💬 EFEKTA nRF5 Motion sensor
@berkseo
nice board
Just a note, in case it could improve your board performance
In datasheet, if you take a look in section 53-4&5, you'll find some infos about the rf path, also on nordic's forums.- it's not really recommended to change layout on rf output, especially close to the mcu the keepout area and inductor+capa, and how it's connected to gnd, else you may get some harmonics.
- coplanar waveguide for impedance matching feedline
then you can add footprints close to antenna, for tuning, in case. cut antenna length etc.
of course better to do this tuning in final setup (enclosed).might improve rf
hope this helps. keep the good work.
@scalz Thanks for your support and tips(this is really important)!!! I tried to calculate everything by RF part(as far as possible). In the prototype version (homemade Board, see the video), there were made special places for additional capacitors, later after the tests I refused them. I paid attention to everything that is recommended to pay attention in the Datasheet. This also applies to paragraphs 53 4 & 5( in my case 53 1). Working tests continue, this is the first revision of the Board, perhaps this will be added in the future - - https://www.johansontechnology.com/datasheets/2450FM07A0035/2450FM07A0035.pdf
MySensors | nRF52832 Motion sensor | first software test – 01:00
— Andrew EfektaSB
@berkseo
cool. if it helps, I'm gladOn your homemade proto pcb, you didn't have gnd plane I guess, so you can't really compare with your board from fabhouse. board layout change antenna tuning for example.
I meant, on your board, rf routing is not great. not sure if your feedline is 50ohms (route seems thin vs 2layer board and coplanar waveguide).
for rf, devil is in details, just saying, if you plan to sell your boards, even nrf5 hasn't the best range so a pity to not get best perfBelow a pic from datasheet, about the layout and , rf pin/inductor/capacitor placement.
there is a keepout area. how capa gnd is connected. so the values for the inductor and capa. with different layout and no tuning->harmonics etc.
Great project!
Have you released software for the board?
Are there pins on the board to flash the uC?[ ],
Renato.
@renatocan said in
EFEKTA nRF5 Motion sensor:
Great project!
Renato.
Added test sketch with adjustable delay of response time - https://www.openhardware.io/view/642#tabs-source
Programmable through an adapter, it always comes with the device(a little different SWD + RX TX) - https://www.openhardware.io/view/588/ICSPandFTDI-Adapter
Thank you very much @berkseo. Can you release the schematics and PCB layout files? I am working on a workspace analytics application in which I have to monitor several office desks to log utilization. I've already deployed a poc using mysensors hardware assembled using jump wires. Now we're looking for a more robust implementation and I think your project may be a great solution. Do you have resources related to this project published somewhere else? Or are you just using Openhardware.io?
Renato.
Can you tell something about the range of this node?
And do you see a chance to post the schematic?
Multisensor
OpenHardware.io • 28 Mar 2016, 18:31 • openhardware.io 23 Apr 2016, 14:56 -
Motion Sensor
Hardware • 6 Oct 2014, 00:07 • BulldogLowell 7 Oct 2014, 01:10 -
💬 Utilipi Mini
OpenHardware.io • 12 Aug 2019, 08:05 • openhardware.io 12 Aug 2019, 08:05 -
💬 MySXMotion
OpenHardware.io • 24 Jul 2018, 19:51 • openhardware.io 24 Jul 2018, 19:51 -
💬 Wireless Module for Capacitive Soil Moisture Sensor v1.2
OpenHardware.io • 18 Jul 2019, 17:30 • openhardware.io 26 Oct 2019, 10:19 -
PIR motion sensor that sends cloud notifications via wifi
Development • 25 Nov 2014, 07:52 • vekraman76 25 Nov 2014, 09:27 -
💬 E73-2G4M04S Breakout
OpenHardware.io • 29 May 2018, 19:59 • openhardware.io 9 Jun 2019, 20:34 -
💬 Mini weather station with e-ink 2.9 Inch
OpenHardware.io • 30 Oct 2020, 15:26 • openhardware.io 8 Jul 2021, 11:36
