  3. Mosquitto
Mosquitto
11 Posts 3 Posters 5.6k Views 3 Watching
  • M Offline
    M Offline
    moskovskiy82
    Not really related to mysensors but many are using MQTT so the question goes like this.
    Currently moving from UBUNTU 14 server to the latest RASPBIAN on raspberry. The gateway is the MQTT client ESP12
    Installed mosquitto, mosquitto-clients and mosquitto python (both)
    Running tcommand on ubuntu
    $ mosquitto_sub -v -t 'mygateway1-out/#'
    gives me output from mysensors
    running
    on raspbian gives me silence
    Mosquitto is up and running and i can see it on the sockets
    And yes i have a loopback in interfaces.
    auto lo
    iface lo inet loopback
    Any help will be appreciated
    • M Offline
      M Offline
      moskovskiy82
      In the logs i notice
      1465234765: New connection from ::1 on port 1883.
      1465234765: New client connected from ::1 as mosqsub/1701-homepi (c1, k60).
      1465234774: Socket error on client mosqsub/1701-homepi, disconnecting.
      1465234789: mosquitto version 1.3.4 terminating
      1465234789: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
      Y 1 Reply Last reply
      • M moskovskiy82
        Y Offline
        Y Offline
        @moskovskiy82 Maybe different Mosquitto versions?
        Caused me headaches in the past...
        • M Offline
          M Offline
          moskovskiy82
          Touche... Will try to install a new one. Wonder if it is worth going MQTT path after this...
          Ubuntu
          libmosquitto0:amd64/trusty 0.15-2ubuntu1 uptodate
          libmosquitto1:amd64/trusty 1.4.9-0mosquitto1 uptodate
          mosquitto:amd64/trusty 1.4.9-0mosquitto1 uptodate
          mosquitto-clients:amd64/trusty 1.4.9-0mosquitto1 uptodate
          Raspbian
          libmosquitto1:armhf/jessie 1.3.4-2 uptodate
          mosquitto:armhf/jessie 1.3.4-2 uptodate
          mosquitto-clients:armhf/jessie 1.3.4-2 uptodate
          python-mosquitto:all/jessie 1.3.4-2 uptodate
          python3-mosquitto:all/jessie 1.3.4-2 uptodate
          • M Offline
            M Offline
            moskovskiy82
            Well now i have a hedache as well..
            Updated to 1.4.8 freom http://repo.mosquitto.org/debian/mosquitto-jessie.list (as it seems the latest avail)
            Upgraded mosquitto and mosquitto clients
             $ apt-show-versions | grep mosquitto
            libmosquitto1:armhf/jessie 1.4.8-0mosquitto2 uptodate
            mosquitto:armhf/jessie 1.4.8-0mosquitto2 uptodate
            mosquitto-clients:armhf/jessie 1.4.8-0mosquitto2 uptodate
            And still i get
             1465238048: Config loaded from /etc/mosquitto/mosquitto.conf.
             1465238048: Opening ipv4 listen socket on port 1883.
             1465238048: Opening ipv6 listen socket on port 1883.
             1465238066: New connection from 127.0.0.1 on port 1883.
             1465238066: New client connected from 127.0.0.1 as mosqsub/1282-homepi (c1, k60).
             1465238078: Socket error on client mosqsub/1282-homepi, disconnecting.
            • M moskovskiy82
              And still i get
              Y Offline
              Y Offline
              @moskovskiy82 Did you try google'ing for the error?
              When I do, I get e.g. http://jpmens.net/2014/07/03/the-mosquitto-mqtt-broker-gets-websockets-support/#comment-1907704831
              Maybe that helps?
              • M Offline
                M Offline
                moskovskiy82
                I tried. But i don't have any username/password
                Strange thing is that this is a fresh raspbian install (downloaded yesterday)
                pid_file /var/run/mosquitto.pid
                persistence true
                persistence_location /var/lib/mosquitto/
                log_dest file /var/log/mosquitto/mosquitto.log
                include_dir /etc/mosquitto/conf.d
                • Harry van der WolfH Offline
                  Harry van der Wolf
                  wrote on last edited by Harry van der Wolf
                  I had some issues as well and read somewhere that there was an issue with the mosquitto packages for raspberri, so I installed from git.
                  wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
                  sudo apt-key add mosquitto-repo.gpg.key
                  cd /etc/apt/sources.list.d/
                  for wheezy: sudo wget http://repo.mosquitto.org/debian/mosquitto-wheezy.list
                  for jessie: sudo wget http://repo.mosquitto.org/debian/mosquitto-jessie.list
                  apt-get update
                  apt-get install mosquitto
                  sudo /etc/init.d/mosquitto start
                  All working flawless for months now.
                  • M Offline
                    M Offline
                    moskovskiy82
                    This i what i did above to solve the old version problem
                    Installed from http://repo.mosquitto.org/debian/mosquitto-jessie.list
                    With no luck.
                    Turning debug i see the following only
                    1465240376: mosquitto version 1.4.8 terminating
                    1465240386: New connection from 127.0.0.1 on port 1883.
                    1465240386: New client connected from 127.0.0.1 as mosqsub/1948-homepi (c1, k60).
                    1465240386: Sending CONNACK to mosqsub/1948-homepi (0, 0)
                    1465240386: Received SUBSCRIBE from mosqsub/1948-homepi
                    1465240386:     mygateway1-out/# (QoS 0)
                    1465240386: Sending SUBACK to mosqsub/1948-homepi
                    1465240419: Socket error on client mosqsub/1948-homepi, disconnecting.
                    Not that much of a help...
                    • M Offline
                      M Offline
                      moskovskiy82
                      What is also strange i tried to start mosquitto with
                      sudo mosquitto -c /etc/mosquitto/mosquitto.conf -v
                      Than on the second console i tried
                      and also
                      Strange thing is that id didn't see any messages in cosole. In the log file
                      1465242491: mosquitto version 1.4.8 (build date Tue, 17 May 2016 11:26:59 +0100) starting
                      1465242491: Config loaded from /etc/mosquitto/mosquitto.conf.
                      1465242491: Opening ipv4 listen socket on port 1883.
                      1465242491: Opening ipv6 listen socket on port 1883.
                      1465242495: New connection from ::1 on port 1883.
                      1465242495: New client connected from ::1 as mosqsub/1848-homepi (c1, k60).
                      1465242495: Sending CONNACK to mosqsub/1848-homepi (0, 0)
                      1465242495: Received SUBSCRIBE from mosqsub/1848-homepi
                      1465242495:     mygateway1-out/# (QoS 0)
                      1465242495: mosqsub/1848-homepi 0 mygateway1-out/#
                      1465242495: Sending SUBACK to mosqsub/1848-homepi
                      1465242527: Socket error on client mosqsub/1848-homepi, disconnecting.
                      1465242530: New connection from ::1 on port 1883.
                      1465242530: New client connected from ::1 as mosqpub/1850-homepi (c1, k60).
                      1465242530: Sending CONNACK to mosqpub/1850-homepi (0, 0)
                      1465242530: Received PUBLISH from mosqpub/1850-homepi (d0, q0, r0, m0,     'mygateway1-in/99/0/1/0/40', ... (6 bytes))
                      1465242530: Received DISCONNECT from mosqpub/1850-homepi
                      1465242530: Client mosqpub/1850-homepi disconnected.
                      1465242536: mosquitto version 1.4.8 terminating
                      • M moskovskiy82
                        and also
                        Y Offline
                        Y Offline
                        @moskovskiy82 can you subscribe and publish something on the pc? Then do the same on the rpi. At least that should work...
