  3. Keep getting "st=fail" despite both 3.3V regulator and decoupling capacitors
10 Posts 8 Posters 5.8k Views 1 Watching
  • N
    N
    nanotube
    Folks, I have benefited a lot from reading this forum but have to come up here to ask for one more help. This problem has baffled me for nearly 2 months:
    Ethernet Gateway on VeraLite is made of a Uno with ethernet shield.
    Problem is with a DHT22 sensor I am trying to make. The sensor radio is the correct NRF24L01+. Using a USB Arduino Nano. DHT22 code is working fine. But the radio keeps giving "st=fail" error, see below.
    ensor started, id 1
    send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=3,st=fail:1.4
    send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
    send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=8,st=fail:Humidity
    send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
    send: 1-1-0-0 s=0,c=0,t=7,pt=0,l=3,st=fail:1.4
    send: 1-1-0-0 s=1,c=0,t=6,pt=0,l=3,st=fail:1.4
    send: 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,st=fail:74.3
    send: 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
    T: 74.30
    send: 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,st=fail:55.8
    H: 55.80
    send: 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,st=fail:55.5
    Now every once in a couple weeks I will get "lucky" and get a few minutes of "st=ok" and connect to Vera successfully. But after a few minutes the data stream would just stop and when I checked debug on the sensor Arduino serial output it was "st=fail" again. I have put the radio power on the output of a 5 V to 3.3V regulator; have put 4.7uF and even 10uF capacitor across the radio power pins but kept seen the same results. Why didn't it work?
    • N nanotube
      ensor started, id 1
      T: 74.30
      H: 55.80
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @nanotube
      So you have decoupling capacitors, what type of power supply are you using?
      Are you sure your problem is the node and not the gateway? Ethernet shield uses a lot of Power. try looking at your serial output from the gateway
      • N
        N
        nanotube
        Honestly I'm not sure whether gateway problems would also lead to the sensor radio "st=fail" -- is that one of the reasons? Thanks.
        For the sensor I have tried both 5V brick power supply to USB and just plugging in to the USB on my desktop computer;
        for the gateway it's mostly on a 6V brick power supply, plugged directly to the power port on the Uno.
        I will try debug mode on the gateway and see if there is a message.
        • m26872M
          m26872M
          m26872
          Try a "delay(100)" before every send message.
            It's the gateway that acks(replies) your sensor transmissions. This is the problem you're seeing. You must ensure gateway have enough power and is correctly decoupled.
            • RJ_MakeR
              RJ_MakeR
              RJ_Make
              Just a note, I have to use 47uf capacitors to get my radios working with V1.4.
              RJ_Make
              • N
                N
                nanotube
                Happy new year folks. Long overdue update but still no cigar...
                Thanks to everybody above's input I now understand the fail problem comes from my gateway. I have tried the following steps:
                Gateway (Arduino Uno) powered via USB by a high quality charger (iphone charger);
                5V from Uno goes to an external down converter to get stable 3.3V;
                Radio powered by 3.3V in parallel with 40 uF capacitor.
                Sensor radio is also powered in parallel with 20 uF caps. I measured after all these steps I get 3.300 +/- 2 mV to the radio. Well problem solved or so I thought.
                Only after these steps would I be able to get stable communication (verified by serial debug from the sensor), but it only lasts two hours max, after which I would get st=fail again until I unplug power to the gateway, replug it in and reload Vera.
                Resetting gateway didn't help; simply reloading Vera didn't help. It had to be a hard reset by unplugging it. I am starting to suspect the radio I bought off eBay is from a bad batch (I bought a 5 pack but switching between them didn't help - they all communicate for a few minutes to 2 hours max then drop dead). Any ideas ? Thanks.
                Dan S.D 1 Reply Last reply
                • N nanotube
                  Dan S.D
                  Dan S.D
                  Dan S.
                  @nanotube My ethernet gateway has a separate 5 volt power supply via the down converter to power the radio and another power supply for the uno/ethernet boards. The ethernet board Uno combination consumes quite a bit of power. Also I don't know if I would call the iPhone charger high quality. Bottom line is I think you still have a power supply issue using one charger for powering everything. Certainly it is good to have the separate down converter rather than tapping off the UNO but you are placing a lot of demand on a single power supply. I think it is best to power the radio separately (but make sure all grounds are common).
                  • G
                    G
                    griffinsaic
                    wrote on last edited by griffinsaic
                    While not involving an Uno, I thought I would share my experience.
                    I was having a similar issue with my nano serial gateway; not accepting messages or incomplete messages from sensors and/or nothing was working at all. Instead of adding an external power supply, I used a Nano Expansion Sensor shield. This cleaned up the power issues, and makes it easier for me to attach several components.
                    http://www.ebay.com/itm/Nano-O-Expansion-sensor-Shield-Arduino-UNO-R1-Nano-3-0-duemilanove-2009-/310546482805?pt=LH_DefaultDomain_0&hash=item484e034675
                    While not ideal for small for factor, it works. I have not had any further communication issues with the serial gateway. However, I do have issues when the sensor battery voltage drops below a certain level. While I have a multimeter, I have not checked at which voltage. Instead I change the batteries whenever the LEDs get dim.
                    From my limited experience, power is most likely your issue.
                    • daulagariD
                      daulagariD
                      daulagari
                      I agree with @griffinsaic, power is most likely your issue but another thing to check is interference, see the Issues with multiple gateways + choosing frequency / channel thread.
