  3. double RelyWithButonActuator not working
3 Posts 2 Posters 1.2k Views 2 Watching
  • DickD
    DickD
    Dick
    wrote on last edited by Dick
    still strugling with multiple relais without using a class. in my code I duplicate the example of MySensors. testing the 2 relais both activate of the 2 defined buttons. so clicking one button, both relais activate, the same with the other button. How can I get it work and what is wrong in the code? If I test only one relay with one button that works fine.
     * Version 1.0 - Henrik Ekblad
     * Example sketch for a "light switch" where you can control light or something
     * else from both HA controller and a local physical button
     * (connected between digital pin 3 and GND).
     * This node also works as a repeader for other nodes
    #include <Bounce2.h>
    #define RELAY1_PIN  4  // Arduino Digital I/O pin number for relay
    #define BUTTON1_PIN  3  // Arduino Digital I/O pin number for button
    #define CHILD_ID_1 1   // Id of the sensor child
    #define RELAY2_PIN  6  // Arduino Digital I/O pin number for relay
    #define BUTTON2_PIN  5  // Arduino Digital I/O pin number for button
    #define CHILD_ID_2 2   // Id of the sensor child
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer1 = Bounce();
    int oldValue1=0;
    bool state1;
    Bounce debouncer2 = Bounce();
    int oldValue2=0;
    bool state2;
    MyMessage msg1(CHILD_ID_1,V_LIGHT);
    MyMessage msg2(CHILD_ID_2,V_LIGHT);
      gw.sendSketchInfo("Relay & Button", "1.0");
     // Setup the button
      pinMode(BUTTON1_PIN,INPUT);
      digitalWrite(BUTTON1_PIN,HIGH);
      pinMode(BUTTON2_PIN,INPUT);
      digitalWrite(BUTTON2_PIN,HIGH);
      debouncer1.attach(BUTTON1_PIN);
      debouncer1.interval(5);
      debouncer2.attach(BUTTON2_PIN);
      debouncer2.interval(5);
      gw.present(CHILD_ID_1, S_LIGHT);
      digitalWrite(RELAY1_PIN, RELAY_OFF);
      pinMode(RELAY1_PIN, OUTPUT);
      gw.present(CHILD_ID_2, S_LIGHT);
      digitalWrite(RELAY2_PIN, RELAY_OFF);
      pinMode(RELAY2_PIN, OUTPUT);
      state1 = gw.loadState(CHILD_ID_1);
      digitalWrite(RELAY1_PIN, state1?RELAY_ON:RELAY_OFF);
      state2 = gw.loadState(CHILD_ID_2);
      digitalWrite(RELAY2_PIN, state2?RELAY_ON:RELAY_OFF);
      gw.process();
      debouncer1.update();
      // Get the update value
      int value1 = debouncer1.read();
      if (value1 != oldValue1 && value1==0) {
          gw.send(msg1.set(state1?false:true), true); // Send new state and request ack back
      oldValue1 = value1;
        debouncer2.update();
      int value2 = debouncer2.read();
      if (value2 != oldValue2 && value2==0) {
          gw.send(msg2.set(state2?false:true), true); // Send new state and request ack back
      oldValue2 = value2;
      if (message.isAck()) {
         // Change relay state
         state1 = message.getBool();
         // Store state in eeprom
         gw.saveState(CHILD_ID_1, state1);
         state2 = message.getBool();
         gw.saveState(CHILD_ID_2, state2);
         // Write some debug info
         Serial.print(message.sensor);
    Boots33B 1 Reply Last reply
    • DickD Dick
      #define RELAY_ON 1
      #define RELAY_OFF 0
      int oldValue1=0;
      bool state1;
      int oldValue2=0;
      bool state2;
       // Setup the button
        gw.process();
        oldValue1 = value1;
        oldValue2 = value2;
      Boots33B
      Boots33B
      Boots33
      @Dick in your receive code you are not testing for which child the message is for, so both are being switched.
      You need to test what child the incoming message is for using message.sensor
      Try something like below.
      Also is there any reason you are still using MySensors V1.x
        switch (message.sensor) {
           case CHILD_ID_1:
            break;
        case CHILD_ID_2:
           break;
        default:
              Serial.print("Incoming sensor unknown");
      DickD 1 Reply Last reply
      • Boots33B Boots33
             case CHILD_ID_1:
              break;
          case CHILD_ID_2:
             break;
          default:
        DickD
        DickD
        Dick
        Thanks for the solution, I tested it and works fine now. In Answer to your question why I use the old version of MySensors, at the moment I am re-configurating my ne RP with the latest version of Domoticz. After that I will connect the latest MYsensors Gateway to it. If all the nodes keep on working on the new environment, there is not an immediate need to adjust the code of all my nodes. Is my approach correct? if not please reply.
