  3. MySensors protocol page improvement recommendation
5 Posts 4 Posters 1.5k Views 4 Watching
  • DerTommD
    DerTommD
    DerTomm
    Hi MySensors team,
    as I am working a lot with the MySensors library at the moment, I just found a little inconsistency between the API and the protocol documentation (https://www.mysensors.org/download/serial_api_20).
    The documentation says that messages consists of these parts: node-id ; child-sensor-id ; message-type ; ack ; sub-type ; payload.
    In the source code (class MyMessage.h) you don't use "message-type" and "sub-type" but instead "command" and "(message) type".
    As I think the latter terms are more suitable for the protocol understanding I'd like to raise the discussion whether it would we better using "command-type" and "message-type" in the protocol documentation as well instead. Then docs and sources would be "in sync" again and I think the protocol structure would be even better understandable.
    Finally another little improvement request: The protocol docs are still talking about "Serial Protocol - 2.0.x" - maybe you should update this to "2.x". :-)
    Best regards,
    Thomas
      Thanks, updated.
      • DerTommD
        DerTommD
        DerTomm
        Nice, thanks for the quick response. :-)
        • F
          F
          Fabien
          Another typo i think : for S_WATER_QUALITY you have V_STATUS but in V_STATUS line you don't reference S_WATER_QUALITY.
          • F
            F
            flopp
            also found typo
            V_STATUS missing S_BINARY, S_WATER_QUALITY
            V_LIGHT missing S_BINARY
            V_WATT missing S_BINARY, S_RGB_LIGHT, S_RGBW_LIGHT
            V_PERCENTAGE missing S_COVER
            V_TEMP missing S_WATER_QUALITY
            S_HEATER missing V_STATUS, V_HVAC_SETPOINT_HEAT
            S_HVAC missing V_STATUS, V_TEMP, V_HVAC_SPEED
            V_HVAC_SETPOINT_COLD is missing
