  3. Controller to Sensor communication problem
serial protocolcontroller
3 Posts 2 Posters 2.3k Views 1 Watching
    A Former User
    my setup has two Arduino UNO R3: one is connected with USB to my laptop running SerialGateway.ino, and the other is running ServoActuator.ino.
    I am about to write my own controller in Java by using the serial gateway looking at the code from https://github.com/mysensors/Vera/blob/master/L_Arduino.lua.
    My problem is that in ServoActuator.ino the callback void incomingMessage(const MyMessage &message) {...} is never called.
    For example the setup() of ServoActuator.ino sends a 0;10;2;0;3;1.4.1 message to the controller. My controller replies with 0;10;1;0;3;0 but that message does not reach the sensor.
    I did also the message exchange manually (with a terminal, no controller at all) but nothing works.
    By going looking at the MySensors code the call to boolean MySensor::sendRoute(MyMessage &message) just return false whatever I do. I think I miss something so that getChildRoute(dest) returns the correct routing to the sensor.
    Please let me know what I do wrong.
    Thanks,
    George G.
      A Former User
      the problem is solved by sending 1 instead of 0 to the sensor during: 255;255;3;0;3; request. So, now I replay with 255:255:3;0;4;1 instead of 255;255;3;0;4;0 and when I get the request 1;10;2;0;3;1.4.1 I reply with 1;10;1;0;3;0 which goes back to the sensor.
      Kind Regards,
      George.
      • daulagariD
        daulagariD
        daulagari
        Yes I think node-id 0 should not be used.
