  3. MQTT Gateway + wi-fi instead of ethernet
mqttwi-figateway
4 Posts 4 Posters 4.1k Views 1 Watching
  • vladimirV
    vladimirV
    vladimir
    Hello!
    Can somebody already did MQTT Gateway with wi-fi instead of ethernet? Is this possible? Please share your code and circuit.
      mainali
      @vladimir Can you put more details, like the gateway will be running on a Rpi or arduino.
      If its a Rpi, then I have not tried yet, but for arduino, the overhead of adding a wifi shield and configuring it will be too much.
      one way is to use a arduino YUN board which has inbuilt wifi and libraries. Or best go ahead with ethernet.
      I gave up personally the wifi after trying a lot. If you come out with the solution do share, I would also love to have a look.
      M 1 Reply Last reply
      • M mainali
        marceloaqno
        Code Contributor
        Did you try using the esp8266 module ? I think it could be possible to build a gateway with it, I'm waiting mine to arrive to test it out.
        • daulagariD
          daulagariD
          daulagari
          Although it should not be too difficult to make the MQTT Gateway with WiFi work on hardware and software level it is a bad idea on system level:
          WiFi and MySensensor NRF24L01+ use the same 2.4 GHz band and with the antennas close a transmit from one will block the other and vice-versa.
