  3. Move functions
Move functions
6 Posts 3 Posters 2.0k Views 4 Watching
    moskovskiy82
    I have merged two sketches together.
    The first one was on switches and the second one was if/else if
    So the first sketch was something like
    Switch
    case1
    case2
    End switch
    Sendcommand();
    Send status();
    And after moving in the second sketch it became
    Switch
    case1
    case2
    newcase3
    newcase4
    End switch
    Sendcommand();
    Send status();
    So now - everytime i issue commands that satisfy newcase3 and 4 - these two functions get executed. So i wonder how i can git rid of that... Can i just move them to the end of switch1 and 2 code?
    mfalkviddM dbemowskD 2 Replies Last reply
    • M moskovskiy82
      Switch
      case1
      case2
      End switch
      Sendcommand();
      Send status();
      Switch
      case1
      case2
      newcase3
      newcase4
      End switch
      Sendcommand();
      Send status();
      @moskovskiy82 yes
      You might want/need to add them to the default: case as well, if they should be run even if case1: and case2: didn't happen.
      • M moskovskiy82
        Switch
        case1
        case2
        End switch
        Sendcommand();
        Send status();
        Switch
        case1
        case2
        newcase3
        newcase4
        End switch
        Sendcommand();
        Send status();
        dbemowskD
        dbemowskD
        @moskovskiy82 I am a bit confused on your question. Can you post your whole sketch and explain more of what you want/don't want to happen?
          moskovskiy82
          Ok this is the part of sketch in question.
          You can see there are two functions in the end
          sendHeatpumpCommand();
          sendNewStateToGateway();
          They only concern HVAC and send an update to the AC. But they get called each time i change for example brightness for the RGB strip
            if (message.isAck()) {
               //return;
            Serial.print("Incoming message for: ");
            Serial.print(message.sensor);
            int val; //RGB VAR
            String recvData = message.data;
            recvData.trim();
            Serial.println(recvData);
            switch (message.type)
              case V_HVAC_SPEED:
                Serial.println("V_HVAC_SPEED");
                if(recvData.equalsIgnoreCase("auto"))
               FAN_STATE = 0;
               HA_FAN_STATE = "Auto";
                else if(recvData.equalsIgnoreCase("min"))
                   FAN_STATE = 1;
                   HA_FAN_STATE = "Min";
                else if(recvData.equalsIgnoreCase("normal"))
                   FAN_STATE = 2;
                   HA_FAN_STATE = "Normal";
                else if(recvData.equalsIgnoreCase("max"))
                   FAN_STATE = 3;
                   HA_FAN_STATE = "Max";
              break;
              case V_HVAC_SETPOINT_COOL:
                Serial.println("V_HVAC_SETPOINT_COOL");
                TEMP_STATE = message.getFloat();
                Serial.println(TEMP_STATE);
              break;
              case V_HVAC_FLOW_STATE:
                Serial.println("V_HVAC_FLOW_STATE");
                if (recvData.equalsIgnoreCase("coolon"))
                   POWER_STATE = 1;
                   MODE_STATE = MODE_COOL;
                   HA_MODE_STATE = "CoolOn";
                else if (recvData.equalsIgnoreCase("heaton"))
                   POWER_STATE = 1;
                   MODE_STATE = MODE_HEAT;
                   HA_MODE_STATE = "HeatOn";
                else if (recvData.equalsIgnoreCase("autochangeover"))
                   POWER_STATE = 1;
                   MODE_STATE = MODE_AUTO;
                   HA_MODE_STATE = "AutoChangeOver";
                else if (recvData.equalsIgnoreCase("off"))
                   POWER_STATE = 0;
                   HA_MODE_STATE = "Off";
                initialValueSent = true;
              break;
            case V_RGB:
               Serial.println( "V_RGB command: " );
               Serial.println(message.data);
               long number = (long) strtol( message.data, NULL, 16);
               // Save old value
               strcpy(rgbstring, message.data);
               // Split it up into r, g, b values
               red = number >> 16;
               green = number >> 8 & 0xFF;
               blue = number & 0xFF;
               send_status();
               set_hw_status();
            break;
            case V_LIGHT:
               Serial.println( "V_LIGHT command: " );
               val = atoi(message.data);
               if (val == 0 or val == 1)
                   on_off_status = val;
                   send_status();
                   set_hw_status();
            break;
            case V_DIMMER:
              Serial.print( "V_DIMMER command: " );
              if (val >= 0 and val <=100)
                dimmerlevel = val;
                send_status();
                set_hw_status();
            break;
            case V_VAR1:
              Serial.print( "V_VAR1 command: " );
              if (val >= 0 and val <= 2000)
                fadespeed = val;
            break;
          • M moskovskiy82
                 //return;
              int val; //RGB VAR
              recvData.trim();
                case V_HVAC_SPEED:
                 FAN_STATE = 0;
                     FAN_STATE = 1;
                     FAN_STATE = 2;
                     FAN_STATE = 3;
                break;
                break;
                     POWER_STATE = 1;
                     POWER_STATE = 1;
                     POWER_STATE = 1;
                     POWER_STATE = 0;
                break;
              case V_RGB:
                 // Save old value
                 red = number >> 16;
                 send_status();
                 set_hw_status();
              break;
              case V_LIGHT:
                     send_status();
                     set_hw_status();
              break;
              case V_DIMMER:
                  dimmerlevel = val;
                  send_status();
                  set_hw_status();
              break;
              case V_VAR1:
                  fadespeed = val;
              break;
            @moskovskiy82 move them to just before break; in the cases you want them to run?
              moskovskiy82
              Thank you. Will do so and report back
