  3. ISR not in IRAM error
12 Posts 5 Posters 2.8k Views 5 Watching
  • AdamAntA
    AdamAntA
    AdamAnt
    wrote on last edited by AdamAnt
    I'm trying to setup an ESP8266 (bare ESP-12E) based gateway using the RFM69 radio module.
    However when I start the gateway, I get the error message ISR not in IRAM
    I'm using mysensors 2.3.1, with versio 2.5.2 of the ESP8266 board library.
    I'm wiring it up to an RFM69W exactly as in the wiring diagram on the Connecting the Radio page, with the exception of NSS being connected to pin 5 not 15.
    The power supply I'm using has more than enough headroom, its a bench supply and shows about 60mA pulled at startup.
    My gateway sketch & serial output is below.
    Any ideas greatly appreciated!!
    SDK:2.2.1(cfd48f3)/Core:2.5.2=20502000/lwIP:STABLE-2_1_2_RELEASE/glue:1.1-7-g82abda3/BearSSL:a143020
    53 MCO:BGN:INIT GW,CP=RRNGE---,REL=255,VER=2.3.1
    211 TSF:LRT:OK
    226 TSM:INIT
    240 TSF:WUR:MS=0
    ISR not in IRAM!
    Abort called
    >>>stack>>>
    ctx: cont
    sp: 3ffffd00 end: 3fffffd0 offset: 01b0
    3ffffeb0:  00000000 00000000 4bc6a7f0 00000000
    3ffffec0:  00000000 00000080 40100246 00000031
    3ffffed0:  00000000 00000105 3ffee590 4010054e
    3ffffee0:  00000000 00000105 3ffee590 40202e6d
    3ffffef0:  00020401 40040203 33060305 0008d907
    3fffff00:  42190009 07264025 dc291028 2d2f882e
    3fffff10:  90376430 8f3c4238 306f123d 400000ff
    3fffff20:  00000064 00000246 00000246 40208120
    3fffff30:  00000000 4bc6a7f0 000000f0 00000102
    3fffff40:  3ffee578 3ffee41f 00000000 40202ef0
    3fffff50:  00000000 00000000 4bc6a7f0 40202f13
    3fffff60:  00000000 00000000 00000000 40201db5
    3fffff70:  00000000 00a7fd40 00000000 4020363d
    3fffff80:  3ffee578 3ffee41f 00000000 4020368b
    3fffff90:  600002ff 00020000 3ffee578 3ffee3c8
    3fffffa0:  3fffdad0 3ffee41f 3ffee806 40203c45
    3fffffb0:  feefeffe 00000000 3ffee3c0 40203cac
    3fffffc0:  feefeffe feefeffe 3ffe8524 4010010d
    <<<stack<<<
    Repeats here ad infinium...
     * Version 1.0 - Henrik EKblad
     * Contribution by Ivo Pullens (ESP8266 support)
     * The EthernetGateway sends data received from sensors to the WiFi link.
     * VERA CONFIGURATION:
     * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
     * E.g. If you want to use the default values in this sketch enter: 192.168.178.66:5003
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
     * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
     * - ERR (red) - fast blink on error during transmission error or receive crc error
     * See https://www.mysensors.org/build/connect_radio for wiring instructions.
     * If you are using a "barebone" ESP8266, see
     * https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
     * Inclusion mode button:
     * - Connect GPIO5 (=D1) via switch to GND ('inclusion switch')
    #define MY_BAUD_RATE 9600
    // For RFM69
    #define MY_RADIO_RFM69
    //#define MY_RFM69_FREQUENCY RFM69_868MHZ // Set your frequency here
    #define MY_RFM69_IRQ_PIN 4
    #define MY_RFM69_IRQ_NUM MY_RFM69_IRQ_PIN
    #define MY_RFM69_CS_PIN 5 // NSS. Use MY_RFM69_SPI_CS for older versions (before 2.2.0)
    #define MY_GATEWAY_ESP8266
    #define MY_WIFI_SSID "<snip>"
    #define MY_WIFI_PASSWORD "<snip>"
    #define MY_PORT 5003
    #include <ESP8266WiFi.h>
    Edit:
    Below is a screenshot of my current upload options
    arduino upload opts
    YveauxY 1 Reply Last reply
    • AdamAntA AdamAnt
      211 TSF:LRT:OK
      226 TSM:INIT
      240 TSF:WUR:MS=0
      ISR not in IRAM!
      Abort called
      >>>stack>>>
      ctx: cont
      <<<stack<<<
       * LED purposes:
      // For RFM69
      Edit:
      arduino upload opts
      YveauxY
      YveauxY
      @adamant According to this post: https://community.blynk.cc/t/error-isr-not-in-iram/37426/15
      could you try the following:
      • For the old RFM69 driver (you seem to be using this one):
        Change the following line https://github.com/mysensors/MySensors/blob/development/hal/transport/RFM69/driver/old/RFM69_old.cpp#L464
        from
      void RFM69::isr0()
      to
      ICACHE_RAM_ATTR void RFM69::isr0()
      • For the new RFM69 driver (for reference):
        Change the following line https://github.com/mysensors/MySensors/blob/development/hal/transport/RFM69/driver/new/RFM69_new.cpp#L245
        from
      LOCAL void RFM69_interruptHandler(void)
      to
      ICACHE_RAM_ATTR void RFM69_interruptHandler(void)
      AdamAntA 1 Reply Last reply
      • YveauxY Yveaux
          from
        void RFM69::isr0()
        to
          from
        to
        AdamAntA
        AdamAntA
        AdamAnt
        @yveaux Hello, thanks so much for your help on this!
        Changing those functions has helped me get past the error, however I now have a different issue.
        Using the the same sketch and setup, on the old driver the gateway crashes with a Soft WDT reset shortly after it initializes the radio:
        50 MCO:BGN:INIT GW,CP=RRNGE---,REL=255,VER=2.3.1
        101 TSF:LRT:OK
        117 TSM:INIT
        131 TSF:WUR:MS=0
        156 TSM:INIT:TSP OK
        177 TSM:INIT:GW MODE
        199 TSM:READY:ID=0,PAR=0,DIS=0
        231 MCO:REG:NOT NEEDED
        scandone
        259 TSM:READY:NWD REQ
        Soft WDT reset
        >>>stack>>>
        ctx: cont
        sp: 3ffffc40 end: 3fffffd0 offset: 01b0
        3ffffdf0:  000003e7 3ffee488 00000a91 402017ee
        3ffffe00:  3ffee319 00000001 00000040 40201664
        3ffffe10:  3ffee319 000000ff 3ffee488 000003e7
        3ffffe20:  3ffee319 000000ff 3ffee488 40201bd5
        3ffffe30:  00000a8a 00000007 00000001 00418937
        3ffffe40:  00000000 3ffee71c 4023d1ac 000009c2
        3ffffe50:  000000ff 3ffee488 00000002 40201428
        3ffffe60:  3ffee319 00000007 00000005 000000c8
        3ffffe70:  3a4d5354 44414552 574e3a59 000000ff
        3ffffe80:  3fffdad0 3ffee46c 3ffee319 40201ced
        3ffffe90:  6d616461 37393931 00000100 402022d7
        3ffffea0:  00000001 3ffef9fc 00000000 40207afc
        3ffffeb0:  000003fd 4023202b 00000000 40100584
        3ffffec0:  00000001 3ffee317 00000001 40202754
        3ffffed0:  e260f400 00f2597d 3fffff00 3ffffef0
        3ffffee0:  00000000 4bc6a7f0 3fffff10 3fffff00
        3ffffef0:  00000004 00000000 4bc6a7f0 00000000
        3fffff00:  6d616461 00418937 00000000 3ffee2c0
        3fffff10:  3fffdad0 3ffee319 000000ff 40202420
        3fffff20:  3fffdad0 00000103 3ffee35c 402028d4
        3fffff30:  00000000 00000000 000001f4 40201dc5
        3fffff40:  3fffdad0 00000103 000001f4 4020364d
        3fffff50:  00000000 00000103 000001f4 402039df
        3fffff60:  3fffdad0 00000103 000001f4 40203a03
        3fffff70:  3fffdad0 3ffee317 3ffee6cc 40203a62
        3fffff80:  3ffee470 3ffee317 00000000 402036a4
        3fffff90:  600002ff 00020000 3ffee470 3ffee2c0
        3fffffa0:  3fffdad0 3ffee317 3ffee6fe 40203b50
        3fffffb0:  feefeffe 00000000 3ffee2b8 40203bb4
        3fffffc0:  feefeffe feefeffe 3ffe851c 40100129
        <<<stack<<<
        However, using the new driver, I get past that point and the gateway initializes fine. But unfortunately, the sensor node never connects. It just constantly sits waiting to find a parent node:
        16 MCO:BGN:INIT NODE,CP=RPNNA---,REL=255,VER=2.3.1
        26 TSM:INIT
        27 TSF:WUR:MS=0
        29 TSM:INIT:TSP OK
        31 TSM:FPAR
        36 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        2045 !TSM:FPAR:NO REPLY
        2048 TSM:FPAR
        2054 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        4061 !TSM:FPAR:NO REPLY
        4063 TSM:FPAR
        4069 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        6076 !TSM:FPAR:NO REPLY
        6078 TSM:FPAR
        6083 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        8091 !TSM:FPAR:FAIL
        8092 TSM:FAIL:CNT=1
        8094 TSM:FAIL:DIS
        8096 TSF:TDI:TSL
        I'm pretty confident my antenna setups are correct - single core wire, each one a straight piece 82mm long.
        • AdamAntA AdamAnt
          101 TSF:LRT:OK
          117 TSM:INIT
          131 TSF:WUR:MS=0
          156 TSM:INIT:TSP OK
          scandone
          Soft WDT reset
          >>>stack>>>
          ctx: cont
          <<<stack<<<
          26 TSM:INIT
          27 TSF:WUR:MS=0
          29 TSM:INIT:TSP OK
          31 TSM:FPAR
          2048 TSM:FPAR
          4063 TSM:FPAR
          6078 TSM:FPAR
          8091 !TSM:FPAR:FAIL
          8092 TSM:FAIL:CNT=1
          8094 TSM:FAIL:DIS
          8096 TSF:TDI:TSL
          @adamant are you using the new driver on the node? Gateway and nodes must use the same driver.
          What does the gateway log say?
            AdamAntA
            AdamAntA
            AdamAnt
            @mfalkvidd Yeah, I reflashed the node & gateway each time to match.
            The gateway has the same sketch as in post 1, just with #define MY_RFM69_NEW_DRIVER added, and the sensor node is the simple repeater sketch:
             * Version 1.0 - Henrik Ekblad
             * Example sketch showing how to create a node that repeats messages
             * from nodes far from gateway back to gateway.
             * It is important that nodes that has enabled repeater mode calls
             * process() frequently. Repeaters should never sleep.
            // Enabled repeater feature for this node
            #define MY_REPEATER_FEATURE
            	//Send the sensor node sketch version information to the gateway
            	sendSketchInfo("Repeater Node", "1.0");
            • S
              Stefan_NE
              i have the same problem. Using the 2.4.2 of the ESP8266 board library works fine. All later versions not.
              Ther is an other Problme with the ESP Gateway. The Wifi reconnect after a soft reboot or pushing the reset switch is not working.
              The gateway is trying to reconnect until it gets power on / off .
              a Modification of the MyGatewayTransportEthernet.cpp helps. Wifi will be always disconnected with the boot process.
              #if defined(MY_GATEWAY_ESP8266) || defined(MY_GATEWAY_ESP32)
              #if defined(MY_WIFI_SSID)
              // Turn off access point
              WiFi.mode(WIFI_STA);
              #if defined(MY_HOSTNAME)
              WiFi.hostname(MY_HOSTNAME);
              #elif defined(MY_GATEWAY_ESP32)
              WiFi.setHostname(MY_HOSTNAME);
              #ifdef MY_IP_ADDRESS
              WiFi.config(_ethernetGatewayIP, _gatewayIp, _subnetIp);
              GATEWAY_DEBUG(PSTR("GWT:TIN:Disconnect Wifi..\n")); //----------- added
              WiFi.persistent(false); // --------------------------------------------------------------------added
              WiFi.disconnect(); //-------------------------------------------------------------------------- added
              GATEWAY_DEBUG(PSTR("GWT:TIN:Delay 500 ms...\n"));
              delay(500);
              (void)WiFi.begin(MY_WIFI_SSID, MY_WIFI_PASSWORD, 0, MY_WIFI_BSSID);
              while (WiFi.status() != WL_CONNECTED) {
              wait(500);
              GATEWAY_DEBUG(PSTR("GWT:TIN:CONNECTING_wait_500ms...\n"));
              GATEWAY_DEBUG(PSTR("GWT:TIN:IP: %s\n"), WiFi.localIP().toString().c_str());
              Have a nice day
              Stefan
              • S Stefan_NE
                delay(500);
                wait(500);
                Have a nice day
                Stefan
                YveauxY
                YveauxY
                @stefan_ne I entered two issues for the issues described above: https://github.com/mysensors/MySensors/issues/1335 and https://github.com/mysensors/MySensors/issues/1334
                Please enter another issue for your case, or issue a pull request.
                • AdamAntA
                  AdamAntA
                  AdamAnt
                  Just jumping in here to say that a combination of using the new driver, and downgrading to ESP8266 ver 2.5.0 has fixed this for me. The other issue I was having was total user error, a bad solder joint was giving me strange results.
                  Thanks for your help!!
                  • AdamAntA AdamAnt
                    YveauxY
                    YveauxY
                    @adamant thanks for reporting back!
                    Does this mean that https://github.com/mysensors/MySensors/issues/1335 can be closed?
                    • S
                      Stefan_NE
                      I don't think so, in time we have just some workarounds
                      Have a nice day
                      Stefan
                      • S Stefan_NE
                        Have a nice day
                        Stefan
                        YveauxY
                        YveauxY
                        @stefan_ne I would like @AdamAnt to confirm if https://github.com/mysensors/MySensors/issues/1335 is still relevant or not.
                        The op of this thread had 2 issues. I entered them in GitHub, then he hinted the second issue (#1335) was solved by fixing a bad solder joint.
                        So, unless somebody confirms #1335 is still relevant, I will close it.
                        #1334 is of course still to be solved.
                        • K
                          K
                          KalleL
                          I had the same error and realized it was caused in combination with an interrupt routine . Having read the answers above I tried only to introduce
                          this directive
                          ICACHE_RAM_ATTR void Interrupt_routine()
                          { ...code...
                          ... and it was all fine :)
