  3. Compilation Error for Arduino Pro or Pro Mini
29 Posts 5 Posters 7.3k Views 4 Watching
  • Daniel RuizD Offline
    Daniel Ruiz
    Hello everyone
    My problem is the following, with imported My Sensors libraries by simply performing the program check, I get the following error message:
    Exit status 1
    I started and it's been several days since I was looking for the solution, if a person could advise me.
    cordially
    Daniel
    • Daniel RuizD Daniel Ruiz
      Hello everyone
      Exit status 1
      cordially
      Daniel
      @Daniel-Ruiz welcome to the MySensors community.
      There should be more information in the output. Is this everything you are getting?
        Daniel Ruiz
        Good evening,
        Below you will find the details of the error message.
        I think I do not have to integrate the external library correctly.
        My problem occurs just with external libraries.
        cordially,
        Daniel
        C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Daniel\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Daniel\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Daniel\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10803 -build-path C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631 -warnings=none -build-cache C:\Users\Daniel\AppData\Local\Temp\arduino_cache_357691 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose C:\Users\Daniel\Documents\Arduino\sketch_jul30a\sketch_jul30a.ino
        C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Daniel\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Daniel\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Daniel\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10803 -build-path C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631 -warnings=none -build-cache C:\Users\Daniel\AppData\Local\Temp\arduino_cache_357691 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose C:\Users\Daniel\Documents\Arduino\sketch_jul30a\sketch_jul30a.ino
        Using board 'pro' from platform in folder: C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19
        Using core 'arduino' from platform in folder: C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19
        Detecting libraries used...
        "C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\cores\arduino" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\variants\eightanaloginputs" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631\sketch\sketch_jul30a.ino.cpp" -o "nul"
        "C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\cores\arduino" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\variants\eightanaloginputs" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\SPI\src" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631\sketch\sketch_jul30a.ino.cpp" -o "nul"
        "C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\cores\arduino" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\variants\eightanaloginputs" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631\sketch\sketch_jul30a.ino.cpp" -o "nul"
        "C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\cores\arduino" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\variants\eightanaloginputs" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631\sketch\sketch_jul30a.ino.cpp" -o "nul"
        "C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\cores\arduino" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\variants\eightanaloginputs" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631\sketch\sketch_jul30a.ino.cpp" -o "C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631\preproc\ctags_target_for_gcc_minus_e.cpp"
        In file included from C:\Users\Daniel\Documents\Arduino\sketch_jul30a\sketch_jul30a.ino:37:0:
        C:\Users\Daniel\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:22:21: fatal error: OneWire.h: No such file or directory
        #include <OneWire.h>
        compilation terminated.
        Utilisation de la bibliothèque SPI version 1.0 dans le dossier: C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\SPI
        Utilisation de la bibliothèque MySensors version 2.0.0 dans le dossier: C:\Users\Daniel\Documents\Arduino\libraries\MySensors
        Utilisation de la bibliothèque DallasTemperature prise dans le dossier : C:\Users\Daniel\Documents\Arduino\libraries\DallasTemperature (legacy)
        exit status 1
        Erreur de compilation pour la carte Arduino Pro or Pro Mini
          Good evening,
          cordially,
          Daniel
          exit status 1
          @Daniel-Ruiz which sketch are you trying to compile?
            Daniel Ruiz
            As I started, I wanted to start simple with two temperature probes.
            Dallas Temperature Sensor
            • B Offline
              B Offline
              Ben Andrewes
              Have you installed the onewire library?
                @Daniel-Ruiz Do you mean this one? https://www.mysensors.org/build/temp#example
                If that's the case you seem to have missed the step mentioned just above the code:
                This example uses a modified version of the external DTH library
                Follow the link to install it and you should be good to go.
                  Daniel Ruiz
                  Hello and thank you for your help.
                  I installed onewire library
                  I used the link: http://www.mysensors.org/build/temp#example
                  I no longer have the compile error message for the ARDUINO PRO MINI card
                  I now have as a message:
                  Exit status 1
                  'Class DallasTemperature' has no member named 'millisToWaitForConversion'
                  I was about to give up, still a little patience
                  Good night
                  Daniel
                  • B Offline
                    B Offline
                    Ben Andrewes
                    Hi Daniel
                    See @mfalkvidd 's post above - have you installed the custom DallasTemparature.h library as well? I had the same problem before and the reason was that I hadn't used this library...
                      Daniel Ruiz
                      Hello everyone,
                      The DALLAS TEMPARATURE .H library is well installed. I still have an error message:
                      rejoe2R 1 Reply Last reply
                        Hello everyone,
                        rejoe2R Offline
                        rejoe2R Offline
                        rejoe2
                        @Daniel-Ruiz
                        You may insert two things to get around this in your sketch:
                        Insert a line
                        int resolution = 12;
                        in the first part of the sketch and
                        conversionTime = 750 / (1 << (12 - resolution));
                        in before() or setup() section.
                        These are the relevant lines that went private for some time in the dallasTemperature-lib.
                          Daniel Ruiz
                          Thank you for your help.
                          I do not understand very well with the translation in French. Could you explain to me in more detail or I have to add the two lines.
                          DANIEL
                          rejoe2R D 2 Replies Last reply
                            DANIEL
                            rejoe2R Offline
                            rejoe2R Offline
                            rejoe2
                            @Daniel-Ruiz
                            Based on the original sketch:
                            int numSensors=0;
                            bool receivedConfig = false;
                            bool metric = true;
                            MyMessage msg(0,V_TEMP);
                            int resolution = 12;  //<---added
                            void before()
                              sensors.begin();
                              conversionTime = 750 / (1 << (12 - resolution)); //<---added
                              DANIEL
                              @Daniel-Ruiz Can we see your whole sketch?
                                Daniel Ruiz
                                [code]
                                • The MySensors Arduino library handles the wireless radio link and protocol
                                • between your home built sensors/actuators and HA controller of choice.
                                • The sensors forms a self healing radio network with optional repeaters. Each
                                • repeater and gateway builds a routing tables in EEPROM which keeps track of the
                                • network topology allowing messages to be routed to nodes.
                                • Created by Henrik Ekblad henrik.ekblad@mysensors.org
                                • Copyright (C) 2013-2015 Sensnology AB
                                • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
                                • Documentation: http://www.mysensors.org
                                • Support Forum: http://forum.mysensors.org
                                • This program is free software; you can redistribute it and/or
                                • modify it under the terms of the GNU General Public License
                                • version 2 as published by the Free Software Foundation.
                                • DESCRIPTION
                                • Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
                                • http://www.mysensors.org/build/temp
                                //#define MY_DEBUG
                                int numSensors=0;
                                bool metric = true;
                                void before()
                                sensors.begin();
                                void presentation() {
                                sendSketchInfo("Temperature Sensor", "1.1");
                                present(i, S_TEMP);
                                sleep(conversionTime);
                                float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                                #if COMPARE_TEMP == 1
                                #else
                                  send(msg.setSensor(i).set(temperature,1));
                                sleep(SLEEP_TIME);
                                [/code]
                                  [code]
                                  • DESCRIPTION
                                  //#define MY_DEBUG
                                  int numSensors=0;
                                  bool metric = true;
                                  void before()
                                  sensors.begin();
                                  present(i, S_TEMP);
                                  #else
                                  sleep(SLEEP_TIME);
                                  [/code]
                                  rejoe2R Offline
                                  rejoe2R Offline
                                  rejoe2
                                  @Daniel-Ruiz OK. Just to be sure:
                                  This sketch now is compiling and working as expected?
                                    Daniel Ruiz
                                    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Daniel\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10802 -build-path C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187 -warnings=none -build-cache C:\Users\Daniel\AppData\Local\Temp\arduino_cache_4544 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Daniel\Documents\Arduino\sketch_aug01a\sketch_aug01a.ino
                                    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Daniel\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10802 -build-path C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187 -warnings=none -build-cache C:\Users\Daniel\AppData\Local\Temp\arduino_cache_4544 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Daniel\Documents\Arduino\sketch_aug01a\sketch_aug01a.ino
                                    Using board 'pro' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
                                    Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
                                    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "nul"
                                    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "nul"
                                    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "nul"
                                    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "nul"
                                    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "nul"
                                    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul"
                                    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp\DallasTemperature.cpp" -o "nul"
                                    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Users\Daniel\Documents\Arduino\libraries\OneWire-master\OneWire.cpp" -o "nul"
                                    Generating function prototypes...
                                    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\preproc\ctags_target_for_gcc_minus_e.cpp"
                                    "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\preproc\ctags_target_for_gcc_minus_e.cpp"
                                    Compilation du croquis...
                                    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp.o"
                                    C:\Users\Daniel\Documents\Arduino\sketch_aug01a\sketch_aug01a.ino: In function 'void before()':
                                    sketch_aug01a:59: error: 'conversionTime' was not declared in this scope
                                    C:\Users\Daniel\Documents\Arduino\sketch_aug01a\sketch_aug01a.ino: In function 'void loop()':
                                    sketch_aug01a:87: error: 'class DallasTemperature' has no member named 'millisToWaitForConversion'
                                    Utilisation de la bibliothèque SPI version 1.0 dans le dossier: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
                                    Utilisation de la bibliothèque MySensors version 2.1.1 dans le dossier: C:\Users\Daniel\Documents\Arduino\libraries\MySensors
                                    Utilisation de la bibliothèque MAX31850_DallasTemp version 1.0.0 dans le dossier: C:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp
                                    Utilisation de la bibliothèque OneWire-master version 2.3.3 dans le dossier: C:\Users\Daniel\Documents\Arduino\libraries\OneWire-master
                                    exit status 1
                                      exit status 1
                                      rejoe2R Offline
                                      rejoe2R Offline
                                      rejoe2
                                      wrote on last edited by rejoe2
                                      @Daniel-Ruiz Thx.
                                      You may start the line with
                                      const int conversionTime = 750 / (1 << (12 - resolution));
                                      Sorry for letting that out...
                                        Daniel Ruiz
                                        @rejoe2 said in Compilation Error for Arduino Pro or Pro Mini:
                                        Sorry to bore you again.
                                        I have to add the two lines as you indicated.
                                        I now have a new errone message.
                                        Daniel
                                          Daniel
                                          rejoe2R Offline
                                          rejoe2R Offline
                                          rejoe2
                                          @Daniel-Ruiz Already noticed that.
                                          Fix above should work (newest version, had first vo check for the correct type of data type).
