  3. Need a recommendation for 1/2 AA batteries
5 Posts 3 Posters 1.8k Views 4 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    Hi
    I have purchased TADIRAN TL-5902 1/2AA batteries, but my Z-wave sensor is eating them for breakfast. The original battery lasted more than a year. Each Tadiran lasts about 1-2 months. Very poor result
    Anyone dealt with good quality 1/2 AA batteries? Where do you buy them please?
      Get some LiFePo4, like the kit from soshine (4 batteries + 2 connectors)
      alexsh1A 1 Reply Last reply
        alexsh1A
        alexsh1A
        alexsh1
        @gohan I have a sensor like this
        https://www.vesternet.com/z-wave-fibaro-universal-door-window-sensor-gen5
        Tue battery 1/2 AA is inside and I cannot fit in other batteries as the space is limited.
        FYG - I did place an order a month ago for Soshine LiFeSo4 batteries and they are still in a snail mail. All sensors can powered directly from them.
        • J
          J
          Johhnywalter
          wrote on last edited by Johhnywalter
          Hello, has anyone here used LiFePO4 batteries to power MySensors nodes ?
          The look really interesting for low power nodes in 10440 format :
          low capacity compared to li-ion but somewhere between 200 and 280mAh which is ample for over a year
          low self discharge which allows to survive the full year
          maximum voltagehttp://jonsguide.org/best-laser-measure-reviews/#bosch-compact-laser-distance-measure-120-feet-glm-35 below the NRF24 max so no need for a regulator with measure!
          minimum voltage around 2V but with a light load if I believe the discharge curves I see over 90% of the capacity is available with a voltage over 2.7V meaning most of the capacity can be used without changing the bootloader and BOD.
          As it's a bit rare and expensive (at least for sellers offering delivery in my country 😞 ) and it needs a special charger I would like to have some feedback from people who are using some.
          Thank you for reading 🙂
            I'm using them, I got the ones from soshine and the stated capacity is just a little more than the one measured by the charger.
