  3. DHT11 humidity and temperature fluctuations
4 Posts 3 Posters 2.2k Views 3 Watching
    moskovskiy82
    Have set up a mysensors relay node with DHT11.
    Seems the sensor is sending quite erraneous data. It is powered by some phone charger and off the same 5V line as arduino.
    The readings are taken every 60seconds
    Green is humidity, yellow is temp from DHT and blue is outside temperature from weatherunderground.
    There is a 10k pull up resistor in place. As can be seen the values for humidity some time spike into the unknown.
    What can be the reason for that? Power supply? Maybe need to define in the code the sensor type?
    #define SN "Vent Klapans"
    #define SV "2.1"
    //System settings
    #define MY_NODE_ID 56
    #include <Bounce2.h>
    #include <DHT.h>
    #include <math.h>
    #include <Wire.h>
    //SETUP PINS
    #define BUT1_PIN 7
    #define BUTTON_PIN2 8
    #define DHT_PIN 3
    #define RELAY_1  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    //Define connections
    #define CHILD_ID_HUM 3
    #define CHILD_ID_TEMP 4
    #define CHILD_BUT1_ID 7
    #define CHILD_BUT2 8
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    DHT dht;
    //MQ+DHT
    long DHT_Millis = 0;
    long DHT_interval = 60000;
    //Buttons
    Bounce debouncer1 = Bounce();
    Bounce debouncer_2 = Bounce();
    int oldValue1=-1;
    int oldValue_2=-1;
    bool state1;
    bool state2;
    MyMessage msgHumi(CHILD_ID_HUM, V_HUM);
    MyMessage msgBut1(CHILD_BUT1_ID,V_STATUS);
    MyMessage msgbut2(CHILD_BUT2,V_TRIPPED);
    void before()
      dht.setup(DHT_PIN);
      pinMode(BUT1_PIN,INPUT_PULLUP);
      pinMode(BUTTON_PIN2,INPUT);
      digitalWrite(BUTTON_PIN2, HIGH);
      debouncer1.attach(BUT1_PIN);
      debouncer1.interval(5);
      debouncer_2.attach(BUTTON_PIN2);
      debouncer_2.interval(5);
      for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS;sensor++, pin++) // Fetch relay status
        pinMode(pin, OUTPUT);   // Then set relay pins in output mode
        digitalWrite(pin, loadState(sensor)?RELAY_ON:RELAY_OFF); // Set relay to last known state (using eeprom storage)
    {  Serial.begin(115200); }
      sendSketchInfo(SN, SV);
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_BUT1_ID, S_LIGHT);
      present(CHILD_BUT2, S_DOOR);
        present(sensor, S_LIGHT); // Register all sensors to gw (they will be created as child devices)
      int value_but_2 = debouncer_2.read();
      unsigned long DHT_Current_Millis = millis();
      if(DHT_Current_Millis - DHT_Millis > DHT_interval)
        DHT_Millis = DHT_Current_Millis;
        if (isnan(temperature))
          if (isnan(humidity))
        else
          send(msgHumi.set(humidity, 1));
          Serial.print("T: ");
          Serial.println(temperature);
          Serial.print("H: ");
          Serial.println(humidity);
        debouncer1.update();
          int value = debouncer1.read();
          if (value != oldValue1)
            // Send in the new value
            send(msgBut1.set(value==HIGH ? 1 : 0));
            oldValue1 = value;
        debouncer_2.update();
        if (value_but_2 != oldValue_2)
        if ( value_but_2==0)
          state2 = !state2;
          send(msgbut2.set(state2));
        oldValue_2 = value_but_2;
        if (message.type==V_STATUS) // We only expect one type of message from controller. But we better check anyway.
          digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF); // Change relay state
          saveState(message.sensor, message.getBool()); // Store state in eeprom
          Serial.print("Incoming change for sensor:"); // Write some debug info
          Serial.print(message.sensor);
    • M moskovskiy82
      #define SV "2.1"
      //System settings
      #include <DHT.h>
      #include <math.h>
      #include <Wire.h>
      //SETUP PINS
      #define BUT1_PIN 7
      #define DHT_PIN 3
      DHT dht;
      //MQ+DHT
      //Buttons
      int oldValue1=-1;
      int oldValue_2=-1;
      bool state1;
      bool state2;
      void before()
        dht.setup(DHT_PIN);
          else
              oldValue1 = value;
            state2 = !state2;
      @moskovskiy82 the indentation after the first isnan clause is wrong. Not sure what your intention is, but it looks fishy.
      Debug output will probably make it easy to spot what is wrong.
      M 1 Reply Last reply
        moskovskiy82
        @mfalkvidd It's hard to catch. Otherwise usually looks normal
        • B
          B
          Ben Andrewes
          If you are having trouble reading the serial prints you could send a msg to controller stating the value as 100 degrees/100% - this would then give peakson the graph to indicate errors instead of trying to get the serial.
          I am not sure (and as I have only been attempting to program arduinos for a month or so, could be very wrong :) ) but I don't think your if/else statement is structured correctly and the else part is only linked to the if(isnan(temparature)). If
          You could try separate if/else for temp and humidity, i.e.
          if(isnan(temparature) {
          ...error msg
          else {
          ...send temp message
          If(isnan(humidity) {
          ...error msg
          else {
          ...send humidity msg
          I'm also not sure if you need this line:
          As you are only sampling every 60 seconds anyway...
