  3. Battery powered sensor - low voltage threshold
16 Posts 6 Posters 7.5k Views 2 Watching
  • sundberg84S
    sundberg84S
    Hi!
    I would recommend this: http://forum.mysensors.org/topic/486/my-2aa-battery-sensor
    As @scalz mentioned a step up / booster and this os working great for me! I have a node running for a year now.
    boanjoB 1 Reply Last reply
      A1: A 100% busy sensor on batteries is not feasible, as you've noticed. Most sensors can sleep more than 99% av their time, using timer and/or interrupts, reaching 1-2 years on 2xAA. There are many threads on battery power.
      A2: I have mapped 0% to 2.8V. You can go as low as 1.6V (limit for the NRF) if you downclock the Arduino and change the fuses. How to do this is discussed in several threads.
      You might want to start reading the section on battery power. It has links to several forum threads as well.
      boanjoB
      boanjoB
      boanjo
      @mfalkvidd
      Q&A1: Yes, the 100% was just to test. I have built many sensors before using Gammons low power techniques (like this one https://github.com/epkboan/rain_sensor) , but then i've used 3xAA and 5V chips an then there has been more "headroom" for the votage drop. But yes they are still running after 1 year and reporting every 50 second. I would like that kind of frequent updates (at least for some sensor types)
      Q&A2: Ok, thanks for the downclock trick! So you think that is the problem why it stops at 2.8V?
      • sundberg84S sundberg84
        Hi!
        boanjoB
        boanjoB
        boanjo
        @sundberg84 Ah, thanks for that link! I thought i had read most of the MySensors page but apparently not.
        @scalz Great! I have just assumed that these step-up solutions will put a penalty on the power consumption that would be unacceptable (similar to voltage regulators). Thanks for clearing that out.
        • boanjoB boanjo
          @mfalkvidd
          No, it is more likely the brown-out detection unless you have changed the fuses.
            boanjoB
            boanjoB
            boanjo
            @mfalkvidd Tnx, now things start to fall into place! When reading through the forum etc i kind of get the feeling that everyone is running for long times more or less out of the box. But there is no magic - you still need to pay attention to the nitty gritty stuff.
            • rvendrameR
              rvendrameR
              rvendrame
              @epkboan , @scalz I'm currently evaluating a 5V step up to power up a PH sensor, with 2x AA batteries.
              Not sure if my multimeter is fine but I'm reading ~3mA consumption with just the step up connected (just the batteries and step up, nothing else).
              Isn't too much? My step up is the one from mySensor store link...
              ESP8266 GW + mySensors 2.3.2
              Alexa / Google Home
              • mfalkviddM
                AA batteries give you approximately 2,000mAh. 2,000/3=667 hours = 28 days
                So you'll get a maximum of 28 days battery life. You'll need a step-up that is more efficient at low power, or shut off the step-up when the PH sensor isn't used.
                rvendrameR 1 Reply Last reply
                  yep, sorry you are right. I have not all detailed. Some points good to know, I can't explain everything (will do when I will update my work, but I am very busy for the moment):
                  • one thing to know for low power, on hardware side, is each thing you add must be carefully thought/choosen or it can break all your low power efforts.
                  • I think booster eval boards are not the best for low power. It is not designed for this purpose. And you have not lot of chips choice.
                  • Stepup are often better than ldo of course, but it needs some care too. That you can "only" manage by making your pcb board unfortunately.
                  In my case, on "mytinycamel" I am using a stepup which is enough efficient. But it is all a story and is much more telemetry dedicated (sleeping mode active, hardware watchdog, cut off powerrails...). It works very well. But it can't handle light load as it is based on capacitor discharge (hardware watchdog concept) or I would have to add capa or bigger. not an allinone idea..
                  So I needed something high efficient for light or very light loads (few uA) like pirs or others when you don't poweroff everything...And it's another story ! Because, switching regs are not all high efficient equivalent, especially in very light loads and low batt voltage (battery end of life). In these case, lots of switching regs are at 50-60% efficiency!! If you add the quiescent current needed to maintain the output voltage, power consumption can double or triple !! There is a formula to evaluate the quiescent current of the circuit at input vs efficiency...I can give you if you want..Yep, we can't take all datasheets and sum quiescent current and then conclude it will be our power consumption. Not as easy unfortunately.
                  So, for these case, I have designed another board. Because it needds to carefully choose booster, and circuit electronic. And to have the best, the switching reg is not handsolderable at all! it is very tiny. And then, it needs to carefully design the board. because if booster not well designed you won't have the best efficiency and power output. I learned lots of things on this stuff these last months..it was very interesting but geeky!
                  Hope it can help a little. I can't detail everything. I have seen lots of others very interesting low power tricks. but these are better suited to arm mcu+BLE (shorter and lower power communication mechanism, better io management, and power domains too) than mysensors or rfm69 (30-40mA tx) which I prefer. No matter, I think it will be enough to me, I want to stick with Mysensors! I am not doing a low power contest lol even it could be fun! 2-3 years min on light loads with 1AA or 2xAAA is enough for me (of course it depends a lot on sketch too).
                    rvendrameR
                    rvendrameR
                    rvendrame
                    Yes, I tried to put a transistor (the only I had was a BC549) to switch the step up, however it did not work. The step up doesn't turn ON, when I have the PH sensor connected. It does work with smaller load (a DHT11 for example). The PH sensor consumes about 25mA.
                    Maybe the poor BC549 is not powerful/fast enough for the step up? I will buy some 2N2222 just in case . Any comments?
                    Alexa / Google Home
                      I don't know your schematic. But I would prefer mosfet...
                      Stepup don't need lot of power for enable pin. it is a much more a signal pin.
                      Another killer battery life : primary battery (lithium I am sure, I think alkaline too) does not like heavy load > 5mA. It speeds up discharge.
                      • scalzS scalz
                        rvendrameR
                        rvendrameR
                        rvendrame
                        The step up I have doesn't have 'enable pin'. Only input +/- and a USB output. So I connected the BC549 between GND and "IN -" , with its base connected to arduino D4 via 10K resistor. IN+ is connected directly to battery.
                        Alexa / Google Home
                        • scalzS scalz
                          hi.
                          and you can use step-up (switching reg) to be able to discharge completely your battery (you can go as low as 0.65v but of course you won't have 100mA available at 0.65v, maybe 30-40mA). And like this you will have constant 3.3v for radio...and everything during the whole battery life.
                          m26872M
                          m26872M
                          m26872
                          @scalz said:
                          hi.
                          I would recommend to NOT use a common 3.3V step-up for the nRF24L01+. Any kind of switching supply seems to impair its performance, despite the usual filtering. nRF supplied with 1.9V and lower works great with 3.3V on Arduino Vcc. And the nRF loves the supply from the batteries. Just bypass the step-up and supply the nRF straight from the batteries. The rest will probably be fine with 3.3V.
                            @m26872: on my side I had no trouble with nrf. maybe lucky. but you are right because I don't use common stepup, nor eval boards or I make it for test. But, there are lot of cool low noise stepup.
                            I have not tested this, and I am very curious, I don't know if nrf/rfm range would be the same at 1.9v vs 3.3v ? btw, for range, I prefer to use rfm69 for my setup, so consumption is not the same! (my dream would be to use cc1310 but have no time to invest, I have not much time actually to play with my devices...)
                            But I see what you mean, simplicity too, I totally agree ;)
