  3. MyS not working on solar sensor board
23 Posts 5 Posters 5.2k Views 5 Watching
  • Sergio RiusS
    Sergio RiusS
    Sergio Rius
    the board is @ceech s one, I don't think there is anything wrong with it, but I can't make it work with mysensors. My testing sketch is the one provided with the board, just adding MySensors declerations and radio initialisation.
    First I tought this issue was related, but after swapping to the development version, the problem still occurs:
    0 MCO:BGN:INIT NODE,CP=R-NNA---,VER=2.2.0-beta
    4 TSM:INIT
    4 TSF:WUR:MS=0
    6 RF24:INIT
    8 RF24:INIT:PIN,CE=9,CS=10
    10 RF24:WBR:REG=0,VAL=14
    18 RF24:WBR:REG=3,VAL=3
    20 RF24:WBR:REG=4,VAL=95
    22 RF24:WBR:REG=5,VAL=76
    26 RF24:WBR:REG=6,VAL=37
    28 RF24:WBR:REG=16,VAL=115
    30 RF24:WBR:REG=29,VAL=6
    34 RF24:RBR:REG=6,VAL=0
    36 RF24:RBR:REG=5,VAL=0
    38 !RF24:INIT:SANCHK FAIL
    40 !TSM:INIT:TSP FAIL
    45 TSM:FAIL:CNT=1
    45 TSM:FAIL:DIS
    47 TSF:TDI:TSL
    49 RF24:SLP
    51 RF24:WBR:REG=0,VAL=12
    10055 TSM:FAIL:RE-INIT
    10057 TSM:INIT
    10059 RF24:INIT
    10061 RF24:INIT:PIN,CE=9,CS=10
    10063 RF24:WBR:REG=0,VAL=14
    10072 RF24:WBR:REG=3,VAL=3
    10074 RF24:WBR:REG=4,VAL=95
    10078 RF24:WBR:REG=5,VAL=76
    10080 RF24:WBR:REG=6,VAL=37
    10084 RF24:WBR:REG=16,VAL=115
    10086 RF24:WBR:REG=29,VAL=6
    10090 RF24:RBR:REG=6,VAL=127
    10092 RF24:RBR:REG=5,VAL=255
    10096 !RF24:INIT:SANCHK FAIL
    10098 !TSM:INIT:TSP FAIL
    10102 TSM:FAIL:CNT=2
    10104 TSM:FAIL:DIS
    10106 TSF:TDI:TSL
    10108 RF24:SLP
    10110 RF24:WBR:REG=0,VAL=12
    • C
      C
      ceech
      Try basic board's functionality first, over Serial monitor for example and work from there.
      • Sergio RiusS
        Sergio RiusS
        Sergio Rius
        wrote on last edited by Sergio Rius
        If you mean, uploading your sample sketch, yes, that worked without problem.
        But MySensors resists to work.
        • Sergio RiusS
          Sergio RiusS
          Sergio Rius
          Correction, the sample sketch just shows:
          HTU21D-F test
          Couldn't find sensor!
          Seems that can be something with the board.
          • C
            C
            ceech
            It is the new sensor on your board. The BME280.
            Here is the library for it:
            https://github.com/sparkfun/SparkFun_BME280_Arduino_Library
            Use I2C_ReadAllData example. And the sensor's address is 0x76, not 0x77
            Sergio RiusS 1 Reply Last reply
            • C ceech
              Sergio RiusS
              Sergio RiusS
              Sergio Rius
              @ceech said in MyS not working on solar sensor board:
              I2C_ReadAllData
              Well it returns some weird negative altitude data, and temperature and humidity seems to be a little off, but I guess it also may have something to initially adjust altitude.
              • C
                C
                ceech
                Initial altitude is calculated based on pressure and needs adjustment.
                • C ceech
                  Sergio RiusS
                  Sergio RiusS
                  Sergio Rius
                  Do you know how to do it? I can't find nothing on the api
                  • C
                    C
                    ceech
                    I don't, sorry.
                    • Sergio RiusS
                      Sergio RiusS
                      Sergio Rius
                      What I can't understand is why the board has been working more than one week with the SFE_BMP180 library, to the point that I was doing adjustments and now I must work with sparkfun one's.
                      Well, then that sensor will be of no use.
                      Temperature: 28.39 degrees C
                      Temperature: 83.10 degrees F
                      Pressure: 101515.85 Pa
                      Altitude: -16.42m
                      Altitude: -53.86ft
                      %RH: 55.80 %
                      The temperature and humidity are off more than three points and altitude by 50mts.
                      • C
                        C
                        ceech
                        Give it a while. It's new. It will calibrate in time. Also you can calibrate it yourself.
                        • C
                          C
                          ceech
                          The BMP180 sensor is from the same family. Parts of the code probably works on both.
                          • Sergio RiusS
                            Sergio RiusS
                            Sergio Rius
                            Ok, so leaving the sensor aside, this is the correct position for the NRF radio module?
                            First I'd directly soldered it, but as it wasn't working I desoldered it, resoldered a connector and tested with all my NRF modules, even with the ones on duty. The board always outputs a radio error:
                            4 TSM:INIT
                            4 TSF:WUR:MS=0
                            6 RF24:write register, reg=0, value=14
                            14 RF24:write register, reg=3, value=3
                            18 RF24:write register, reg=4, value=95
                            22 RF24:write register, reg=5, value=76
                            26 RF24:write register, reg=6, value=39
                            30 RF24:write register, reg=16, value=115
                            36 RF24:write register, reg=29, value=6
                            40 RF24:read register, reg=6, value=255
                            45 RF24:read register, reg=5, value=255
                            49 !RF24:INIT:SANCHK FAIL
                            51 !TSM:INIT:TSP FAIL
                            53 TSM:FAIL:CNT=1
                            55 TSM:FAIL:PDT
                            57 RF24:write register, reg=0, value=12
                            61 RF24:PD
                            Also with MySensors version 2.0.0:
                            TSM:INIT
                            RF24:Sanity check failed: configuration mismatch! Check wiring, replace module or non-P version
                            !TSM:RADIO:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            RF24:power down
                            @ceech Do you have a mysensors working board? Which version?
                            Could this be a faulty one or something must be configured for mysensors?
                            • C
                              C
                              ceech
                              I can't say what's wrong. Can you send it back and I'll take a look at it?
                              • Sergio RiusS
                                Sergio RiusS
                                Sergio Rius
                                I can, just send me your address through MP or to my email.
                                Is the following configuration right for the resistor values you modified for my 7.2v batt?
                                float R1 = 47000.0; // resistance of R1
                                float R2 = 10000.0; // resistance of R2
                                You can also send me a working sketch and I'll upload and test it for you.
                                R 1 Reply Last reply
                                • Sergio RiusS Sergio Rius
                                  R
                                  R
                                  ramwal
                                  @Sergio-Rius
                                  It is a long time ago, but did you ever get a chance to solve the problem with this board? I have exactly the same problem as you explained in your message. In the past I bought a few of these boards, but never got so far to use them. Now I want to try them and @ceech is not appearing anymore on the forum.
                                  skywatchS Sergio RiusS 2 Replies Last reply
                                  • R ramwal
                                    @Sergio-Rius
                                    skywatchS
                                    skywatchS
                                    skywatch
                                    @ramwal Have you made the line "const float ALTITUDE = " correct for your location in the sketch?
                                    • skywatchS skywatch
                                      R
                                      R
                                      ramwal
                                      @skywatch
                                      Yes, I did filled in the altitude, but I think that's not the problem, because after starting the program it stays with the sanity check fail of the radio Nrf24l01, with the verbose debug. So it has definitely to do with this particular board and the radio. The radio's I use are working on other standard Arduino's. So the radio is OK. It is sad, that the board is not supported anymore by its creator!!
                                      I do not know how to go further! I can not make sense of the output. Anyway thanks for reacting.
                                      See here the verbose debug output:
                                      15:19:06.087 ->
                                      15:19:06.087 ->  __  __       ____
                                      15:19:06.087 -> |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
                                      15:19:06.087 -> | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __|
                                      15:19:06.123 -> | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
                                      15:19:06.123 -> |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
                                      15:19:06.123 ->         |___/                      2.3.2
                                      15:19:06.123 ->
                                      15:19:06.123 -> 16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=8,REL=255,VER=2.3.2
                                      15:19:06.123 -> 28 TSM:INIT
                                      15:19:06.123 -> 28 TSF:WUR:MS=0
                                      15:19:06.123 -> 30 RF24:INIT:PIN,CE=9,CS=10
                                      15:19:06.123 -> 34 RF24:SBY
                                      15:19:06.157 -> 34 RF24:WBR:REG=0,VAL=14
                                      15:19:06.157 -> 43 RF24:WBR:REG=3,VAL=3
                                      15:19:06.157 -> 45 RF24:WBR:REG=4,VAL=95
                                      15:19:06.157 -> 47 RF24:WBR:REG=5,VAL=76
                                      15:19:06.157 -> 51 RF24:WBR:REG=6,VAL=37
                                      15:19:06.157 -> 53 RF24:WBR:REG=29,VAL=4
                                      15:19:06.157 -> 55 RF24:RBR:REG=29,VAL=255
                                      15:19:06.157 -> 59 RF24:WBR:REG=16,VAL=115
                                      15:19:06.157 -> 61 RF24:WBR:REG=29,VAL=4
                                      15:19:06.157 -> 63 RF24:RBR:REG=6,VAL=255
                                      15:19:06.157 -> 67 !RF24:INIT:SANCHK FAIL
                                      15:19:06.157 -> 69 !TSM:INIT:TSP FAIL
                                      15:19:06.190 -> 71 TSM:FAIL:CNT=1
                                      15:19:06.190 -> 73 TSM:FAIL:DIS
                                      15:19:06.190 -> 75 TSF:TDI:TSL
                                      15:19:06.190 -> 77 RF24:SLP
                                      15:19:06.190 -> 77 RF24:WBR:REG=0,VAL=12
                                      15:19:16.161 -> 10082 TSM:FAIL:RE-INIT
                                      15:19:16.161 -> 10084 TSM:INIT
                                      15:19:16.161 -> 10086 RF24:INIT:PIN,CE=9,CS=10
                                      15:19:16.194 -> 10088 RF24:SBY
                                      15:19:16.194 -> 10090 RF24:WBR:REG=0,VAL=14
                                      15:19:16.194 -> 10098 RF24:WBR:REG=3,VAL=3
                                      15:19:16.194 -> 10100 RF24:WBR:REG=4,VAL=95
                                      15:19:16.194 -> 10104 RF24:WBR:REG=5,VAL=76
                                      15:19:16.194 -> 10106 RF24:WBR:REG=6,VAL=37
                                      15:19:16.194 -> 10110 RF24:WBR:REG=29,VAL=4
                                      15:19:16.194 -> 10113 RF24:RBR:REG=29,VAL=255
                                      15:19:16.194 -> 10117 RF24:WBR:REG=16,VAL=115
                                      15:19:16.194 -> 10119 RF24:WBR:REG=29,VAL=4
                                      15:19:16.194 -> 10123 RF24:RBR:REG=6,VAL=255
                                      15:19:16.194 -> 10125 !RF24:INIT:SANCHK FAIL
                                      15:19:16.227 -> 10129 !TSM:INIT:TSP FAIL
                                      15:19:16.227 -> 10131 TSM:FAIL:CNT=2
                                      15:19:16.227 -> 10133 TSM:FAIL:DIS
                                      15:19:16.227 -> 10135 TSF:TDI:TSL
                                      15:19:16.227 -> 10137 RF24:SLP
                                      rvendrameR skywatchS 2 Replies Last reply
                                      • R ramwal
                                        @skywatch
                                        15:19:06.087 ->
                                        15:19:06.123 ->
                                        rvendrameR
                                        rvendrameR
                                        rvendrame
                                        @ramwal
                                        These boards use a different CE and CS pins in Arduino. Try to add this BEFORE the #include <MySensors.h>:
                                        #define MY_RF24_CE_PIN 7 // Ceech Arista board
                                        #define MY_RF24_CS_PIN 8 // Ceech Arista board
                                        // Includes -------------------------------------------
                                        ESP8266 GW + mySensors 2.3.2
                                        Alexa / Google Home
                                        • R ramwal
                                          @skywatch
                                          15:19:06.087 ->
                                          15:19:06.123 ->
                                          skywatchS
                                          skywatchS
                                          skywatch
                                          @ramwal I have no experience of that board. You can only test all attached modules on other known working nodes. You could also try without mysensors in the sketch just to see. Finally the usual magnifying glass inspection of the PCB and all connections, solder joints etc.... But while typing this you got a really good lead from @rvendrame :)
