  3. API Structure Datatypes
3 Posts 3 Posters 1.2k Views 5 Watching
  • AndyDHillA
    AndyDHillA
    AndyDHill
    In the Serial API pages we can find a table that show the correlation, between type of sensor and data structure that can be used , eg a switch will be of type S_Binary and S_ Binary has elements of V_Status & V_Watt so far all well and good. But when we come to write C code be should be disciplined in our data type and we should be typecasting or ensuring that the data we pass into V_Watt is correct type w shouldn;t be passing in a DINT when V_Watt if it is defined as type Real (float), Similarly we should only pass Bool into S_Status if it is defined as bool, but it could be defined as sint?
    This leads to my Question, is there a table showing the data types (Bool, Float, Int, Din, Sint etc) for each of these elements. ?
    Type		                  Data Type
    V_TEMP		                     ?INT
    V_HUM		                     ?INT
    V_STATUS		             ?BOOL
    V_PERCENTAGE		             ?INT
    V_PRESSURE		             ?INT
    V_FORECAST		             ??????
    V_RAIN
    V_RAINRATE
    V_WIND
    V_GUST
    V_DIRECTION
    V_UV
    V_WEIGHT
    V_DISTANCE
    V_IMPEDANCE
    V_ARMED
    V_TRIPPED
    V_WATT
    V_KWH
    V_SCENE_ON
    V_SCENE_OFF
    V_HVAC_FLOW_STATE
    V_HVAC_SPEED
    V_LIGHT_LEVEL
    V_VAR1
    V_VAR2
    V_VAR3
    V_VAR4
    V_VAR5
    V_UP
    V_DOWN
    V_STOP
    V_IR_SEND
    V_IR_RECEIVE
    V_FLOW
    V_VOLUME
    V_LOCK_STATUS
    V_LEVEL
    V_VOLTAGE
    V_CURRENT
    V_RGB
    V_RGBW
    V_ID
    V_UNIT_PREFIX
    V_HVAC_SETPOINT_COOL
    V_HVAC_SETPOINT_HEAT
    V_HVAC_FLOW_MODE
    V_TEXT
    V_CUSTOM
    V_POSITION
    V_IR_RECORD
    V_PH
    V_ORP
    V_EC
    V_VAR
    V_VA
    V_POWER_FACTOR
    So can anyone complete the above table ?
    K 1 Reply Last reply
      This little Javascript data structure might help you (used by a thing I'm working on). Not 100% mappable to C but you should be able to read out the assumed data types.
      let parseB = function(x) {
        return x === "1" ? 1:0;
      let serializeB = function(x) {
        if (!x)
          return "0";
        return x==="1"?"1":"0";
      let parseS = function(x) {
        return striptags(x.toString());
      let serializeS = function(x) {
        if (!x)
          return "";
        return x.toString();
      let parseRGB = function(x) {
        if (x.length() != 6)
          return null;
        try {
          let r = parseInt(x.substr(0,2), 16);
          let g = parseInt(x.substr(2,2), 16);
          let b = parseInt(x.substr(4,2), 16);
          if (isNaN(r) && isNaN(g) && isNaN(b))
            return null;
          return {r: r, g: g, b: b };
        } catch (e) {
        return null;
      let serializeRGB = function(x) {
        if (!x || !x.r || !x.g || !x.b)
          return "";
        return x.r.toString(16) + x.g.toString(16) + x.b.toString(16);
      let parseRGBW = function(x) {
        if (x.length() != 8)
          return null;
        try {
          let w = parseInt(x.substr(6,2), 16);
          if (isNaN(r) && isNaN(g) && isNaN(b) && isNaN(w))
            return null;
          return {r: r, g: g, b: b, w: w };
        } catch (e) {
          return null;
      let serializeRGBW = function(x) {
        if (!x || !x.r || !x.g || !x.b || !x.w)
          return "";
        return x.r.toString(16) + x.g.toString(16) + x.b.toString(16) + x.w.toString(16);
      let parsePos = function(x) {
        return x.split(";");
      let serializePos = function(x) {
        if (!x || !Array.isArray(x))
          return "";
        return x.join(";");
      let parseF = function(x) {
        try {
          let f = Number.parseFloat(x);
          return isNaN(f) ? null : f;
        } catch (e) {
           return null;
      let serializeF = function(x) {
        if (x===undefined || x==="")
          return "";
      let parseI = function(x) {
        try {
          let i = Number.parseInt(x, 10);
          return isNaN(i) ? null : i;
        } catch (e) {
           return null;
      let serializeI = function(x) {
        if (!x)
          return "";
      let parseP = function(x) {
        try {
            return isNaN(i) ? null : Math.min(Math.max(0,i),100);
        } catch (e) {
          return null;
      let serializeP = function(x) {
        if (!x)
          return "0";
      let allowedForecast = ["stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown"];
      let parseForecast = function(x) {
        if(allowedForecast.indexOf(x)>=0)
          return x;
        return "unknown";
      let serializeForecast = function(x) {
          return x;
        return "unknown";
      let allowedFlowState = ["Off", "HeatOn", "CoolOn", "AutoChangeOver"];
      let parseFlowState = function(x) {
        if(allowedFlowState.indexOf(x)>=0)
          return x;
        return null;
      let serializeFlowState = function(x) {
          return x;
        return "";
      let allowedHvacSpeed = ["Min", "Normal", "Max", "Auto"];
      let parseHvacSpeed = function(x) {
        if(allowedHvacSpeed.indexOf(x)>=0)
          return x;
        return null;
      let serializeHvacSpeed = function(x) {
          return x;
        return "";
      let allowedHvacFlowMode = ["Auto", "ContinuousOn", "PeriodicOn"];
      let parseHvacFlowMode = function(x) {
        if(allowedHvacFlowMode.indexOf(x)>=0)
          return x;
        return null;
      let serializeHvacFlowMode = function(x) {
          return x;
        return "";
      let vars = module.exports.vars = {
          TEMP: {
            title: "Temperature",
            parse: parseF,
            serialize: serializeF,
            type: "numeric",
            unit: {I: "°F", M: "°C"},
          HUM : {
            title: "Humidity",
            parse: parseP,
            serialize: serializeP,
            type: "numeric",
            unit: {I: "%", M: "%"},
            min:0,
            max:100
          BINARY : {
            title: "Binary value",
            opts: {
              1: {
                title: "On",
                icon: "binary-1.png"
              0: {
                title: "Off",
                icon: "binary-0.png"
            type: "binary",
            parse: parseB,
            serialize: serializeB,
          PERCENTAGE : {
            title: "Percentage",
            parse: parseP,
            type: "numeric",
            min: 0,
            max: 100,
          PRESSURE : {
            title: "Pressure",
            parse: parseF,
            unit: {I: "hPa", M: "hPa"},
            decimals: 1,
            type: "numeric",
          FORECAST : {
            title: "Forecast",
            opts: {
              stable: {
                icon: "forecast-stable.png",
                title: "Stable"
              sunny: {
                icon: "forecast-sunny.png",
                title: "Sunny"
              cloudy: {
                icon: "forecast-cloudy.png",
                title: "Cloudy"
              unstable: {
                icon: "forecast-unstable.png",
                title: "Unstable"
              thunderstorm: {
                icon: "forecast-thunderstorm.png",
                title: "Thunderstorm"
              unknown: {
                icon: "forecast-unknown.png",
                title: "Unknown"
            parse: parseForecast,
            serialize: serializeForecast,
            type: "text",
          RAIN : {
            title: "Rain",
            parse: parseF,
            unit: {I: "in", M: "mm"},
            decimals: 1,
            type: "numeric",
          RAINRATE : {
            title: "Rain Rate",
            parse: parseF,
            unit: {I: "in/h", M: "mm/h"},
            decimals: 1,
            type: "numeric",
          WIND : {
            title: "Wind",
            parse: parseF,
            unit: {I: "mph", M: "m/s"} ,   // Knots?
            decimals: 1,
            type: "numeric",
          GUST : {
            title: "Gust",
            parse: parseF,
            unit: {I: "mph", M: "m/s"},
            decimals: 1,
            type: "numeric",
          DIRECTION : {
            title: "Direction",
            parse: parseF,        // Should come in as degrees from north
            unit: {I: "°", M: "°"},
            type: "numeric",
          UV : {
            title: "UV Level",
            parse: parseI,
            serialize: serializeI,
            type: "numeric",
          WEIGHT : {
            title: "Weight",
            parse: parseF,
            unit: {I: "lb", M: "kg"},
            decimals: 1,
            type: "numeric",
          DISTANCE : {
            title: "Distance",
            parse: parseF,
            unit: {I: "in", M: "cm"},
            type: "numeric",
          IMPEDANCE : {
            title: "Impedance",
            parse: parseF,
            unit: {I: "Ω", M: "Ω"},
            type: "numeric",
          ARMED : {
            title: "Armed Status",
            parse: parseB,
            type: "binary",
          TRIPPED : {
            title: "Tripped Status",
            opts: {
              1: {
                title: "Tripped",
                icon: "door-1.png"
              0: {
                title: "Untripped",
                icon: "door-0.png"
            parse: parseB,
            type: "binary",
            sensors: {
              DOOR: {
                opts: {
                  1: {
                    title: "Open",
                    icon: "door-1.png"
                  0: {
                    title: "Closed",
                    icon: "door-0.png"
              MOTION: {
                opts: {
                  1: {
                    title: "Motion",
                    icon: "motion-1.png"
                  0: {
                    title: "No Motion",
                    icon: "motion-0.png"
              SMOKE: {
                opts: {
                  1: {
                    title: "Fire!",
                    icon: "smoke-1.png"
                  0: {
                    title: "No Fire",
                    icon: "smoke-0.png"
          WATT : {
            title: "Watt",
            parse: parseF,
            unit: {I: "W", M: "W"},
            decimals: 0,
            default: 0,
            type: "numeric",
          KWH : {
            title: "Energy Used",
            parse: parseF,
            unit: {I: "kWh", M: "kWh"},
            decimals: 1,
            type: "numeric",
          SCENE_ON : {
            title: "Scene On",
            parse: parseI,
            type: "numeric",
          SCENE_OFF : {
            title: "Scene Off",
            parse: parseI,
            type: "numeric",
          HVAC_FLOW_STATE : {
            title: "HVAC Flow State",
            opts: {
              Off: { title: "Off"},
              HeatOn: { title: "Heat On"},
              CoolOn: { title: "Cool On" },
              AutoChangeOver: { title: "Auto" }
            parse: parseFlowState,
            serialize: serializeFlowState,
            type: "text",
          HVAC_SPEED : {
            title: "HVAC Speed",
            parse: parseHvacSpeed,
            serialize: serializeHvacSpeed,
            opts: {
              Min: { title: "Min"},
              Normal: { title: "Normal"},
              Max: { title: "Max"},
              Auto: { title: "Auto"}
            type: "text",
          LIGHT_LEVEL : {
            title: "Light Level",
            parse: parseP,
            type: "numeric",
            min: 0,
            max: 100,
          VAR1 : {
            title: "Var 1",
            parse: parseS,
            serialize: serializeS,
            type: "text",
          VAR2 : {
            title: "Var 2",
            parse: parseS,
            type: "text",
          VAR3 : {
            title: "Var 3",
            parse: parseS,
            type: "text",
          VAR4 : {
            title: "Var 4",
            parse: parseS,
            type: "text",
          VAR5 : {
            title: "Var 5",
            parse: parseS,
            type: "text",
          UP : {
            title: "Up",
            command: true,
            parse: parseS,
            type: "action",
          DOWN : {
            title: "Down",
            parse: parseS,
            type: "action",
          STOP : {
            title: "Stop",
            parse: parseS,
            type: "action",
          IR_SEND : {
            title: "IR Send",
            parse: parseI,
            type: "numeric",
          IR_RECEIVE : {
            title: "IR Received",
            parse: parseI,
            type: "numeric",
          FLOW : {
            title: "Flow",
            parse: parseF,
            sensors: {
              WATER: { unit: {I: "gal/min", M: "l/s"} },
              GAS: { unit: {I: "scfm", M: "scm/h"} },
            decimals: 1,
            type: "numeric",
          VOLUME : {
            title: "Volume",
            parse: parseF,
            sensors: {
              WATER: { unit: {I: "gal", M: "l"} },
              GAS: { unit: {I: "SCF", M: "Nm³"} },
            type: "numeric",
          LOCK_STATUS : {
            title: "Lock Status",
            parse: parseB,
            opts: {
              0: {
                title: "Open",
                icon: "lock-0.png"
              1: {
                title: "Lock",
                icon: "lock-1.png"
            type: "binary",
          LEVEL : {
            title: "Level",
            parse: parseF,
            sensors: {
              AIR_QUALITY: { unit: { I: "mg/m³", M: "mg/m³"} },
              DUST: { unit: {I: "mg/m³", M: "mg/m³"} },
              SOUND: { unit: {I: "dB", M: "dB"} },
              VIBRATION: { unit: {I: "Hz", M: "Hz"} },
              LIGHT_LEVEL: { unit: {I: "Lux", M: "Lux"} },
              MOISTURE: { unit: {I: "", M: ""} },
            decimals: 1,
            type: "numeric",
          VOLTAGE : {
            title: "Voltage",
            parse: parseF,
            unit: {I: "V", M: "V"},
            decimals: 1,
            type: "numeric",
          CURRENT : {
            title: "Current",
            parse: parseF,
            unit: {I: "A", M: "A"},
            decimals: 1,
            type: "numeric",
          RGB : {
            title: "RGB Color",
            parse: parseRGB,
            serialize: serializeRGB,
            type: "rgb",
          RGBW : {
            title: "RGBW Color",
            parse: parseRGBW,
            serialize: serializeRGBW,
            type: "rgbw",
            title: "Id",
            parse: parseS,
            type: "text",
          UNIT_PREFIX : {
            title: "Unit Prefix",
            parse: parseS,
            type: "text"
          HVAC_SETPOINT_COOL : {
            title: "HVAC Setpoint Cool",
            parse: parseP,
            decimals: 1,
            type: "numeric",
            min:0,
            max:100,
          HVAC_SETPOINT_HEAT : {
            title: "HVAC Setpoint Heat",
            parse: parseP,
            decimals: 1,
            type: "numeric",
            min:0,
            max:100,
          HVAC_FLOW_MODE : {
            parse: parseHvacFlowMode,
            serialize: serializeHvacFlowMode,
            opts: {
              Auto: {title: "Auto"},
              ContinuousOn: { title: "Continuous On"},
              PeriodicOn: {title: "Periodic On"}
            type: "text",
          TEXT : {
            title: "Text",
            parse: parseS,
            type: "text",
          CUSTOM : {
            title: "Custom",
            parse: parseS,
            type: "text",
          POSITION : {
            title: "Position",
            parse: parsePos,
            serialize: serializePos,
            type: "map",
          IR_RECORD : {
            title: "IR Record",
            parse: parseI,
            type: "numeric",
          PH : {
            title: "PH",
            parse: parseF,
            decimals: 1,
            type: "numeric",
          ORP : {
            title: "ORP",
            parse: parseF,
            unit: {I: "mV", M: "mV"},
            decimals: 1,
            type: "numeric",
          EC : {
            title: "EC",
            parse: parseF,
            unit: {I: "μS/cm", M: "μS/cm"},
            decimals: 1,
            type: "numeric",
          VAR : {
            title: "Reactive Power",
            parse: parseF,
            unit: {I: "VAR", M: "VAR"},
            decimals: 1,
            type: "numeric",
          VA : {
            title: "Apparent Power",
            parse: parseF,
            unit: {I: "VA", M: "VA"},
            decimals: 1,
            type: "numeric",
          POWER_FACTOR : {
            title: "Power Factor",
            parse: parseF,
            unit: {I: "", M: ""},
            decimals: 1,
            type: "numeric",
          // Internal variables used by web interface
          I_BATTERY_LEVEL : {
            title: "Battery Level",
            parse: parseP,
            unit: "%",
            type: "numeric",
      • AndyDHillA AndyDHill
        Type		                  Data Type
        V_TEMP		                     ?INT
        V_HUM		                     ?INT
        V_STATUS		             ?BOOL
        V_PERCENTAGE		             ?INT
        V_PRESSURE		             ?INT
        V_FORECAST		             ??????
        V_RAIN
        V_RAINRATE
        V_WIND
        V_GUST
        V_DIRECTION
        V_UV
        V_WEIGHT
        V_DISTANCE
        V_IMPEDANCE
        V_ARMED
        V_TRIPPED
        V_WATT
        V_KWH
        V_SCENE_ON
        V_SCENE_OFF
        V_HVAC_FLOW_STATE
        V_HVAC_SPEED
        V_LIGHT_LEVEL
        V_VAR1
        V_VAR2
        V_VAR3
        V_VAR4
        V_VAR5
        V_UP
        V_DOWN
        V_STOP
        V_IR_SEND
        V_IR_RECEIVE
        V_FLOW
        V_VOLUME
        V_LOCK_STATUS
        V_LEVEL
        V_VOLTAGE
        V_CURRENT
        V_RGB
        V_RGBW
        V_ID
        V_UNIT_PREFIX
        V_HVAC_FLOW_MODE
        V_TEXT
        V_CUSTOM
        V_POSITION
        V_IR_RECORD
        V_PH
        V_ORP
        V_EC
        V_VAR
        V_VA
        V_POWER_FACTOR
        K
        K
        kimot
        @AndyDHill
        Look at "MockMySensors" sketch in MySensors examples. Maybe it helps with some types.
