  3. Sensebender with RFM69
5 Posts 3 Posters 4.7k Views 4 Watching
  • T Offline
    T Offline
    tbowmo
    Got my converter boards for RFM69 -> NRF24 footprint in from Dirty pcb's today, and it seems that the sensebender has accepted it's new friend..
    However, the GW that I have set up, doesn't receive anything (they are within 5cm of each other). So I have to do some good old hardware debugging (on both sides)..
    • Igor KatkovI Offline
      Igor Katkov
      Would you care to share schematics?
      • T Offline
        T Offline
        tbowmo
        @Igor-Katkov
        The design is available on openhardware https://www.openhardware.io/view/16/NRF2RFM69
        • S Offline
          stedew
          Well i don't know wich RFM69 you use but i have here a few moteino's and also toy-ing with them i had similar problem no data exchange possible between the two moteino's. whatever i try no connection was builtup. i even unsolder a rfm69HW on the GW and replaced it.. it communicates??? So conclusion bad RFM69 Throw away.. and test further. After a few days again same problem. Now it was on the breadboard so replacing was easy. Same as before (replace and works).
          Then i loaded up the moteino test program in the sensornode and the GW with the non working RFM69 .... Works like a charm??? switch back to Mysensors works again.. I Can't remeber anymore what i did but you have to look at the code n the utility folder the rfm69.cpp file in the initializer. when there is no encryption (NULL) the encryption string is not written.. so ones it's filled in you can't clear it. I suspect that the problem relies there..
          regards, Stefan.
          • T Offline
            T Offline
            tbowmo
            @stedew
            Thanks for the info. My problem was much simpler, as I hadn't defined the right interrupt pin in the software that the rfm69 was connected to.
            So after setting this, I had communication up and running.
            12.2k
