  3. CE line on sensor node?
29 Posts 6 Posters 10.5k Views 1 Watching
  • YveauxY
    Did you check-double-check the connections? You didn't swap e.g. the CE/CSN pins by mistake?
    • aquaproA
      aquaproA
      aquapro
      I have tested 1000 times, wasted complete weekend. Rechecked with built up the wiring from scratch. Same Problem.
      Suppose I have swap the cables, which I doubt, why it works when I disconnect it completely?
      • YveauxY
        Can you check with a different radio and/or Arduino?
        • aquaproA
          aquaproA
          aquapro
          Yes, checked with 5 Arduinos (all different vendor's) and 8 radios. Same Problem. I am totally confused.
          RJ_MakeR 1 Reply Last reply
          • aquaproA aquapro
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @aquapro
            Have you tried all new wiring?
            RJ_Make
              If you show a few pictures also (closeups!) it might help.
              • aquaproA
                aquaproA
                aquapro
                If I disconnect orange wire (red marker on first sensor picture), sensor works fine.
                Sensor figures:
                Gateway figures:
                RJ_MakeR YveauxY 2 Replies Last reply
                • aquaproA aquapro
                  Sensor figures:
                  Gateway figures:
                  RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  @aquapro
                  I think I would connected the radio directly to the breadboard pins next to the Arduino with new wiring.
                  RJ_Make
                  • aquaproA
                    aquaproA
                    aquapro
                    @aquapro sagte:> Hi,
                    I have all the cables replaced, also new from different suppliers. I used the next pins on the Arduino. For the pictures I have to build something stretched to better overview.
                    • aquaproA aquapro
                      RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      @aquapro
                      So the pictures don't reflect the current wiring?
                      RJ_Make
                      • aquaproA
                        aquaproA
                        aquapro
                        Pictures reflect the curren?t wiring! Same Problem with closer wiring
                        • aquaproA aquapro
                          Sensor figures:
                          Gateway figures:
                          @aquapro The MySensors site (http://www.mysensors.org/build/connect_radio) gives the following wiring:
                          Arduino     nRF24
                          9           CE
                          10          CSN
                          13          SCK
                          11          MOSI
                          12          MISO
                          2           IRQ
                          These are the defaults for the library. CE & CSN you can adapt through the constructor of MySensor (did you do that?)
                          Looking at the pictures I have a hard time figuring out the connections for pins 8..12, while these are just the interesting part...
                          aquaproA 2 Replies Last reply
                          • aquaproA aquapro
                            hello,
                            very good project!
                            I currently testing version 1.4b1 and I have a problem. Only if I disconnect the CE line on the sensor, the values ​​are transferred.
                            If the CE line is connected, only one part will be sent, see Figure 1, the LED on the sensor remains on. As soon as I disconnect CE line, all values ​​are not sent are transmitted (Figure 2) and the LED goes out and lights up briefly in the next transmission.
                            Does anyone have an idea?
                            greeting
                            aqua
                            Figure1
                            Figure 2
                            DammeD
                            DammeD
                            Damme
                            Code Contributor
                            wrote on last edited by Damme
                            @aquapro Hmmmm
                            The chip on your looks like a blob more than this; You might have gotten a chinese ripoff .. I dont remember the chip name... Hmmmm hard to see!
                            edit:
                            maybe : http://forum.mysensors.org/topic/300/rfm73-experience/ ?
                            inverted CE?
                            YveauxY RJ_MakeR 2 Replies Last reply
                            • DammeD Damme
                              @aquapro Hmmmm
                              edit:
                              inverted CE?
                              @Damme Sharp observation, dude!
                              Have a look at these: http://www.aliexpress.com/item/Free-shipping-10pcs-lot-NRF24L01-wireless-data-transmission-module-NRF24L01-wireless-module/1996222121.html
                              Claimed to be nRF24L01+!!
                              • DammeD Damme
                                @aquapro Hmmmm
                                edit:
                                inverted CE?
                                RJ_MakeR
                                RJ_MakeR
                                RJ_Make
                                @Damme
                                Nice Catch Indeed!
                                RJ_Make
                                • YveauxY Yveaux
                                  Arduino     nRF24
                                  9           CE
                                  10          CSN
                                  13          SCK
                                  11          MOSI
                                  12          MISO
                                  2           IRQ
                                  aquaproA
                                  aquaproA
                                  aquapro
                                  wrote on last edited by aquapro
                                  @Yveaux yes I checked wiring with (http://www.mysensors.org/build/connect_radio)
                                  more detail picture, hope so. (bad light)
                                  @Damme
                                  Chip is covered.
                                  • YveauxY Yveaux
                                    Arduino     nRF24
                                    9           CE
                                    10          CSN
                                    13          SCK
                                    11          MOSI
                                    12          MISO
                                    2           IRQ
                                    aquaproA
                                    aquaproA
                                    aquapro
                                    @Yveaux
                                    Pin 8?
                                    YveauxY DammeD 2 Replies Last reply
                                    • aquaproA aquapro
                                      @Yveaux
                                      Pin 8?
                                      @aquapro said:
                                      Pin 8?
                                      It looked like you could have a connection to pin 8, but apparently (in the better pictures) you haven't...
                                      • aquaproA aquapro
                                        @Yveaux
                                        Pin 8?
                                        DammeD
                                        DammeD
                                        Damme
                                        Code Contributor
                                        @aquapro I dont think you got a nordic semiconductor nrf24l01, What I can find they are only in QFN package.
                                        http://www.nordicsemi.com/eng/Products/2.4GHz-RF/nRF24L01
                                        So the specs on that chip may be different. Maybe CE is inverted?
                                        • aquaproA
                                          aquaproA
                                          aquapro
                                          hm ... if CE inverted, ping sample should not work?! CE must switch between hight and low for TX and RX right? But Ping sample send and receive works.
