  3. Battery based atmega328p sensor (no SMD)
12 Posts 4 Posters 3.3k Views 4 Watching
  • M Offline
    M Offline
    Markus.
    Hi all,
    Well, iam starting to learn to use pcbs. I have now two of above mentioned sensor boards. But im anot sure how i connect the batterrys for the power supply or the Ftdi usb adapter for programming. Is there a kind of cabling diagramm available where i can see how and where which connection must be done?
    Many thanks
    Markus
    K 1 Reply Last reply
    • M Markus.
      Hi all,
      Many thanks
      Markus
      K Offline
      K Offline
      kimot
      @Markus.
      Hi.
      What you exactly mean "above mentioned sensor boards" ?
      I do not see any info about some boards.
      ATmega328p is type of processor only.
      • F Offline
        F Offline
        FotoFieber
        http://www.psyelmer9.info/blog/may-17th-2012
        You may need to set the fuses to disable bod and burn a bootloader with an ISP-Adapter.
        • M Offline
          M Offline
          Markus.
          Sorry i mean this one here
          https://www.openhardware.io/view/5/Battery-based-atmega328p-sensor-no-SMD
          And how must i connect the ftdi usb adapter to flash this board...
          Thx
          M 1 Reply Last reply
          • M Markus.
            Thx
            M Offline
            M Offline
            Markus.
            And how should i connect correctly the battery for the power supply? A complete cabeling diagramm would be great... :-)
            A 1 Reply Last reply
            • F Offline
              F Offline
              FotoFieber
              I found a label FTDI on one picture of the PCB. 😀
              I encourage you to read articles about arduino on breadboard and dive deeper or buy complete solutions like the sensebender micro.
              • M Markus.
                A Offline
                A Offline
                AWI
                @Markus. The ftdi connection is marked on the board. @GertSanders used a standard ftdi connector with 6 pins and "black" and "green" marking.
                • A AWI
                  M Offline
                  M Offline
                  Markus.
                  @AWI many thanks thats now clear for me. Sorry for all this questions but I've started to learn.... :-(
                  I can see on the board some 3,3 V Connections beside VCC and VBAT. Where is now the correct place to connect the Battery as power supply ?
                  Markus
                  • M Markus.
                    Markus
                    A Offline
                    A Offline
                    AWI
                    @Markus. From my perspective @GertSanders has done a great job in documenting the board, but there are many options.
                    0_1487839791325_upload-015d0f54-3e86-4972-9ced-211bd758d7ae This is the place where you determine what is connected to Vcc and battery. If you don't use an external regulator, just make connections indicated and any 3v3, Vcc and vbat connection can be used.
                    If you operate from 2 AA cells then probably your next question is leading to burning the fuses for operating at low voltages ;-)
                    • M Offline
                      M Offline
                      Markus.
                      wrote on last edited by Markus.
                      yes thats the idea to operate themwith 2xAA cells.... ;-) So it means that I can use each GND conenction for Minus and each 3V3 connction for plus....
                      Ohhh hell.. :-) And what exactly do you mean with "burning the fuses for operating at low voltages" ?? Thought I can simple connect my Minus from the Battery to a Connection on the board and also the Plus to get it working with Batterys...:-(
                      What I also not understand is .."If powered by two AA or AAA batteries, the circuits VCC and 3V3 should be connected. This is done by shorting jumper "J1"." ...
                      Hope I will understand all this in the next 100 years .. :-)
                      • M Markus.
                        A Offline
                        A Offline
                        AWI
                        @Markus. "shorting jumper J1' is equivalent to the right blue line in my last post.
                        "fuses for operating at low voltages" means you need to program the AVR processor so that it can operate at low voltages (< 2.7 volt). this needs to be done with a special programming circuit. So you either keep your batteries above 2.7 volt or dive into the world of Fuse programming.
                        • A AWI
                          M Offline
                          M Offline
                          Markus.
                          @AWI So I will Keep my batterys above 2.7 Volts ..:-)
                          So in Summary... Hope its now correct
                          1. Shorting the 3V3 Connections (right site of the Picture)
                          2. plus from Battery to VBAT
                          3. minus to any GND
                          Any many many thanks for your Patience !!!!
