  3. Relais sketch, auto switch on again after x seconds
9 Posts 5 Posters 3.7k Views 4 Watching
  • CorvlC Offline
    CorvlC Offline
    Corvl
    Hello everyone,
    I just build a simple single relais , using the sketch from the examples. ( see also below) . Is it possible to change it a bit , so the relais when switched off , switches on again automatically after for example 5 seconds?
    Thanks,
    Cor
    // Example sketch showing how to control physical relays.
    // This example will remember relay state even after power failure.
      gw.sendSketchInfo("Relay", "1.0");
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      gw.process();
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    • rejoe2R Offline
      rejoe2R Offline
      rejoe2
      Hi Cor,
      this ain't no big deal, you may just study my example in https://github.com/rejoe2/MySensors_Small/blob/master/MyS103/MyS103.ino.
      You have to store the sitch off-time, check in loop(), if your intended off-time has past and then switch on again, ideally informing your controller about the node having done so.
      Btw: your sketch is for MySensors Version 1.x. You may have to make additional changes to transfer my code back.
      • mfalkviddM Offline
        The solution in https://forum.mysensors.org/post/58102 could be good as a base. It waits for 0.5 seconds.
        • CorvlC Offline
          CorvlC Offline
          Corvl
          wrote on last edited by Corvl
          No big deal :cold_sweat:
          I tried with the code from mfalkvidd , change what I though looked good.
          But I get the error in compiling:
          RelayActuator.ino: In function 'void setup()':
          RelayActuator.ino:28:30: error: 'RELAY_Off' was not declared in this scope
          RelayActuator.ino:30:10: error: 'wait' was not declared in this scope
          RelayActuator.ino:31:19: error: 'RELAY_On' was not declared in this scope
          RelayActuator.ino: In function 'void incomingMessage(const MyMessage&)':
          RelayActuator.ino:47:27: error: 'RELAY_Off' was not declared in this scope
          RelayActuator.ino:49:9: error: 'wait' was not declared in this scope
          RelayActuator.ino:50:40: error: 'RELAY_On' was not declared in this scope
          Error compiling
          This is what I did:
          I changed exactly what was in that code , but since I didn't have "loadState" but I did have "gw.loadState" I changed it in "gw.loadState" but also "Loadstate"gives an error compling.
           if (gw.loadState(sensor) == RELAY_Off) {
          digitalWrite(pin, RELAY_Off);
          wait(5000);
          digitalWrite(pin, RELAY_On);
            gw.process();
           if (message.getBool() == RELAY_Off) {
          digitalWrite(message.sensor-1+RELAY_1, RELAY_Off);
          wait(500);
          digitalWrite(message.sensor-1+RELAY_1, RELAY_On);
          Boots33B 1 Reply Last reply
          • CorvlC Corvl
            Error compiling
            This is what I did:
            wait(5000);
              gw.process();
            wait(500);
            Boots33B Offline
            Boots33B Offline
            Boots33
            @Corvl What version of MySensors are you using. the sketch you have is for the earlier 1.xx version. If possible you should move to MySensors version 2
            • CorvlC Offline
              CorvlC Offline
              Corvl
              @ Boots33: both my vera's are running with version 1.5 . Can I just update , will the sketches wich are now running still work?
              • CorvlC Corvl
                B Offline
                B Offline
                BartE
                @Corvl yes you should be able to upgrade.byt you have top upgrade the gateway aswel.
                It is quicker to solve the compile errors:
                Do note that C in case sensitive so
                • change RELAY_Off to RELAY_OFF on line 28 and 47
                • change RELAY_On to RELAY_ON on line 31 and 50
                Since you use the old library you also should change wait to gw.wait on line 30 and 49
                That should fix the compiler error.
                I think the second gw.wait should also be 5000 iso 500 if you want to wait 5 seconds also.
                As a general comment, when programming C it is general practice to use indents for beter readability of the code so please add some whitespace in front of the added lines
                • CorvlC Offline
                  CorvlC Offline
                  Corvl
                  Thanks,
                  I am thinking of upgrading to 2.x , not sure yet if that is wise. Just made another topic for some questions.
                  Thanks so far,
                  Cor
                  • CorvlC Offline
                    CorvlC Offline
                    Corvl
                    @ BartE , thanks a lot , I changed all the _Off to _OFF and the same with the On , gw. wait as well. also the 500 to 5000
                    Working perfectly !
                    Many thanks
                    I haven't had a definite anwer yet if libabry 2.x works on vera , I have only read about problems . For the moment I stick to 1.5
                    edit : one small thing I just noticed , when I switch via the vera Gui the relais to off , it nicely goes back to on after 5 seconds , but it doesn't report back to vera that it is again in an on state.
                    is there still something wrong with the code?
                    Again many thanks,
                    Cor
                    For future reference:
                         if (gw.loadState(sensor) == RELAY_OFF) {
                         digitalWrite(pin, RELAY_OFF);
                         gw.wait(5000);
                         digitalWrite(pin, RELAY_ON);
                      gw.process();
                     if (message.getBool() == RELAY_OFF) {
                    digitalWrite(message.sensor-1+RELAY_1, RELAY_OFF);
                    gw.wait(5000);
                    digitalWrite(message.sensor-1+RELAY_1, RELAY_ON);
