  3. CE line on sensor node?
29 Posts 6 Posters 10.5k Views 1 Watching
  • aquaproA
    aquaproA
    aquapro
    I have tested 1000 times, wasted complete weekend. Rechecked with built up the wiring from scratch. Same Problem.
    Suppose I have swap the cables, which I doubt, why it works when I disconnect it completely?
    • YveauxY
      Can you check with a different radio and/or Arduino?
      • aquaproA
        aquaproA
        aquapro
        Yes, checked with 5 Arduinos (all different vendor's) and 8 radios. Same Problem. I am totally confused.
        RJ_MakeR 1 Reply Last reply
        • aquaproA aquapro
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @aquapro
          Have you tried all new wiring?
          RJ_Make
            If you show a few pictures also (closeups!) it might help.
            • aquaproA
              aquaproA
              aquapro
              If I disconnect orange wire (red marker on first sensor picture), sensor works fine.
              Sensor figures:
              Gateway figures:
              RJ_MakeR YveauxY 2 Replies Last reply
              • aquaproA aquapro
                Sensor figures:
                Gateway figures:
                RJ_MakeR
                RJ_MakeR
                RJ_Make
                @aquapro
                I think I would connected the radio directly to the breadboard pins next to the Arduino with new wiring.
                RJ_Make
                • aquaproA
                  aquaproA
                  aquapro
                  @aquapro sagte:> Hi,
                  I have all the cables replaced, also new from different suppliers. I used the next pins on the Arduino. For the pictures I have to build something stretched to better overview.
                  • aquaproA aquapro
                    RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    @aquapro
                    So the pictures don't reflect the current wiring?
                    RJ_Make
                    • aquaproA
                      aquaproA
                      aquapro
                      Pictures reflect the curren?t wiring! Same Problem with closer wiring
                      • aquaproA aquapro
                        Sensor figures:
                        Gateway figures:
                        @aquapro The MySensors site (http://www.mysensors.org/build/connect_radio) gives the following wiring:
                        Arduino     nRF24
                        9           CE
                        10          CSN
                        13          SCK
                        11          MOSI
                        12          MISO
                        2           IRQ
                        These are the defaults for the library. CE & CSN you can adapt through the constructor of MySensor (did you do that?)
                        Looking at the pictures I have a hard time figuring out the connections for pins 8..12, while these are just the interesting part...
                        aquaproA 2 Replies Last reply
                        • aquaproA aquapro
                          hello,
                          very good project!
                          I currently testing version 1.4b1 and I have a problem. Only if I disconnect the CE line on the sensor, the values ​​are transferred.
                          If the CE line is connected, only one part will be sent, see Figure 1, the LED on the sensor remains on. As soon as I disconnect CE line, all values ​​are not sent are transmitted (Figure 2) and the LED goes out and lights up briefly in the next transmission.
                          Does anyone have an idea?
                          greeting
                          aqua
                          Figure1
                          Figure 2
                          DammeD
                          DammeD
                          Damme
                          Code Contributor
                          wrote on last edited by Damme
                          @aquapro Hmmmm
                          The chip on your looks like a blob more than this; You might have gotten a chinese ripoff .. I dont remember the chip name... Hmmmm hard to see!
                          edit:
                          maybe : http://forum.mysensors.org/topic/300/rfm73-experience/ ?
                          inverted CE?
                          YveauxY RJ_MakeR 2 Replies Last reply
                          • DammeD Damme
                            @aquapro Hmmmm
                            edit:
                            inverted CE?
                            @Damme Sharp observation, dude!
                            Have a look at these: http://www.aliexpress.com/item/Free-shipping-10pcs-lot-NRF24L01-wireless-data-transmission-module-NRF24L01-wireless-module/1996222121.html
                            Claimed to be nRF24L01+!!
                            • DammeD Damme
                              @aquapro Hmmmm
                              edit:
                              inverted CE?
                              RJ_MakeR
                              RJ_MakeR
                              RJ_Make
                              @Damme
                              Nice Catch Indeed!
                              RJ_Make
                              • YveauxY Yveaux
                                Arduino     nRF24
                                9           CE
                                10          CSN
                                13          SCK
                                11          MOSI
                                12          MISO
                                2           IRQ
                                aquaproA
                                aquaproA
                                aquapro
                                wrote on last edited by aquapro
                                @Yveaux yes I checked wiring with (http://www.mysensors.org/build/connect_radio)
                                more detail picture, hope so. (bad light)
                                @Damme
                                Chip is covered.
                                • YveauxY Yveaux
                                  Arduino     nRF24
                                  9           CE
                                  10          CSN
                                  13          SCK
                                  11          MOSI
                                  12          MISO
                                  2           IRQ
                                  aquaproA
                                  aquaproA
                                  aquapro
                                  @Yveaux
                                  Pin 8?
                                  YveauxY DammeD 2 Replies Last reply
                                  • aquaproA aquapro
                                    @Yveaux
                                    Pin 8?
                                    @aquapro said:
                                    Pin 8?
                                    It looked like you could have a connection to pin 8, but apparently (in the better pictures) you haven't...
                                    • aquaproA aquapro
                                      @Yveaux
                                      Pin 8?
                                      DammeD
                                      DammeD
                                      Damme
                                      Code Contributor
                                      @aquapro I dont think you got a nordic semiconductor nrf24l01, What I can find they are only in QFN package.
                                      http://www.nordicsemi.com/eng/Products/2.4GHz-RF/nRF24L01
                                      So the specs on that chip may be different. Maybe CE is inverted?
                                      • aquaproA
                                        aquaproA
                                        aquapro
                                        hm ... if CE inverted, ping sample should not work?! CE must switch between hight and low for TX and RX right? But Ping sample send and receive works.
                                        • aquaproA
                                          aquaproA
                                          aquapro
                                          I have bought the new modules (right on pic), which operate without modification. I simply swapped and all is fine.
                                          What do I do with the other. How can I test inverted.
                                          hekH 1 Reply Last reply
