
        Serial.println( "Invalid command received..." );
        return;
    Do i understand correctly that i should still with HVAC code and use cases and rewrite the rgb code just substituting
    with
    case V_RGB:
    • M moskovskiy82
           return;
        recvData.trim();
          case V_HVAC_SPEED:
          break;
          break;
              POWER_STATE = 1;
              POWER_STATE = 1;
              POWER_STATE = 1;
              POWER_STATE = 0;
            break;
        int val;
          // Save old value
          red = number >> 16;
          send_status();
          set_hw_status();
            send_status();
            set_hw_status();
            dimmerlevel = val;
            send_status();
            set_hw_status();
            fadespeed = val;
        } else {
          return;
      with
      case V_RGB:
      @moskovskiy82 yes that's correct.
      And don't forget the break; at end of each case.
        moskovskiy82
        How to da that? Internet tells me a can use
        case V_LIGHT:
        case V_STATUS:
        But that throws errors
        • M moskovskiy82
          case V_LIGHT:
          case V_STATUS:
          @moskovskiy82 it would help if you could post those errors...
            moskovskiy82
            wrote on last edited by moskovskiy82
            Well with this code
            case V_RGB:
              // Save old value
              red = number >> 16;
              send_status();
              set_hw_status();
            break;
            case V_LIGHT: case V_STATUS:
                send_status();
                set_hw_status();
            break;
            case V_DIMMER: case V_PERCENTAGE:
                dimmerlevel = val;
                send_status();
                set_hw_status();
            break;
            Get the following errors
            In function 'void receive(const MyMessage&)':
            IR_TESTBED:232: error: duplicate case value
            IR_TESTBED:232: error: previously used here
            IR_TESTBED:245: error: duplicate case value
            IR_TESTBED:245: error: previously used here
            Using library MySensors at version 2.1.1
            exit status 1
            • M moskovskiy82
              Well with this code
              case V_RGB:
                // Save old value
                red = number >> 16;
                send_status();
                set_hw_status();
              break;
                  send_status();
                  set_hw_status();
              break;
                  dimmerlevel = val;
                  send_status();
                  set_hw_status();
              break;
              exit status 1
              @moskovskiy82 ah. You caught a very subtle problem.
              From MyMessage.h:
                      V_STATUS                                = 2,    //!< S_BINARY, S_DIMMER, S_SPRINKLER, S_HVAC, S_HEATER. Used for setting/reporting binary (on/off) status. 1=on, 0=off
                      V_LIGHT                                 = 2,    //!< \deprecated Same as V_STATUS, **** DEPRECATED, DO NOT USE ****
              So behind the scenes, V_LIGHT is the same as V_STATUS (the integer 2).
              That means your code, when compiling, looks like this:
              case 2: case 2:
              and the compiler complains because the same value can only be used once in a switch clause.
              Same thing for the other two:
                      V_PERCENTAGE                    = 3,    //!< S_DIMMER. Used for sending a percentage value 0-100 (%).
                      V_DIMMER                        = 3,    //!< \deprecated Same as V_PERCENTAGE, **** DEPRECATED, DO NOT USE ****
              So just remove the "case V_LIGHT" and "case V_DIMMER" parts and you'll be good to go.
              M 1 Reply Last reply
                From MyMessage.h:
                case 2: case 2:
                moskovskiy82
                @mfalkvidd Thank you! That solved everything. Well almost. At the end of the heatpump sensor there was a call to two functions
                After moving the RGB code to the case switch - everytime i change the RGB light the AC beeps as it receives the command. Is there an easy solution for this?
