  3. MQTT MySensors gateway via serial/ESP8266
4 Posts 3 Posters 1.5k Views 3 Watching
  • L Offline
    L Offline
    LastSamurai
    wrote on last edited by LastSamurai
    I am currently using a serial gateway but I am thinking about switching to an MQTT one (or adding an additional one, is that supported?). Do I absosultely have to have one of these ethernet adapters for a MQTT gateway or can it be done via a serial or a ESP8266 gateway too (I already have the hardware for these here).
    Btw @hek I am currently getting lots of Error 400 messages for some socket.io ULR in the browser console and needed several tries to write this.
    • H Offline
      H Offline
      Yes, I've noticed this as well. Tried a lot of things during the weekend to resolve the problem but didn't succeed.
      I will upgrade the server during the evening (downtime expected) to a LTS release and add the possibility to run the latest nginx (where I think the problem is).
      • L LastSamurai
        @LastSamurai it is possible to run mqtt on the esp8266.
        L 1 Reply Last reply
          L Offline
          L Offline
          LastSamurai
          @mfalkvidd Thank you, I guess I will use the ESP then.
          Or perhaps I will try to write a script to use MQTT with the serial gateway... why add another network layer (WiFi) if you don't have to...
          12.1k
