  3. AM2320 will this work as a replacement for AM2302 / DHT22
4 Posts 4 Posters 12.0k Views 2 Watching
  • B Offline
    B Offline
    brchevo
    wrote on last edited by brchevo
    I was looking for another humidity sensor and the AM2320 came up as a alternative to DHT22 / AM2302.
    Has anyone tried this unit already? Will this work as a direct replacement in the humidity sketch for a DHT22?
    Thanks in advance! :-)
    T 1 Reply Last reply
    • B brchevo
      T Offline
      T Offline
      TheoL
      @brchevo I just googled for AM2320 and came accross the AdaFruit site. They say that the AM2302 is just a wired version of the DHT22. So it should work perfect since it is a DHT22.
      • O Offline
        O Offline
        Omemanti
        I know, im responding to an old thread,
        AM2320 is not the same as AM2302, I might be wrong, the switcheroo between 20 an 02 is easily made,
        If Im correct;
        AM2320 = 1 = vcc / 2 = SDA / 3 = GND / 4 = SCL
        AM2302 = 1 = vcc / 2 = SDA / 3 = NC / 4 = GND
        Please correct me if im wrong, cuz I dont get the AM2320 properly working.
        • B Offline
          B Offline
          bgunnarb
          @Omemanti
          I think the AM2320 has got an "One-wire mode", at least if you look at the datasheet. I have not tried it though.
          I also had great difficulties in getting the AM2320 to work with I2C until I realised late last night that I had forgotten to include the pull-up resistors, 4k7 each from SDC and SDA to Vcc. All other I2C sensors I have used have had them included on the breakout board but this sensor does not have them built in the sensor body.
          Now it works like a charm, one measurement of temp and hum every 2 minutes.
          There are a few arduino-libraries for AM2320 floating around. I use this: (https://github.com/thakshak/AM2320)
          Here is my sketch:
           * Temperature and humidity measurement using the AM2320 with I2C interface
           * Battery voltage also monitored using internal reference
          #define MY_NODE_ID 23
          #define BATTERY_SENSE_PIN A0  // Input pin for battery sense
          #define VMIN 1.0  // (Min input voltage to regulator according to datasheet or guessing. (?) )
          #define VMAX 3.22 // (Known or desired voltage of full batteries. If not, set to Vlim.)
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          #include <AM2320.h>
          #include <Wire.h>
          #define DEBUG_PRINT 0  // Print temperature and humidity measurements on serial i/f. 1 = Yes 0 = No
          unsigned long SLEEP_TIME = 120000; // Sleep time between reads (in milliseconds)
          bool receivedConfig = false;
          bool metric = true;
          float temp, hum;
          // Create an AM2320 instance
          AM2320 th;
          // Initialize AM temperature message
          MyMessage msgt(CHILD_ID_TEMP,V_TEMP);
          // Initialize AM humidity message
          MyMessage msgh(CHILD_ID_HUM,V_HUM);
          void before()
              analogReference(INTERNAL1V1);
            #else
              analogReference(INTERNAL);
          Serial.begin(115200);
          Wire.begin();
          void presentation() {
            sendSketchInfo("Temp. Hum Sensor", "1.4");
            // Present temp/humidity sensor to controller
            present(CHILD_ID_HUM, S_HUM);
            //Get temperature and humidity from AM2320
            switch(th.Read()) {
              case 2:
                Serial.println("CRC failed");
                break;
              case 1:
                Serial.println("Sensor offline");
                break;
              case 0:
                temp = th.t;
                send(msgt.set(temp, 1));
                hum = th.h;
                send(msgh.set(hum, 0));
                if (DEBUG_PRINT == 1) {
                  Serial.print("humidity: ");
                  Serial.print(th.h);
                  Serial.print("%, temperature: ");
                  Serial.print(th.t);
                  Serial.println("*C");
                break;
            sleep (200);
            // get the battery voltage
            int batValue = analogRead(BATTERY_SENSE_PIN);    // Battery monitoring reading
            float Vbat  = batValue * 0.003363;
            int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
            sleep(SLEEP_TIME);
          I have never been so busy since I retired!
