  3. Repeater node crashes
16 Posts 3 Posters 4.7k Views 3 Watching
  • mimaretM
    mimaretM
    mimaret
    I mounted sensors on an Arduino pro mini 3.3v, radio nrf24 managing a DHT22, a 1Wire 18b20 and a door contact under interruption. Everything is working very well.
    On this basis, I created a repeater (#define MY_REPEATER_FEATURE) by replacing the Delay () statement with Wait (). The repeater crashes during the Wait () statement, but interrupts still work. I turned off the interrupt and the repeater does not crash anymore.
    Do you have an idea
    Thank you for your answers.
    Home Assistant, Raspi MQTT Gateway , nodes MySensors
    • mimaretM
      mimaretM
      mimaret
      In addition to my previous post:
      I use the MySensors 2.1.1 library and I tested with 2.2.0 rc2. same result.
      IDE 1.8.0
      I also noticed that the led pin 13 is off on the sensors and adding (#define MY_REPEATER_FEATURE), the led remains on.
      • rejoe2R
        rejoe2R
        rejoe2
        Thank you for adding some more info, now there's only the code missing if you follwo the instructions here.
        Sounds like you did not do a "non-blocking-loop()" but used some kind of wait/delay functionality instead. I'd highly recommend using non-blocking methods for repeaters and not use wait/delay (with the exeption of short periodes needed for the DS18B20 to do their measurements).
        • mimaretM
          mimaretM
          mimaret
          The code is inspired by MySensors sketchs :
            MM Octobre 2017
           1.5 remplacé Delay() par Wait()
               Update intervalle 5 min
               readDHT() : wait(1100)
          // Enable debug prints
          //#define MY_DEBUG
          #define MY_NODE_ID 111
          #define SketchName "Buanderie"
          #define SketchVer "1.5"
          #include <MyConfig.h>
          #include <DHT.h>
          #include <OneWire.h>
          #define ONE_WIRE_BUS 5
          #define DHT_DATA_PIN 3
          #define DOOR_PIN 2
          #define DHTTYPE DHT22
          #define SENSOR_TEMP_OFFSET 0
          static const uint64_t UPDATE_INTERVAL = 5 * 60000;
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          #define CHILD_ID_DOOR 2
          #define CHILD_ID_1WIRE 3
          float lastTemp;
          float lastHum;
          float lastTemp1W;
          uint8_t nNoUpdatesTemp;
          uint8_t nNoUpdatesHum;
          uint8_t nNoUpdatesTemp1W;
          MyMessage msgDoor(CHILD_ID_DOOR, V_TRIPPED);
          MyMessage msg1W(CHILD_ID_1WIRE, V_TEMP);
          DHT dht;
          DallasTemperature sensors(&oneWire); // Pass our oneWire reference to Dallas Temperature.
          DeviceAddress insideThermometer;
          void presentation() {
            sendSketchInfo(SketchName, SketchVer);
            present(CHILD_ID_HUM, S_HUM);
            present(CHILD_ID_DOOR, S_DOOR);
            present(CHILD_ID_1WIRE, S_TEMP);
            analogReference(INTERNAL);
            wait(500);
            pinMode(DOOR_PIN, INPUT_PULLUP);
            digitalWrite(DOOR_PIN, HIGH);
            oneWire.reset_search();
            // assigns the first address found to insideThermometer
            if (!oneWire.search(insideThermometer)) {
            sensors.setResolution(insideThermometer, 9);
            attachInterrupt(digitalPinToInterrupt(DOOR_PIN), DoorMoving, CHANGE);
          void DoorMoving() {
              Serial.println("------> Door");
              send(msgDoor.set(digitalRead(DOOR_PIN) == HIGH ? 1 : 0));
          void read1Wire() {
            sensors.requestTemperatures(); // Send the command to get temperatures
            float tempC = sensors.getTempC(insideThermometer);
            if (tempC != lastTemp1W  && tempC > -50.00 && tempC != 85.00 || nNoUpdatesTemp1W == FORCE_UPDATE_N_READS) {
              send(msg1W.set(tempC, 1));
              lastTemp1W = tempC;
              nNoUpdatesTemp1W = 0;
          #ifdef MY_DEBUG
              Serial.print("Temp 1Wire C: "); Serial.println(tempC);
            } else
              nNoUpdatesTemp1W++;
          void readDHT() {
            dht.readSensor(true);
            wait(1100);
            if (isnan(temperature)) {
              Serial.println("T DHT!");
              lastTemp = temperature;
              // Reset no updates counter
              nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
              Serial.print("T: "); Serial.println(temperature);
            } else {
              nNoUpdatesTemp++;
            if (isnan(humidity)) {
              Serial.println("H DHT");
              lastHum = humidity;
              nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
              Serial.print("H: "); Serial.println(humidity);
            } else {
              nNoUpdatesHum++;
            Serial.println("------> readDHT");
            readDHT();
            Serial.println("------> read1Wire");
            read1Wire();
            Serial.println("------> wait");
            wait(UPDATE_INTERVAL);
          rejoe2R 1 Reply Last reply
          • mimaretM mimaret
              MM Octobre 2017
            //#define MY_DEBUG
            #include <DHT.h>
            #define DOOR_PIN 2
            float lastTemp;
            float lastHum;
            float lastTemp1W;
            DHT dht;
              wait(500);
            void DoorMoving() {
            void read1Wire() {
                lastTemp1W = tempC;
            #ifdef MY_DEBUG
              } else
                nNoUpdatesTemp1W++;
            void readDHT() {
              wait(1100);
                nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
              } else {
                nNoUpdatesTemp++;
                lastHum = humidity;
                nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
              } else {
                nNoUpdatesHum++;
              readDHT();
              read1Wire();
            rejoe2R
            rejoe2R
            rejoe2
            @mimaret Well organised code, congratulation.
            Imo, you should just change your loop() (btw: that's really cool, just "straight forward") to be non-blocking. The principle is described here: https://www.arduino.cc/en/tutorial/BlinkWithoutDelay.
            If you need a working implementation of the blink-without-delay function within MySensors, see the https://www.mysensors.org/build/pulse_power example.
            Additional remarks: As mysensors may use interrupts in the future, (if possible) connecting Pin2 to nRF interrupt, door sensor to Pin3 and use one of the remaining Pins to connect the DHT may be a good idea.
            • mimaretM
              mimaretM
              mimaret
              @rejoe2 Thank you for your reply.
              I seemed to have read that for a repeater it was necessary to replace delay () by wait (). . .
              I will adapt my program according to your recommendations and keep you informed.
              • mimaretM mimaret
                @mimaret could you post the debug output from before and during the crash?
                What you're doing should work. The debug output usually gives useful info on why things don't work the way they are supposed to.
                Also, check the power problem flowchart on the page @rejoe2 linked earlier. PA_MAX puts very high stress on the power supply. My guess is that this is related to insufficient power stability.
                • mimaretM
                  mimaretM
                  mimaret
                  @mfalkvidd Thank you for your reply.
                  I do not think about power problem. The power supply can deliver 1A and I mounted a capacitor of 470 uF on the 3.3v and a 47 uF close to the radio module. I had doubts about hardware and I set up a second repeater.
                  On the first repeater, radio module nrf24L01 + PA + LNA. On the second repeater, radio module nrf24L01 +. Same problem.
                  When the repeater crashes, the interrupt is executed again. The led pin 13 that I do not manage is ON during normal operation and goes OFF when the repeater crashes.
                  I noticed that by disabling the interrupt (// attachInterrupt (....), the repeater does not crash.
                  I will look how to check the state of memory, stack, etc.
                  I also include the debug output and I do not see anything particular.
                  • mimaretM
                    mimaretM
                    mimaret
                    OOPS :
                    19820560 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                    ------> Door
                    ------> Door
                    19825700 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                    ------> Door
                    19826745 !TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=NACK:0
                    ------> Door
                    19826745 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:0
                    19826747 TSF:MSG:READ,255-255-255,s=255,c=7,t=255,pt=7,l=25,sg=1: 0
                    19826755 !TSF:MSG:LEN,7!=32
                    ------> readDHT
                    20105310 TSF:MSG:SEND,111-111-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:42.4
                    H: 42.40
                    ------> read1Wire
                    20105426
                    ------> readDHT
                    20405309 TSF:MSG:SEND,111-111-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:21.8
                    T: 21.80
                    20405323 TSF:MSG:SEND,111-111-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:42.1
                    H: 42.10
                    ------> read1Wire
                    20405440
                    20700045 TSF:SAN:OK
                    ------> readDHT
                    20705310 TSF:MSG:SEND,111-111-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:41.9
                    H: 41.90
                    ------> read1Wire
                    20705427
                    ------> Door
                    20707352 !TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=NACK:1
                    ------> Door
                    20707352 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:0
                    ------> Door
                    20723965 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                    ------> Door
                    20725862 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                    ------> Door
                    <------------------------------------CRASH-----------------
                    ------> Door
                    20729143 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                    ------> Door
                    20730232 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                    ------> Door
                    • mimaretM mimaret
                      OOPS :
                      ------> Door
                      ------> Door
                      ------> Door
                      ------> Door
                      ------> readDHT
                      H: 42.40
                      ------> read1Wire
                      20105426
                      ------> readDHT
                      T: 21.80
                      H: 42.10
                      ------> read1Wire
                      20405440
                      20700045 TSF:SAN:OK
                      ------> readDHT
                      H: 41.90
                      ------> read1Wire
                      20705427
                      ------> Door
                      ------> Door
                      ------> Door
                      ------> Door
                      ------> Door
                      ------> Door
                      ------> Door
                      ------> Door
                      @mimaret could you describe what you mean ny "crash"? I thought you meant that the node rebooted, but I see now that my assumption was wrong.
                      • mimaretM
                        mimaretM
                        mimaret
                        In fact, the node no longer executes the program and the only solution is to restart it with a reset or switch off the power supply.
                        • mimaretM mimaret
                          @mimaret strange. The (re)start should be visible in the debug output. Did you cut it out?
                          • mimaretM
                            mimaretM
                            mimaret
                            There is no restart. Only the interrupt executes when I open the door contact. The Loop () does not continue. I did not cut anything, I just added the crash line as soon as the program stopped.
                            • mimaretM mimaret
                              @mimaret thanks for explaining.
                              I think the problem lies in calling send from within the interrupt handler. Interrupt handlers are supposed to execute very quickly. Usually they just set a flag that there is work to be done, and return.
                              From https://learn.adafruit.com/multi-tasking-the-arduino-part-2/interrupt-etiquette
                              Code in the ISR should not call anything that requires interrupts to be active (e.g. delay() or anything that uses the i2c bus). This will result in hanging your program.
                              From the debug output, send fails. That means the node must have tried to send, waited for acknowledgement until timeout, tried to send again and waited and so on until the max number of attempts is reached. That's way too much time to spend inside an interrupt handler. And the radio use
                              Try to only set a variable inside the interrupt handler, and perform the send from inside loop instead.
                              Also see https://arduino.stackexchange.com/questions/30968/how-do-interrupts-work-on-the-arduino-uno-and-similar-boards/30969
                              • mimaretM
                                mimaretM
                                mimaret
                                A big thank you for your contribution. I modified the program according to your proposals. Everything is working. I am attaching you the pieces of code relating to the door contact.
                                My problem is solved.
                                  DoorChange = 1;
                                  LastDoor = 0;
                                void DoorMoving() {
                                    DoorChange = 1;
                                void readDoor() {
                                  if (DoorChange) {
                                    boolean Door = (digitalRead(DOOR_PIN));
                                    if (Door != LastDoor) {
                                      send(msgDoor.set((Door) == HIGH ? 1 : 0));
                                      LastDoor = Door;
                                      DoorChange = 0;
                                  readDoor();
                                  if (currentMillis - previousMillis >= UPDATE_INTERVAL) {
                                    previousMillis = currentMillis;
                                    readDHT();
                                    read1Wire();
                                • mimaretM mimaret
                                    DoorChange = 1;
                                    LastDoor = 0;
                                  void DoorMoving() {
                                      DoorChange = 1;
                                  void readDoor() {
                                    if (DoorChange) {
                                        LastDoor = Door;
                                        DoorChange = 0;
                                    readDoor();
                                      readDHT();
                                      read1Wire();
                                  @mimaret great work! Thanks for posting your solution.
