  3. battery level doesn't appear ?
25 Posts 6 Posters 7.5k Views 4 Watching
  • F Offline
    F Offline
    flylowgofast
    Hello all,
    I have a node with switchs and dimmer, and I tried to send Battery level like that :
      if ((millis() - myTime) > 10000) { // toutes les dix secondes
        myTime = millis();
        gw.sendBatteryLevel(97,1);
      } else {
        if ((millis() - myTime) < 0) {
          myTime = millis();
    but in Domoticz I can't see the battery level ! however, I have the same code for two other nodes with temperature sensors and in this case It works ? is Battery level for temperature sensors only ?
    thanks
    A 1 Reply Last reply
    • mfalkviddM Offline
      What do you mean by "1" in "97,1"?
      The signature for sendBatteryLevel is
      void sendBatteryLevel(uint8_t level, bool ack=false);
      Sending 1 means the same as true, even though sending 1 is less clear than sending true. It should still work though.
      • F Offline
        F Offline
        flylowgofast
        hello,
        thanks for your answer. For me 97,1 means 97% and acknowledge. And the same code work properly with my other nodes with temperature sensors !
        Any other ideas ?
        • F Offline
          F Offline
          flopp
          wrote on last edited by flopp
          I have rain, light and temp sensor and battery level is working, so I think you can have it for almost any sensor type.
          Have you tried to remove everything except gw.sendbattery...
          Just to check?
          The last } does it have a { above if
          I guess you have otherwise you cannot compile but maybe that is in an IF loop or some other loop that doesn't work as expected
          F 1 Reply Last reply
          • F flylowgofast
            Hello all,
                myTime = millis();
              } else {
                  myTime = millis();
            thanks
            A Offline
            A Offline
            AWI
            @flylowgofast Is the actual sensor updating? From my experience Domoticz only updates/shows the new battery level when a new value is received for the sensor data..
            • F flopp
              Just to check?
              F Offline
              F Offline
              flylowgofast
              Hello @flopp,
              I'll try this evening to remove all the code but gw.sendbattery...
              I think there isn't problem with { or }, perhaps you don't like my way to write code :smile:
              thanks
              • A AWI
                F Offline
                F Offline
                flylowgofast
                hello @AWI,
                is there a way to verify if my sensor send a newx value ? because I can't use terminal with debug informations, I use Rx / Tx for an other purpose !
                thanks
                • S Offline
                  @flylowgofast - Check Domoticz log, if the value updates you see it there.
                  Or for more details, check serial log on your gateway. There you see all trafic. As AWI said, you wont see any updates on Domoticz if its the same value as before, Domoticz needs new value to update.
                  • X Offline
                    X Offline
                    Xander
                    "Battery Level" is a internal message.
                    See: http://www.mysensors.org/download/serial_api_15
                    This means it is going to the gateway and nobody knows what the gateway is doing with it...
                    Please correct me if I am wrong.
                    • S Offline
                      I have several nodes reporting battery level to Domoticz.
                      • F Offline
                        F Offline
                        flylowgofast
                        hello,
                        here is logs from gateway
                        2;4;1;1;3;70;0;3;0;9;send: 0-0-2-2 s=4,c=1,t=3,pt=0,l=1,sg=0,st=fail:7
                        Finished
                        0;0;3;0;18;PINGFinished
                        0;0;3;0;9;read: 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:97
                        0;0;3;0;9;send: 0-0-1-1 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:97
                        1;255;3;0;0;97
                        Finished
                        0;0;3;0;18;PING0;0;3;0;9;read: 65-65-0 s=255,c=3,t=0,pt=1,l=1,sg=0:99
                        0;0;3;0;9;send: 0-0-65-65 s=255,c=3,t=0,pt=1,l=1,sg=0,st=fail:99
                        65;255;3;0;0;99
                        1;255;3;0;0;97
                        Finished
                        Is there a documentation to understand better ?
                        thanks
                        • F Offline
                          F Offline
                          flopp
                          Can you post your sketch here?
                          • F Offline
                            F Offline
                            flopp
                            This is from my GW
                            0;0;3;0;18;PING0;0;3;0;9;read: 12-12-0 s=255,c=3,t=0,pt=1,l=1,sg=0:98
                            12;255;3;0;0;98
                            0;0;3;0;9;read: 12-12-0 s=1,c=1,t=38,pt=7,l=5,sg=0:2.979
                            12;1;1;0;38;2.979
                            0;0;3;0;9;read: 12-12-0 s=0,c=1,t=23,pt=3,l=2,sg=0:66
                            12;0;1;0;23;66
                            Finished
                            98% battery
                            2.979 voltage
                            66 lux
                            • F Offline
                              F Offline
                              flopp
                              You can also restart your Node and then it will send all data again like, Sketchname, version and also all childs
                              • F Offline
                                F Offline
                                flylowgofast
                                my loop(){}
                                // the loop routine runs over and over again forever:
                                  gw.process();
                                  //---------------Lecture des ouvertures de porte------------------
                                  doorOpenOffState = digitalRead(HALLOFFICEDOOR); // lecture à chaque cycle (urgence)
                                  if (doorOpenOffState != doorOpenOffChange){
                                    gw.send(msgDoorOffice.setSensor(OFFICEDOOR).set(doorOpenOffState));
                                    doorOpenOffChange = doorOpenOffState;
                                  doorOpenBedState = digitalRead(HALLBEDROOMDOOR); // lecture à chaque cycle (urgence)
                                  if (doorOpenBedState != doorOpenBedChange){
                                    gw.send(msgDoorBedroom.setSensor(BEDROOMDOOR).set(doorOpenBedState));
                                    doorOpenBedChange = doorOpenBedState;
                                  if (digitalRead(ECLEXT) != oldInterExt){
                                    oldInterExt = !oldInterExt;
                                    eclState = !eclState;
                                    gw.send(msgLightSwitch.set(eclState));
                                  //---------------Envoi du niveau de batterie !! pour rester eveillé------------------
                                  /*if ((millis() - myTime) > 10000) { // toutes les dix secondes
                                    myTime = millis();
                                  } else {
                                      myTime = millis();
                                // ---------------Traitement volet 1-----------------
                                  analogUpV1 = analogRead(UPV1);
                                  if ((analogUpV1 <25) && !manOnV1) { //analogUp proche de zéro et ancienne valeur niveau haut (en l'air)
                                    digitalWrite(TRIAC5, HIGH);
                                    digitalWrite(TRIAC2, LOW);
                                    triacTempoV1 = millis();
                                    triacManPriorityV1 = true;
                                    manOnV1 = true;
                                    memoStopV1 = false;
                                  } else {
                                    analogDownV1 = analogRead(DOWNV1);
                                    if ((analogDownV1 <25) && !manOnV1) { //proche de zéro
                                      digitalWrite(TRIAC5, LOW);
                                      digitalWrite(TRIAC2, HIGH);
                                      manOnV1 = true;
                                      memoStopV1 = false;
                                    } else {
                                      if (analogUpV1 > 800 && analogDownV1 > 800 && !memoStopV1){ // les deux fils en l'air
                                        triacManPriorityV1 = false;
                                        manOnV1 = false;
                                        memoStopV1 = true;
                                      } else {
                                        if (!triacManPriorityV1){
                                          if (shutterOff1State && shutterOff2State) {
                                            shutterOff1State = false;
                                            shutterOff2State = false;
                                          } else {
                                            if (shutterOff1State) {
                                            } else {
                                              if (shutterOff2State) {
                                  if (((triacTempoV1 + TEMPOOPENV1) < millis())) {
                                // --------------------------Traitement volet 2------------------------
                                  analogUpV2 = analogRead(UPV2);
                                  if ((analogUpV2 <25) && !manOnV2) { //analogUp proche de zéro et ancienne valeur niveau haut (en l'air)
                                    digitalWrite(TRIAC3, HIGH);
                                    digitalWrite(TRIAC4, LOW);
                                    triacTempoV2 = millis();
                                    triacManPriorityV2 = true;
                                    manOnV2 = true;
                                    memoStopV2 = false;
                                  } else {
                                    analogDownV2 = analogRead(DOWNV2);
                                    if ((analogDownV2 <25) && !manOnV2) { //proche de zéro
                                      digitalWrite(TRIAC3, LOW);
                                      digitalWrite(TRIAC4, HIGH);
                                      manOnV2 = true;
                                      memoStopV2 = false;
                                    } else {
                                      if (analogUpV2 > 800 && analogDownV2 > 800 && !memoStopV2){ // les deux fils en l'air
                                        //triac3 = false;
                                        //triac4 = false;
                                        triacManPriorityV2 = false;
                                        manOnV2 = false;
                                        memoStopV2 = true;
                                      } else {
                                        if (!triacManPriorityV2){
                                          if (shutterBed1State && shutterBed2State) {
                                            shutterBed1State = false;
                                            shutterBed2State = false;
                                          } else {
                                            if (shutterBed1State) {
                                            } else {
                                              if (shutterBed2State) {
                                  if (((triacTempoV2 + TEMPOOPENV2) < millis())) {
                                • F flylowgofast
                                  my loop(){}
                                    gw.process();
                                      myTime = millis();
                                    } else {
                                        myTime = millis();
                                      manOnV1 = true;
                                      memoStopV1 = false;
                                    } else {
                                        manOnV1 = true;
                                        memoStopV1 = false;
                                      } else {
                                          manOnV1 = false;
                                          memoStopV1 = true;
                                        } else {
                                            } else {
                                              } else {
                                      manOnV2 = true;
                                      memoStopV2 = false;
                                    } else {
                                        manOnV2 = true;
                                        memoStopV2 = false;
                                      } else {
                                          //triac3 = false;
                                          //triac4 = false;
                                          manOnV2 = false;
                                          memoStopV2 = true;
                                        } else {
                                            } else {
                                              } else {
                                  F Offline
                                  F Offline
                                  flopp
                                  @flylowgofast
                                  Look ok
                                  • F flylowgofast
                                    hello,
                                    Finished
                                    1;255;3;0;0;97
                                    Finished
                                    65;255;3;0;0;99
                                    1;255;3;0;0;97
                                    Finished
                                    thanks
                                    A Offline
                                    A Offline
                                    AWI
                                    @flylowgofast for information on the logs take a look at the debug topic
                                    • F Offline
                                      F Offline
                                      flylowgofast
                                      My real problem is not to send battery level. I try to do that because after 24 or 48 hours my node stop sending messages . So, I hoped that was a way to make it awake !
                                      A F 2 Replies Last reply
                                      • F flylowgofast
                                        A Offline
                                        A Offline
                                        AWI
                                        @flylowgofast From what I read from your sketch you seem to do some high voltage / current switching. Especially the radio doesn't like all kinds of electronic disturbances (emc etc.) To avoid lockups you need to pay special attention/separate power supplies (if you haven't done already).
                                        • F Offline
                                          F Offline
                                          flylowgofast
                                          Hello AWI,
                                          Thanks for your reply, yes my node trigs 5 triacs. I use snubber, regulator, capacitor. And ond the other hand, all commands to the node work properly ? just battery level doesn't work and after several hours NRF24L01 stop to work.
                                          I would like to reset NRF24L01 but with MySensors we don't have direct access to it anymore. Perhaps there is a way to reset the sketch globaly ?
                                          thanks for your help
                                          12.1k
