  3. Sample: ESP gateway with sensor
2 Posts 2 Posters 1.7k Views 2 Watching
  • G
    G
    gloob
    Does anybody have a sample of an ESP gateway with a local sensor attached?
    Currently I'm not able to find out how this can be done.
    I just want to send an increasing integer value to the controller (FHEM) each 5 minutes, to check if the connection is okay in the controller.
    AWIA 1 Reply Last reply
    • G gloob
      AWIA
      AWIA
      AWI
      @gloob I only commented out my network id/ passw/ and ip config
      A counter is included ;-)
       * Version 1.0 - Henrik EKblad
       * Contribution by Ivo Pullens (ESP8266 support)
       * The EthernetGateway sends data received from sensors to the WiFi link.
       * VERA CONFIGURATION:
       * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
       * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
       * LED purposes:
       * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
       * nRF24L01+  ESP8266
       * VCC        VCC
       * CE         GPIO4
       * CSN/CS     GPIO15
       * SCK        GPIO14
       * MISO       GPIO12
       * MOSI       GPIO13
       * GND        GND
        * Inclusion mode button:
      #define MY_BAUD_RATE 9600
      #define MY_RF24_CHANNEL 83										// radio channel, default = 76
      #define MY_GATEWAY_ESP8266
      #define MY_ESP8266_SSID "<your SSID"
      #define MY_ESP8266_PASSWORD "<your passw>"
      #define MY_IP_ADDRESS 192,168,2,120
      #define MY_IP_GATEWAY_ADDRESS 192,168,2,254
      #define MY_PORT 5003
      // Enable inclusion mode
      // #define MY_INCLUSION_BUTTON_FEATURE
      // Set blinking period
      // #define MY_DEFAULT_LED_BLINK_PERIOD 300
      // Flash leds on rx/tx/err
      // Led pins used if blinking feature is enabled above
      #if defined(MY_USE_UDP)
        #include <WiFiUdp.h>
      #define NODE_TXT "AWI_ESP 120"									// Text to add to sensor name
      #include <ESP8266WiFi.h>
      unsigned long SLEEP_TIME = 10000; 								// Sleep time between reports (in milliseconds)
      #define CHILD_ID 1   											// Id of the sensor child
      #define CHILD_ID2 2   											// Id of the sensor child
      //#define LED_GREEN 12
      //#define LED_BLUE  13
      #define LED_RED   16
      //#define ADC A0
      // Initialize message
      MyMessage msg(CHILD_ID, V_PERCENTAGE);
      MyMessage msg2(CHILD_ID2, V_TEXT);
      int messageCounter = 0 ;										// Count the outgoing messages for validation (0..99)
        delay(1);
      void presentation() {
        sendSketchInfo(NODE_TXT, "1.0");
        present(CHILD_ID, S_DIMMER, NODE_TXT " dimmer");
        present(CHILD_ID2, S_INFO, NODE_TXT " text");
       	send(msg.set(messageCounter)); 										// Send message to gw
      	messageCounter = ++messageCounter % 100 ;							// wrap
      	send(msg2.set("Hallo")); 											// Send message to gw
      	// Send update every SLEEP_TIME
      	wait(SLEEP_TIME) ;
      void receive(const MyMessage &message) {  								// messages from node or controller
      	//char printBuf[40] ;
      	//Serial.print(message.getInt());
      		//sprintf(printBuf, "Message node: %d %d  OK\n", message.sender, message.getInt());
      	//Serial.print(printBuf) ;
      	//sprintf(printBuf, "Messages: %d Errors: %d\n", messageCounter, messageErrorCounter);
