  2. Announcements
  3. 💬 MyController.org
💬 MyController.org
12 Posts 9 Posters 8.7k Views 9 Watching
    This thread contains comments for the article "MyController.org" posted on MySensors.org.
    • D
      D
      den2k
      Got this to work. Very nice.
      • maghacM
        maghacM
        maghac
        Would it be possible to use this ONLY to manage OTA updates for a network of MySensors nodes using the MQTT protocol? I have a ESP8266 based MQTT gateway but I'm using a different controller.
        J 1 Reply Last reply
        • maghacM maghac
          J
          J
          jkandasa
          @maghac I guess it is possible by filtering topic only for firmware type
          V 1 Reply Last reply
          • J jkandasa
            V
            V
            vikasjee
            @jkandasa Will it be possible to provide a step procedure tutorial?
            • mppM
              mppM
              mpp
              I'd love to help provide a step by step guide but I can't get it to work properly with the ESP MQTT gateway and Pro Mini RFM69 nodes. Does this controller support MY_NODE_ID AUTO?
              MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
              • mppM mpp
                @mpp from the mqtt build page: "NOTE: No controller supports dynamic ID assignment through MQTT"
                mppM 1 Reply Last reply
                  mppM
                  mppM
                  mpp
                  Thanks @mfalkvidd, the table on the controller page says yes for “node ID generation" which seems to contradict this?
                  Setting the ID manually still results in no parent being found though.
                  mfalkviddM J 2 Replies Last reply
                  • mppM mpp
                    @mpp It could probably be made clearer, but it is not totally contradicting. I don't use mycontroller myself but I would guess it supports node id generation for serial gateways and ethernet gateways and wifi gateways.
                    • mppM mpp
                      J
                      J
                      jkandasa
                      wrote on last edited by jkandasa
                      @mpp Yes, MyController.org supports MY_NODE_ID AUTO in any gateway (Serial, Ethernet or MQTT)
                      On Status >> Resources logs page can you check, Does MyController receives ID request from your node?
                      • G
                        G
                        Guillermo Schimmel
                        Great worl. Still prefer OpenHAB for my home automation, but for sensor management and OTA seems to be the way to go. Thanks!
                        • S
                          Serg2055
                          Good afternoon. Please tell me how to add the firmware for the node to the system. So that I could then shoot it through the air.
