  3. CE line on sensor node?
29 Posts 6 Posters 10.4k Views 1 Watching
  • YveauxY
    Can you check with a different radio and/or Arduino?
    • aquaproA
      aquaproA
      aquapro
      Yes, checked with 5 Arduinos (all different vendor's) and 8 radios. Same Problem. I am totally confused.
      RJ_MakeR 1 Reply Last reply
      • aquaproA aquapro
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @aquapro
        Have you tried all new wiring?
        RJ_Make
          If you show a few pictures also (closeups!) it might help.
          • aquaproA
            aquaproA
            aquapro
            If I disconnect orange wire (red marker on first sensor picture), sensor works fine.
            Sensor figures:
            Gateway figures:
            RJ_MakeR YveauxY 2 Replies Last reply
            • aquaproA aquapro
              Sensor figures:
              Gateway figures:
              RJ_MakeR
              RJ_MakeR
              RJ_Make
              @aquapro
              I think I would connected the radio directly to the breadboard pins next to the Arduino with new wiring.
              RJ_Make
              • aquaproA
                aquaproA
                aquapro
                @aquapro sagte:> Hi,
                I have tested 1000 times, wasted complete weekend. Rechecked with built up the wiring from scratch. Same Problem.
                Suppose I have swap the cables, which I doubt, why it works when I disconnect it completely?
                I have all the cables replaced, also new from different suppliers. I used the next pins on the Arduino. For the pictures I have to build something stretched to better overview.
                • aquaproA aquapro
                  RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  @aquapro
                  So the pictures don't reflect the current wiring?
                  RJ_Make
                  • aquaproA
                    aquaproA
                    aquapro
                    Pictures reflect the curren?t wiring! Same Problem with closer wiring
                    • aquaproA aquapro
                      Sensor figures:
                      Gateway figures:
                      @aquapro The MySensors site (http://www.mysensors.org/build/connect_radio) gives the following wiring:
                      Arduino     nRF24
                      9           CE
                      10          CSN
                      13          SCK
                      11          MOSI
                      12          MISO
                      2           IRQ
                      These are the defaults for the library. CE & CSN you can adapt through the constructor of MySensor (did you do that?)
                      Looking at the pictures I have a hard time figuring out the connections for pins 8..12, while these are just the interesting part...
                      aquaproA 2 Replies Last reply
                      • aquaproA aquapro
                        hello,
                        very good project!
                        I currently testing version 1.4b1 and I have a problem. Only if I disconnect the CE line on the sensor, the values ​​are transferred.
                        If the CE line is connected, only one part will be sent, see Figure 1, the LED on the sensor remains on. As soon as I disconnect CE line, all values ​​are not sent are transmitted (Figure 2) and the LED goes out and lights up briefly in the next transmission.
                        Does anyone have an idea?
                        greeting
                        aqua
                        Figure1
                        Figure 2
                        DammeD
                        DammeD
                        Damme
                        Code Contributor
                        wrote on last edited by Damme
                        @aquapro Hmmmm
                        The chip on your looks like a blob more than this; You might have gotten a chinese ripoff .. I dont remember the chip name... Hmmmm hard to see!
                        edit:
                        maybe : http://forum.mysensors.org/topic/300/rfm73-experience/ ?
                        inverted CE?
                        YveauxY RJ_MakeR 2 Replies Last reply
                        • DammeD Damme
                          @aquapro Hmmmm
                          edit:
                          inverted CE?
                          @Damme Sharp observation, dude!
                          Have a look at these: http://www.aliexpress.com/item/Free-shipping-10pcs-lot-NRF24L01-wireless-data-transmission-module-NRF24L01-wireless-module/1996222121.html
                          Claimed to be nRF24L01+!!
                          • DammeD Damme
                            @aquapro Hmmmm
                            edit:
                            inverted CE?
                            RJ_MakeR
                            RJ_MakeR
                            RJ_Make
                            @Damme
                            Nice Catch Indeed!
                            RJ_Make
                            • YveauxY Yveaux
                              Arduino     nRF24
                              9           CE
                              10          CSN
                              13          SCK
                              11          MOSI
                              12          MISO
                              2           IRQ
                              aquaproA
                              aquaproA
                              aquapro
                              wrote on last edited by aquapro
                              @Yveaux yes I checked wiring with (http://www.mysensors.org/build/connect_radio)
                              more detail picture, hope so. (bad light)
                              @Damme
                              Chip is covered.
                              • YveauxY Yveaux
                                Arduino     nRF24
                                9           CE
                                10          CSN
                                13          SCK
                                11          MOSI
                                12          MISO
                                2           IRQ
                                aquaproA
                                aquaproA
                                aquapro
                                @Yveaux
                                Pin 8?
                                YveauxY DammeD 2 Replies Last reply
                                • aquaproA aquapro
                                  @Yveaux
                                  Pin 8?
                                  @aquapro said:
                                  Pin 8?
                                  It looked like you could have a connection to pin 8, but apparently (in the better pictures) you haven't...
                                  • aquaproA aquapro
                                    @Yveaux
                                    Pin 8?
                                    DammeD
                                    DammeD
                                    Damme
                                    Code Contributor
                                    @aquapro I dont think you got a nordic semiconductor nrf24l01, What I can find they are only in QFN package.
                                    http://www.nordicsemi.com/eng/Products/2.4GHz-RF/nRF24L01
                                    So the specs on that chip may be different. Maybe CE is inverted?
                                    • aquaproA
                                      aquaproA
                                      aquapro
                                      hm ... if CE inverted, ping sample should not work?! CE must switch between hight and low for TX and RX right? But Ping sample send and receive works.
                                      • aquaproA
                                        aquaproA
                                        aquapro
                                        I have bought the new modules (right on pic), which operate without modification. I simply swapped and all is fine.
                                        What do I do with the other. How can I test inverted.
                                        hekH 1 Reply Last reply
                                        • aquaproA aquapro
                                          @aquapro
                                          I hope you didn't get the left one when purchasing through the links in the MySensors "store"?
