  3. Advice about RF nRF24L01+ to send/receive sensory information
29 Posts 3 Posters 11.7k Views 2 Watching
  • Walyson Albuquerque MachadoW Offline
    wrote on last edited by Walyson Albuquerque Machado
    Hello! :smiley:
    I'm a beginner and I'd like to ask you guys about the RF nRF24L01+
    I want to use a hall sensor module to measure the speed and a voltage sensor module to measure the battery level of a Remote Control Car. One Arduino UNO stays on the Car to get these information of the sensors and then the RF nRF24L01+ send them to another Arduino UNO(near to the Car) that receives with another RF nRF24L01+ and display the information in a LCD 20x4.
    This Remote Control Car is going to operate only in short distances(like inside a house).
    Have anyone done a project similar like this? Is it too hard?
    The RF nRF24L01+ operates with 2.4GHz and the remote control with 27MHZ, am I going to have problems with interferences?
    Thanks a lot in advance! :thumbsup:
    • Walyson Albuquerque MachadoW Walyson Albuquerque Machado
      Hello! :smiley:
      Welcome to the MySensors forum @Walyson-Albuquerque-Machado
      What you are describing should be pretty easy. The radios will not interfere with eachother.
      An example for how to use MySensors with a display is available at https://www.mysensors.org/build/display but don't use the code there (it is for MySensors 1.x), use the RealTimeClockDisplaySensor example included in https://github.com/mysensors/MySensorsArduinoExamples
      Instructions on how to measure and report battery level is available at https://www.mysensors.org/build/battery#measuring-and-reporting-battery-level
      Using a controller would probably be overkill for this project, unless you want graphs of the battery level. Read more about the differenc components in a MySensors network at https://www.mysensors.org/about/network
      If you don't use a controller you'll need to set CHILD_ID in the sketch.
      Start small, perhabs by building the lcd device and making it display some text. What that is working, move on to the next step. Don't try to build everything at once.
      Walyson Albuquerque MachadoW 1 Reply Last reply
        @mfalkvidd Thank you! I really appreciated your advices.
        I'm using two Arduinos UNO and at the moment I can see battery level using a lcd and a voltage sensor module.
        Now I'm going to build the nRF module, but I have a doubt about the Arduino UNO pin using SPI interface MOSI, MISO and SCK.
        One UNO with nRF > pin 11, 12 and 13 / SD card > pin 11, 12 and 13
        Another UNO with nRF > pin 11, 12 and 13 / lcd > pin 11, 12, 2, 3, 4 and 5
        They use the same pins, what am I gonna do? Put them in parallel?
        Thanks!
          Thanks!
          @Walyson-Albuquerque-Machado it depends on which libraries and which lcd and sd card reader you are using. Some can be put in parallell, with addition of a slave select pin. An alternative is to use softspi as described in https://www.mysensors.org/build/ethernet_gateway and https://github.com/mysensors/MySensors/blob/development/examples/GatewayW5100/GatewayW5100.ino#L57
          With softspi, an extra spi bus is created and one of the components (the w5100 ethernet module in the above example) is connected to the extra bus so it does not interfere with the nrf.
          https://learn.sparkfun.com/tutorials/serial-peripheral-interface-spi is a good start if you want to learn more about spi.
            Hey!
            Thanks @mfalkvidd !
            I'm trying to make the module nRF24l01+ work with the micro SD card in parallell and I'm having some trouble.
            The micro SD card is working, but the nRF24l01+ not.
            The nRF24l01+ works fine when there's no micro SD card.
            Can anyone give me a help, please!?
            TX:
            #include <RF24.h>
            #define REFRESH_TIME 1000
            RF24 radio (9, 10);
            byte enderecos[][6] = {"1node"};
            float dadosenviados[2];
            // Bateria
            int sensorTensaoDC = A0;
            float valorTensaoDC;
            int amostragem = 1000;
            float mediaTotalTensaoDC = 0;
            float R1 = 28000.0;
            float R2 = 7600.0;
            int sensorValue_aux = 0;
            float voltsporUnidade = 0.004887586;// 5%1023
            //Velocidade
            unsigned long lastRefresh = millis();
            float circMetric = 0.17;
            volatile long loopCount = 0;
            void setup ()
              analogReference(DEFAULT);
              pinMode(A0, INPUT);
              attachInterrupt(0, speedCalc, RISING);
              radio.begin();
              radio.openWritingPipe(enderecos[0]);
              radio.stopListening();
            void bateria ()
              for(int i=0; i < amostragem ; i++)
                valorTensaoDC = analogRead(sensorTensaoDC);
                valorTensaoDC =(valorTensaoDC*voltsporUnidade);
                mediaTotalTensaoDC = mediaTotalTensaoDC+ (valorTensaoDC / (R2/(R1+R2)));
                delay(1);
              dadosenviados[0] = mediaTotalTensaoDC / amostragem;
            void velocidade ()
              if (millis() - lastRefresh >= REFRESH_TIME)
                detachInterrupt(0);
                dadosenviados[1] = (3600*circMetric*loopCount)/(millis() - lastRefresh);
                loopCount = 0;
            void speedCalc()
              loopCount++;
            void envio ()
              radio.write(&dadosenviados, sizeof(dadosenviados));
              delay(10);
              dadosenviados[0] = 0;
              dadosenviados[1] = 0;
              bateria();
              velocidade();
              envio();
            RX:
            #include <SD.h>
            #include <RF24.h>
            #include <LiquidCrystal.h>
            #define CE_PIN   9 // RF
            #define CSN_PIN 10 //RF
            #define SS_P 8// SD
            RF24 radio (9, 10);
            File dataFile;
            LiquidCrystal lcd(3, 2, 7, 6, 5, 4);
            String dadosrecebidos[2];
            void setup ()
            pinMode(CSN_PIN, OUTPUT); // RF
            pinMode(CE_PIN, OUTPUT); // RF
            pinMode(SS_P, OUTPUT); // SD
              digitalWrite(SS_P, HIGH);
              digitalWrite(CSN_PIN, HIGH);
              digitalWrite(CE_PIN, HIGH);
              SPI.begin();
              delay(50);
              digitalWrite(CSN_PIN, LOW);
              digitalWrite(CE_PIN, LOW);
                radio.begin();
                radio.openReadingPipe(1, enderecos[0]);
                radio.startListening();
              lcd.begin(20, 4);
              lcd.clear();
              lcd.setCursor(5, 0);
              lcd.print("Teste 1.6");
              delay(5000);
              lcd.setCursor(3, 2);
              lcd.print("Carregando...");
              delay(5000);
              lcd.clear();
              digitalWrite(SS_P, LOW);
                if (SD.begin(SS_P))
                lcd.setCursor(0, 0);
                lcd.print("Cartao presente!");
                lcd.setCursor(0, 1);
                lcd.print("Pronto para gravar.");
                delay(5000);
                lcd.setCursor(3, 3);
                lcd.print("Iniciando...");
                delay(5000);
              else
                lcd.print("Insira o cartao!");
                lcd.print("Se ja inseriu,");
                lcd.setCursor(0, 2);
                lcd.print("verifique o");
                lcd.setCursor(0, 3);
                lcd.print("cartao");
                delay(5000);
                dataFile = SD.open("datalog.txt", FILE_WRITE);
                if (dataFile)
                dataFile.println("Tensão e velocidade");
                dataFile.close();
                else
                dataFile.println("Erro");
            void recebido ()
               if (radio.available())
                while (radio.available())
                  radio.read(&dadosrecebidos, sizeof(dadosrecebidos));
                lcd.clear();
                lcd.print("TENSAO");
                lcd.setCursor(7, 0);
                lcd.print(dadosrecebidos[0]);
                lcd.print("VOLTS");
                lcd.print("VELOCIDADE");
                lcd.setCursor(11, 1);
                lcd.print(dadosrecebidos[1]);
                lcd.print("KM/H");
            void gravar()
              // make a string for assembling the data to log:
              String dataString = ""; //this line simply erases the string
              dataString += "Tensao ";
              dataString += (dadosrecebidos[0]);
              dataString += " VOLTS";
              dataString += " / ";     //puts a comma between the two bits of data
              dataString += "Velocidade ";
              dataString += (dadosrecebidos[1]);
              dataString += " KM/H";
              delay (1000);
              // if the file is available, write to it:
              if (dataFile)
                dataFile.println(dataString);
                dataFile.close();
              // if the file isn't open, pop up an error:
              else
            void loop ()
              recebido();
              gravar();
            A 1 Reply Last reply
              Hey!
              Thanks @mfalkvidd !
              TX:
              #include <RF24.h>
              RF24 radio (9, 10);
              // Bateria
              float R1 = 28000.0;
              float R2 = 7600.0;
              //Velocidade
              void setup ()
                pinMode(A0, INPUT);
                radio.begin();
              void bateria ()
                  delay(1);
              void velocidade ()
                  detachInterrupt(0);
                  loopCount = 0;
              void speedCalc()
                loopCount++;
              void envio ()
                delay(10);
                bateria();
                velocidade();
                envio();
              RX:
              #include <SD.h>
              #include <RF24.h>
              #define SS_P 8// SD
              RF24 radio (9, 10);
              File dataFile;
              void setup ()
                SPI.begin();
                delay(50);
                  radio.begin();
                lcd.begin(20, 4);
                lcd.clear();
                delay(5000);
                delay(5000);
                lcd.clear();
                  if (SD.begin(SS_P))
                  delay(5000);
                  delay(5000);
                else
                  delay(5000);
                  if (dataFile)
                  dataFile.close();
                  else
              void recebido ()
                  lcd.clear();
                  lcd.print("VOLTS");
                  lcd.print("KM/H");
              void gravar()
                delay (1000);
                if (dataFile)
                  dataFile.close();
                else
              void loop ()
                recebido();
                gravar();
              A Offline
              A Offline
              AWI
              @Walyson-Albuquerque-Machado from your sketch I conclude that you are not using MySensors as framework for creating you sensor and logger.
              @mfalkvidd gave you some good suggestions for using a SPI bus interface.
              The purpose of this forum is to work with/ discuss the MySensors framework.
              Give MySensors a try and discover that it solves a lot of your low level interface issues.
              • A AWI
                @AWI Hi.
                Sure, I'm going to try and then I come back here.
                Thanks.
                  Hey. I'm trying to use Mysensors, but I got these errors. Are there a specific command that I should use? I didn't find any example.
                  error: 'RF24' does not name a type RF24 radio(MY_RF24_CE_PIN, MY_RF24_CS_PIN);
                  error: 'radio' was not declared in this scope radio.begin();
                    A Offline
                    A Offline
                    AWI
                    @Walyson-Albuquerque-Machado The MySensors site is full of examples. You probably have an incomplete instalation or conflicting (RF24) libararies. Try getting started
                      I'm getting started and I'm researching about Mysensors. I would like some tips, please.
                      I know that I must set this first:
                      #define RF24_CE_PIN       9
                      #define RF24_CS_PIN      10
                      #define RF24_PA_LEVEL      RF24_PA_MAX
                      #define RF24_PA_LEVEL_GW   RF24_PA_LOW
                      #define RF24_CHANNEL     76
                      #define RF24_DATARATE      RF24_250KBPS
                      #define RF24_BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL)
                      #define SOFTSPI
                      #ifdef SOFTSPI
                        const uint8_t SOFT_SPI_MISO_PIN = 16;
                          const uint8_t SOFT_SPI_MOSI_PIN = 15;
                          const uint8_t SOFT_SPI_SCK_PIN = 14;
                      #include <MyConfig.h>
                      And I know that in 2.0.x I don't need to set this:
                       .begin();
                      But I don't know how to define in Mysensors when it's Writing / stopListening and Reading / startListening
                      startListening();
                      Also how to Write the sensor information and Read:
                      Is this how I send the sensor information? If so, how do I read?
                        sendSketchInfo("Distance Sensor", "1.0");
                        present(CHILD_ID, S_DISTANCE);
                        #define SOFTSPI
                        #ifdef SOFTSPI
                         .begin();
                        startListening();
                        A Offline
                        A Offline
                        AWI
                        @Walyson-Albuquerque-Machado You are getting on track. You should not bother about the radio, it is hidden (abstracted) in MySensors. You send with the "send" function and receive with the "receive" function. Everything as described in the API.
                        I would suggest you build a simple sensor/sketch (i.e. relay actuator) before diving deeper.
                        I am still taking some tough lessons combining devices on the SPI bus. Like @mfalkvidd mentioned in his post
                        Let us know your progress.
                          I'm trying to do the battery level example and I'm getting this:
                          TSM:INIT
                          TSM:RADIO:OK
                          TSP:ASSIGNID:OK (ID=10)
                          TSM:FPAR
                          TSP:MSG:SEND 10-10-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                          TSP:MSG:READ 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                          TSP:MSG:BC
                          TSM:FPAR
                          TSP:MSG:BC
                          TSM:FPAR
                          TSM:FPAR
                          !TSM:FPAR:FAIL
                          !TSM:FAILURE
                          TSM:PDT
                          What does it mean? Why can't I read the serial messages?
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSP:MSG:BC
                            TSM:FPAR
                            TSP:MSG:BC
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            A Offline
                            A Offline
                            AWI
                            Your node does not find a parent (gateway) so no response from another node. For documentation: a little indirect but this post by @mfalkvidd should help.
                              Ok, I'm getting there. I appreciate your advices, thanks. :smile:
                              Now I can see the battery level in the serial. But I didn't understand how to receive the battery level in the gateway to show on my LCD display.
                              Gateway ok:
                              0;255;3;0;9;TSM:INIT
                              0;255;3;0;9;TSM:RADIO:OK
                              0;255;3;0;9;TSM:GW MODE
                              0;255;3;0;9;TSM:READY
                              0;255;0;0;18;2.0.0
                              0;255;3;0;9;TSP:MSG:READ 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                              0;255;3;0;9;TSP:MSG:BC
                              0;255;3;0;9;TSP:MSG:FPAR REQ (sender=10)
                              0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
                              0;255;3;0;9;TSP:MSG:GWL OK
                              0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                              0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                              0;255;3;0;9;TSP:MSG:PINGED (ID=10, hops=1)
                              0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                              0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                              0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                              0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                              10;255;0;0;17;2.0.0
                              0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                              10;255;3;0;6;0
                              0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Battery Meter
                              0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                              0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                              0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                              Node ok:
                              TSM:INIT
                              RF24:write register, reg=0, value=14
                              RF24:read register, reg=6, value=35
                              RF24:flushRX
                              TSM:RADIO:OK
                              RF24:start listening
                              RF24:write register, reg=10, value=10
                              TSM:FPAR
                              RF24:stop listening
                              RF24:open writing pipe, recipient=255
                              RF24:write register, reg=10, value=255
                              RF24:send message to 255, len=7
                              RF24:flushTX
                              RF24:MAX_RT
                              TSP:MSG:READ 0-0-10 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                              TSP:MSG:FPAR (PPAR FOUND)
                              TSP:MSG:PAR OK (ID=0, dist=1)
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:CHKID:OK (ID=10)
                              TSM:UPL
                              TSP:PING:SEND (dest=0)
                              TSP:MSG:PONG RECV (hops=1)
                              TSP:CHKUPL:OK
                              TSM:UPL:OK
                              TSM:READY
                              Init complete, id=10, parent=0, distance=1, registration=1
                              Battery Voltage: 0.00 V
                              Battery Voltage: 5.91 V
                                Gateway ok:
                                0;255;0;0;18;2.0.0
                                10;255;0;0;17;2.0.0
                                10;255;3;0;6;0
                                Node ok:
                                TSM:INIT
                                RF24:flushRX
                                TSM:RADIO:OK
                                TSM:FPAR
                                RF24:stop listening
                                RF24:flushTX
                                RF24:MAX_RT
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                TSP:CHKUPL:OK
                                TSM:UPL:OK
                                TSM:READY
                                A Offline
                                A Offline
                                AWI
                                @Walyson-Albuquerque-Machado Back to one of your previous posts. What kind of LCD display are you using. Do you have one with I2C interface?
                                  Hey. I don't have I2C interface. Do I need it?
                                  I have one like this, 20x4:
                                    A Offline
                                    A Offline
                                    AWI
                                    @Walyson-Albuquerque-Machado It is much easier to connect an I2C display (only 2 wires and power).But if you have pins left on your arduino and the patience to solder you're ok.
                                    an adapter plate:
                                      I have pins and I have already done this. :stuck_out_tongue_closed_eyes:
                                        Is that how I send ? Can I use BINARY to my hall effect sensor? I'm using the digital pin to count every time it passes through a magnet.
                                        MyMessage msg(NODE_ID, V_STATUS);
                                        float value = 0;
                                            present(NODE_ID, S_BINARY);
                                            send(msg.set(value));
                                        Is that how I receive?
                                            // Handle incoming message
                                          Please, someone tell me how to get the voltage that i'm receiving. I've tried many things, I don't know why this doesn't work.
                                          msgvolt.getFloat();
                                          I can see the battery in the gateway through serial, but I don't know how to get it to show on the LCD.
                                          Node:
                                          #define MY_DEBUG_VERBOSE_RF24
                                          #define DESTINATION_NODE 0
                                          #define MY_NODE_ID 10
                                          #define MY_PARENT_NODE_ID  0
                                          #define MY_RF24_CE_PIN 9
                                          #define MY_RF24_CS_PIN 10
                                          #define MY_RF24_PA_LEVEL_GW RF24_PA_LOW
                                          #define MY_RF24_CHANNEL 76
                                          #define MY_RF24_DATARATE RF24_250KBPS
                                          float R1 = 28000.0;
                                          float R2 = 7600.0;
                                          float voltsporUnidade = 0.005278592; // 5%1023
                                          float dadosenviados;
                                          MyMessage msgvolt(4, V_VOLTAGE);
                                            pinMode(A0, INPUT);
                                          void presentation() {
                                             sendSketchInfo("Battery Meter", "1.0");
                                             present(4, S_MULTIMETER, "Voltage", true);
                                            dadosenviados = mediaTotalTensaoDC / amostragem;
                                             Serial.print(dadosenviados);
                                             Serial.println(" V");
                                           send(msgvolt.setDestination(DESTINATION_NODE).set(dadosenviados, 2), 1);
                                            wait(2000);
                                          Gateway:
                                          #define MY_GATEWAY_SERIAL
                                          #define MY_NODE_ID 0
                                          #define DESTINATION_NODE 10
                                          float dadosenviados = 0;
                                            lcd.begin(20, 4);
                                            lcd.clear();
                                            delay(5000);
                                            delay(5000);
                                            lcd.clear();
                                                sendSketchInfo("Battery Meter", "2.0");
                                                present(4, S_MULTIMETER);
                                          void receive(const MyMessage &msgvolt) {
                                            saveState(msgvolt.sensor, msgvolt.getFloat());
                                           dadosenviados = msgvolt.getFloat();
                                          request(4, V_VOLTAGE, 10);
                                          void incomingMessage(const MyMessage &msgvolt) {
                                              lcd.clear();
                                              lcd.print(dadosenviados);
                                              lcd.print("VOLTS");
                                              lcd.print(msgvolt.getFloat());
                                              wait(1000);
                                                Serial.print("Battery Voltage: ")`;
