  3. SSR 3-way relay suggestion
11 Posts 4 Posters 3.0k Views 3 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    Can anyone suggest ONE SSR 3-way relay? I need to "MySensorise" a fan in the bathroom and it is isolated, i.e. 3 different wires are switched on/off (L, N and other one, I guess a load (black colour)). I do not want to waist three different relays - I have a few 25-50A Croydom SSRs.
    Load - 10-15A and 240V AC.
    Input - 3V DC (to be managed by a node)
    So it must be DC controlled
    EDIT: I am replacing isolator fan switch in this diagram:
    skywatchS 1 Reply Last reply
    • alexsh1A alexsh1
      skywatchS
      skywatchS
      skywatch
      @alexsh1 You should not replace the isolator.
      The isolator is there to enable disconnection of all power for service/cleaning/replacement/emergency disconnect. Also your labeling of the light switch is wrong. Com is actually Live and L1 should be SL. There is no common or neutral wire in a light switch.
      At the moment, the light switch controls whether the fan is on or off. There is also the permanent live and neutral connections to the fan so I expect the fan has a time delay built in so that it continues working for a while after the light is switched off.
      To control the fan independently of the light switch you simply need to connect a relay in the line from the fan isolator output L1 and input SL on the fan (SL = Switched Live).
      You only need a single pole relay/switch or triac to do this.
      alexsh1A 1 Reply Last reply
      • alowhumA
        alowhumA
        alowhum
        In the bathroom you would probably want to use a solid state relay.
        skywatchS alexsh1A 2 Replies Last reply
        • alowhumA alowhum
          skywatchS
          skywatchS
          skywatch
          @alexsh1
          Also, you don't need a 15A relay for this. I doubt it will draw more than about 8-16W it is a reccent low noise fan, or 20-30W if it is older design. Just remember that the inrush current at start will be higher, but a 3A relay should be more than enough. If you take the fan down you may well find a relay inside attached to the timer circuit, that will give you more info on what you need.
          As alowhum implied, do not use an open relay in a huhmid area, the contacts will corrode. A hermetically sealed mechanical relay will do the job, but a SSR will do just as well and with no 'click' noise when it switches as a bonus.
          I hope I have helped clarify how this works now, but if you have any doubt, consult a qualified electrician in your country and follow the 18th edition regulations on wiring as a minimum. Also consider if DIY work on this will void your insurance in the event of a fire caused by the modification you intend? Be safe!
          • skywatchS skywatch
            alexsh1A
            alexsh1A
            alexsh1
            @skywatch Thank you for an excellent answer. Well, if I have a proper SSR replay, it would work exactly the same way as the isolator switch, right?
            The diagram was taken from the internet. Sorry - I just did not bother to draw mine.
            Yes, you are correct, there is a 30 secs or so time delay on the fan.
            You see building regulations in the UK are not clear about to isolator switch. They refer to the fan manufacturers. And these guys always suggest the to install the isolator switch.
            The relay will not be installed in the bathroom. It will be installed outside where the isolator switch is based (just outside the bathroom). Given that I have a new furniture - shelving units, which is not obstructing the isolator switch, the idea is to replace it with the SSR. Otherwise, it will be permanently obstructed and I won't be able to switch the fan on/off.
            • alowhumA alowhum
              alexsh1A
              alexsh1A
              alexsh1
              @alowhum The location is not in the bathroom. It is outside the bathroom. above the door leading to the bathroom. However, my idea is to use the SSR from the beginning.
              • alexsh1A alexsh1
                zboblamontZ
                zboblamontZ
                zboblamont
                wrote on last edited by zboblamont
                @alexsh1 This is not a BAD idea, just bordering on Darwin Award territory - This is a safety isolator not a switch, it is outside the bathroom to comply with Regulations such that it KILLS everything by someone flicking the switch should anything electrical go wrong, such as you dancing in the shower with an electric fire on an extension lead to feel warmer, and your partner hears your screams from the Lounge, or perhaps smells the distinct odour of burning hair.
                Personally I prefer the cord actuated switched hanging from the ceiling, the chances of pulling that in the agony of spasms from electrocution is infinitely greater than reaching the door, in turn much more likely than getting hold of, operating, and select appropriate icons on the mobile to stop the agony...
                Maybe trial it, if we don't hear further, it probably didn't work... ;)
                • zboblamontZ zboblamont
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @zboblamont said in SSR 3-way relay suggestion:
                  BAD
                  the isolation switch is purely for isolating the fan for maintenance purposes if it is fed from a lighting circuit. That's it.
                  BS7671 (Building Regulations in the UK) says nothing about it. Ultimately, it comes down to a fan manufacturer, a property developer or an electrician to install the isolator.
                  Cord switches? You are too old-fashioned!
                  • alexsh1A alexsh1
                    BAD
                    zboblamontZ
                    zboblamontZ
                    zboblamont
                    @alexsh1 I think you missed the point, the isolator is there permanently, your remote control isn't. ;)
                    These isolators arose in the 60s (1960s before you ask) under the Electrical Regs when fans were found to occasionally go on fire and/or fall out with exposed wires, the pull-cord ceiling light switches go back to the 1950s for bathroom lights and went on to be used for bathroom fan isolators. It is intended as a kill switch not a maintenance switch.
                    Controlling a bathroom light switch or a fan remotely is your choice, a single relay will do fine for either, but removing the safeties is a bit pointless.
                      skywatchS
                      skywatchS
                      skywatch
                      This post is deleted!
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @zboblamont I think the safety point is highly debatable these days. I can see why the isolators were installed in the 60s, but with modern bathroom fans, this is an obsolete. As I pointed out, it is not required to be installed by the Building Regulations (at least in the UK). Anyway, back to the topic, I'll have to check but I am sure the relay has to be placed behind the isolator socket box. The isolator itself will be buried behind a shelving unit
