  3. Anyone help with 4 relays please?
34 Posts 6 Posters 7.5k Views 9 Watching
  • skywatchS Offline
    skywatchS Offline
    skywatch
    I have a pro mini set with nrf24l01+ and a 4 relay board. GW and controller both see the set up but it is unreliable (does not always respond to state changes sent from the controller) Seems pretty random as to if it will change or not...
    I tried 2 different methods, here they are......
    1. Take the latest code from dev branch (examples/actuator/relay) and change that to make a 4 relay board work. - It does switch 'sometimes' but is not reliable enough to use...
       The MySensors Arduino library handles the wireless radio link and protocol
       between your home built sensors/actuators and HA controller of choice.
       The sensors forms a self healing radio network with optional repeaters. Each
       repeater and gateway builds a routing tables in EEPROM which keeps track of the
       network topology allowing messages to be routed to nodes.
       Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
       Copyright (C) 2013-2015 Sensnology AB
       Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
       Documentation: http://www.mysensors.org
       Support Forum: http://forum.mysensors.org
       This program is free software; you can redistribute it and/or
       modify it under the terms of the GNU General Public License
       version 2 as published by the Free Software Foundation.
       REVISION HISTORY
       Version 1.0 - Henrik Ekblad
       DESCRIPTION
       Example sketch showing how to control physical relays.
       This example will remember relay state after power failure.
       http://www.mysensors.org/build/relay
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_NODE_ID 140
    //#define MY_REPEATER_FEATURE
    MyMessage relay_msg;
    //#define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    const int RELAY_PIN[]  {4, 5, 6, 7}; // Array for relay pins.
    #define NUMBER_OF_RELAYS 4 // Total number of attached relays
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    void before()
      for (int sensor = 1, pin = RELAY_PIN[sensor - 1]; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
        pinMode(pin, OUTPUT);
        //digitalWrite(pin, loadState(sensor)?RELAY_ON:RELAY_OFF);
        digitalWrite(pin, LOW);
      sendSketchInfo("4Relay", "1.0a");
        present(sensor, S_BINARY);
    void receive(const MyMessage & message)
      // Handle incoming relay commands
        // Change relay state
        if (RELAY_PIN[message.sensor - 1]) {
          digitalWrite(RELAY_PIN[message.sensor - 1], message.getBool() ? RELAY_ON : RELAY_OFF);
          // Store state in eeprom
          saveState(message.sensor - 1, message.getBool());
          // Write some debug info
          Serial.print(message.sensor);
    void relay_msg_constructor(int sensor, uint8_t type)
      relay_msg.setSensor(sensor);
      relay_msg.setType(type);
    Second attempt was to look in the forums and try an update an old thread with mys 1.x code to work with 2.2.0-rc.1 - Here is that code with alarming similar results..... ;)
           REVISION HISTORY
           Version 1.1 - HenryWhite
           DESCRIPTION
           Optional attachment of motion sensor to control the relays is possible.
           Notes:
              -- The Child-IDs of the attached relays range from 1 up to (1-(NUMBER_OF_RELAYS))
              -- Make sure to adjust the potentiometer for triggertime on your motion sensor as leftmost as possible,
                 because the countdown will not start until the motion sensor reports back a "0" (no movement)
    #include <Bounce2.h>
    //----------------------- Library Configuration ---------------------
    //#define MY_DEBUG                          // uncomment to enable debug prints to serial monitor
    //#define MY_REPEATER_FEATURE               // uncomment to enable repeater functionality for this node
    #define MY_NODE_ID 140                   // uncomment to define static node ID
    // Enable and uncomment attached radio type
    //----------------------- Relay and Motion Sensor Configuration -----------------------
    #define NUMBER_OF_RELAYS  4                                       // Total number of attached relays. Must be equal to total number of elements in array below!
    #define NUMBER_OF_SWITCHES 4                                      //Total of local manual override switches.
    const int sw[]                      =     {14, 15, 16, 17};        //switches connected to a0-a3.
    const int RELAYS[]   {4, 5, 6, 7};             // digital pins of attached relays
    int value = -1;
    #define RELAY_ON          1                                       // GPIO value to write to turn on attached relay
    #define RELAY_OFF         0                                       // GPIO value to write to turn off attached relay
    bool ack = 1;                                                     // set this to 1 if you want destination node to send ack back to this node
    int oldValue = 0;
    bool state;
    //----------------------- DO NOT CHANGE -----------------------------
    MyMessage relay_msg;                                // Initialize relay message
    void before()
      for (int i = 1; i <= NUMBER_OF_RELAYS; i++)
        // set relay pins to output mode
        pinMode(RELAYS[i-1], OUTPUT);
        digitalWrite(RELAYS[i-1], LOW);
        // Restore relay to last known state (using eeprom storage)
        //  digitalWrite(RELAYS[i], loadState(sensor) ? RELAY_ON : RELAY_OFF);
      for (int i = 14; i <= (NUMBER_OF_SWITCHES + 13); i++)
        pinMode(sw[i], INPUT_PULLUP);
      sendSketchInfo("Relay/Motion", "1.0");
      for (int i = 1; i <= NUMBER_OF_RELAYS; i++) {
        present(i, S_BINARY, "Relay");
      if (value == 0) {
        for (int i = 14; i < (NUMBER_OF_SWITCHES + 14); i++) {
          digitalRead(i);
          send(relay_msg.set(state ? false : true)); // Send new state and request ack back
        oldValue = value;
        if (RELAYS[message.sensor - 1]) {
          digitalWrite(RELAYS[message.sensor - 1], message.getBool() ? RELAY_ON : RELAY_OFF);
    I have reached the limit of my current understanding of this and could really do with some help to get this working before I even try and add buttons for local emergency override ;)
      You need to monitor the logs, check if you get any NACKs on gateway and check if the node is really receiving the message. As a test I'd try to put a wait(500) at the end of loop just to see if you get any changes.
      • skywatchS Offline
        skywatchS Offline
        skywatch
        @gohan,
        Thanks for the idea and moral support!
        With due respect to all involved I found this thread from last year.....
        https://forum.mysensors.org/topic/1299/array-relay-button-actuator
        The code didn't compile at first due to a typo and then when loaded it didn't work due to deprecated sensor-type and variable-type. I updated it for compatibility with 2.2.0-rc.1 and it nearly all works.
        It compiles and loads.
        The gw and controller see it and buttons made in the controller switch the relays fine.
        The local physical buttons also toggle the relays just fine.
        But when the physical buttons are used to toggle the relays, the controller does not update the status on the screen so any changes made locally are not known by the controller.
        Here is the updated code, if anyone can see an issue in the void loop() then might be causeing this I would love to hear about it!
        #define MY_RF24_PA_LEVEL   RF24_PA_LOW
        #define RELAY_ON 0                      // switch around for relay HIGH/LOW state
        #define RELAY_OFF 1
        #define noRelays 4                     //2-4
        const int relayPin[] = {4,5,6,7};          //  switch around pins to your desire
        const int buttonPin[] = {A0,A1,A2,A3};      //  switch around pins to your desire
        class Relay             // relay class, store all relevant data (equivalent to struct)
        public:
          int buttonPin;                   // physical pin number of button
          int relayPin;             // physical pin number of relay
          byte oldValue;                    // last Values for key (debounce)
          boolean relayState;               // relay status (also stored in EEPROM)
        Relay Relays[noRelays];
        Bounce debouncer[noRelays];
        MyMessage msg[noRelays];
        void setup(){
            sendHeartbeat();
            wait(250);
            // Initialize Relays with corresponding buttons
            for (int i = 0; i < noRelays; i++){
            Relays[i].buttonPin = buttonPin[i];              // assign physical pins
            Relays[i].relayPin = relayPin[i];
            msg[i].sensor = i;                                   // initialize messages
            msg[i].type = V_STATUS;
            debouncer[i] = Bounce();                        // initialize debouncer
            debouncer[i].attach(buttonPin[i]);
            debouncer[i].interval(5);
            pinMode(Relays[i].buttonPin, INPUT_PULLUP);
            //digitalWrite(Relays[i].relayPin, RELAY_OFF);
            wait(250);
            Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
            digitalWrite(Relays[i].relayPin, Relays[i].relayState? RELAY_ON:RELAY_OFF);   // and set relays accordingly
            send(msg[i].set(Relays[i].relayState? true : false));                  // make controller aware of last status
            wait(250);
        void presentation()  {
              sendSketchInfo("MYS-4-Relay", "0.1");
              wait(250);
              present(i, S_BINARY);                               // present sensor to gateway
            for (byte i = 0; i < noRelays; i++){
            debouncer[i].update();
            byte value = debouncer[i].read();
            if (value != Relays[i].oldValue && value==0){
            digitalWrite(Relays[i].relayPin, Relays[i].relayState?RELAY_ON:RELAY_OFF);
            saveState( i, Relays[i].relayState );}                 // save sensor state in EEPROM (location == sensor number)
                Relays[i].oldValue = value;
        // process incoming message
        void receive(const MyMessage &message){
           if (message.type == V_STATUS){
           if (message.sensor <noRelays){            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
           digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState? RELAY_ON:RELAY_OFF); // and set relays accordingly
           saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
        • skywatchS Offline
          skywatchS Offline
          skywatch
          If anyone is interested this now works perfectly with mycontroller, local buttons and remote buttons too.....
          Petr NosekP Z 2 Replies Last reply
          • skywatchS skywatch
            Petr NosekP Offline
            Petr NosekP Offline
            Petr Nosek
            @skywatch Hi, I was trying to follow your findings as I have exactly the same issue, but unfortunately, although I basically used the same setup as you did, it still misbehaves. Sometimes is reacts immediately, 5 times in a row, and sometimes it simply does not work for 10 attempts. My 8 relay sketch is so simple that it can not be simpler. Also using the capacitor - still no effect. Other relay sketch - same code, same everything - works as expected :( Really no idea.
              Z Offline
              Z Offline
              ZachFlem
              wrote on last edited by ZachFlem
              @skywatch said in Anyone help with 4 relays please?:
              Any modification to the above code? This could be very handy for me!
              EDIT: does each button pin correspond to a relay? So in your example A0 relates to 4?
              Or can I use the rules in MC to dynamically assign buttons to operations?
              • skywatchS Offline
                skywatchS Offline
                skywatch
                @petr nosek
                You can only compare the one that works with the one that doesn't and see if you can figure out what is different and causing the problems.
                @ZachFlem
                Yes pins A0-A3 are button inputs for relay 1-4.
                Yes, works from mycontroller and buttons - I am re-learning all this again now as my controller sd card died and I lost a lot of settings - still it will be worth it.
                Petr NosekP 1 Reply Last reply
                  @petr nosek
                  @ZachFlem
                  Petr NosekP Offline
                  Petr NosekP Offline
                  Petr Nosek
                  @skywatch thanks for the answer. I did compare all and they all share teh same code. Pretty much. Some work for year or two without being touched and they are even further away from the gateway. I do think, that there is either HW problem with the arduino or the radio module. Before I touch it - which of those two determine what ID is the sensor? Is it the Radio module or arduino? I ask because when I change the one which delivers the ID, all the relays on the controller will be lost and I will have to rewrite all related dependencies etc.
                  Regarding your further not on the lost configuration. I found somewhere a piece of code - a script, which does upload daily the current full database and configuration to dropbox - so in case I loose the raspberry Pi or SD card, I can restore it in a minute with the history. If you ned I can find it and send it.
                    Node id is stored in Arduino eeprom
                    • skywatchS Offline
                      skywatchS Offline
                      skywatch
                      My currnet setup is running fine although there are occasional dropouts and that needs investigation.
                      I added a heartbeat for the controller as the node often has no communications for hours at a time.
                      I also tried to get 'ack' working with the node and gw/controller and this gave me some issues that I didn't have any time to really look into (World Cup etc....) ;)
                      Hopefully I get some more time soon to look into this again.
                      • Petr NosekP Offline
                        Petr NosekP Offline
                        Petr Nosek
                        Hi skywatch,
                        would you be so kind and share your ack and heart beat code snippets? I tried to use the code from examples, but it seems teh heartbeat never worked as expected. Regarding the ack - I am getting constantly a message: Error: MySensors: Repeating previous command (2/2) - seems to me to be related to ack as it simply does not get acknowledgement from the node and repeats the command again. But in 99% cases the command seems to be executed fine.
                        skywatchS 1 Reply Last reply
                          Petr NosekP Offline
                          Petr NosekP Offline
                          Petr Nosek
                          @skywatch P.S. I have one more theory I need to prove. Based on another discussion where my sauna control display fails to display properly after several relay switch on and off which according to many users is caused by the use of common power source for arduino/LCD and the relays which create short but noticeable power peaks. So I will try to power my 8 node relay board from a independent power source from the power used for arduino... A little chance, but worth testing.
                          • Petr NosekP Petr Nosek
                            Hi skywatch,
                            skywatchS Offline
                            skywatchS Offline
                            skywatch
                            @petr-nosek
                            See below for the current code I run for my 4 relay test node.....
                            #define MY_RF24_PA_LEVEL   RF24_PA_HIGH
                            #define MY_RF24_CHANNEL (97)
                            #define MY_PARENT_NODE_ID 0
                            //#define MY_SIGNING_ATSHA204
                            //#define MY_SIGNING_REQUEST_SIGNATURES
                            #define RELAY_ON 1                      // switch around for relay HIGH/LOW state
                            #define RELAY_OFF 0
                            unsigned long HEARTBEAT_TIME = 60000*10; //every 10 mins.
                            unsigned long last_heartbeat_time = 0;
                            public:
                            void setup(){
                                wait(250);
                                wait(250);
                                send(msg[i].set(Relays[i].relayState? true : false),true);                  // make controller aware of last status
                                wait(250);
                                  sendSketchInfo("MYS-4-Relay", "0.2");
                                  wait(250);
                                  present(0, S_BINARY,"Relay 1");
                                  wait(150);
                                  present(1, S_BINARY,"Relay 2");
                                  wait(150);
                                  present(2, S_BINARY,"Relay 3");
                                  wait(150);
                                  present(3, S_BINARY,"Relay 4");
                                // Send heartbeat
                                if ((millis() - last_heartbeat_time) > HEARTBEAT_TIME) {
                                sendHeartbeat();
                                last_heartbeat_time = millis();
                              #ifdef MY_DEBUG
                                Serial.println("Sent heartbeat");
                                wait(50);
                               if (message.sensor < noRelays){            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                            This includes my latest attempt at heartbeat and ack. Heartbeat works fine, but ack is still a problem with mycontroller.
                            I can't risk using it until ack and signing are implemented and fully reliable as it will be controlling mains devices and that needs to be done securely.
                            As for your sauna problem don't forget to connect the grounds between power supplies. You could try adding a 0.1uF capacitor across the 5v supply along with a nice big 220uF 6.3V or higher electrolytic. That might help with spikes or momentary sags in the voltage caused by current rush.
                              If you want complete isolation between relays and arduino you don't need to share common ground if your relays have optocouplers.
                              • skywatchS Offline
                                skywatchS Offline
                                skywatch
                                @gohan, Good point! :)
                                  Petr NosekP Offline
                                  Petr Nosek
                                  Good day everyone,
                                  in case someone faces the same issues I did:
                                  • controlling multiple relays from one arduino and sharing the same power (powering relay board from Arduino
                                    or
                                  • controlling relay which switches high loads circuit causing connected LCD to show garbage and again powering the relay from Arduino...
                                  ...the solution proposed above is the only one which helps - provide separated power supply for the relay boards. Once this is done with an extra little bucket power source for 5V (3W) all the issues with relays not working, domoticz not switching relays, LCD going crazy - all solved. I should have done this long before.
                                  Thanks everyone!
                                  P.S. For those, who still do not follow, the relay boards for Arduino contain extra jumper connecting VCC and JD-VCC (plus sometimes extra GND pin). So remove the jumper and connect the standalone, not common sharing 5V power source to this extra JD-VCC and GND (or GND near the IN1 pin) and disconnect the GND from Arduino and then you have a full optosiolation and then there are no interferences and other garbage breaking the Arduino functionality by switching relays coils. (also explained here: https://forum.arduino.cc/index.php?topic=470134.0)
                                  • parachutesjP Offline
                                    parachutesj
                                    If this really solves the problem...would have saved me a lot of headaches. Got rid of all my relay nodes in the meantime.
                                    • parachutesjP parachutesj
                                      Petr NosekP Offline
                                      Petr NosekP Offline
                                      Petr Nosek
                                      @parachutesj I do say it does. I have about 50 nodes in my house, 15 relays or so, temperature sensors and some others. All the relays i power now with standalone little china made 5V, 3W adapters and as I sit now in my house I do switch on and off lights, turn on gate, control pumps in greenhouse, all works on the first tap. I am finally happy with my mysensors equipped domoticz, first after 2 years. It took my so long to just give it a try.
                                      parachutesjP 1 Reply Last reply
                                        parachutesj
                                        @petr-nosek my problem was maily unrealiability. They worked for minutes or weeks and then stopped (or anything in between).
                                        All other nodes work flawless.
                                        Maybe give it a try at next project
                                          have you been using watchdogs on your sketches?
                                          12.1k
