  3. Domoticz
  4. Motion sensors
Motion sensors
4 Posts 2 Posters 2.4k Views 1 Watching
  • J Offline
    J Offline
    Jacek Slawinski
    Hi all
    Could you please help me?
    I want to hook more than one motion detector to arduino.
    In the program I see both sensors and contatron
    The first motion sensor works and the second one does not change states
    Contatron works
    What's wrong with the scripts?
    https://pastebin.com/baMUK4zj
    • J Jacek Slawinski
      Hi all
      Contatron works
      mfalkviddM Online
      mfalkviddM Online
      @Jacek-Slawinski welcome to the MySensors community!
      The code in your sketch first sleeps waiting for sensor1, then sleeps waiting for sensor2. So when "the other" sensor is triggered, the Arduino does not wake.
      Remove the first sleep and change the last sleep to something like
      wakeupReason = sleep(digitalPinToInterrupt(CzujnikRuchu1), CHANGE, digitalPinToInterrupt(CzujnikRuchu2), CHANGE, SLEEP_TIME);
      Then check the value of wakeupReason and act accordingly.
      See https://www.mysensors.org/download/sensor_api_20#sleeping for full description on how to sleep with two interrupt pins and how to use the return value of sleep().
      Also note that only some pins can be used for interrupt.
      • J Offline
        J Offline
        Jacek Slawinski
        wrote on last edited by Jacek Slawinski
        Thank you very much
        It works
        I add this
        sleep(digitalPinToInterrupt(CzujnikRuchu1), CHANGE, digitalPinToInterrupt(CzujnikRuchu2), CHANGE, SLEEP_TIME);``````
        Insert Code Here
        However, in the devices from time to time themselves add new ones not used.
        I don't know why
        foto
        • J Offline
          J Offline
          Jacek Slawinski
          Hi
          I have coneccted the arduino mega to RPI 3 via usb
          I can not handle the script on more than one motion sensor
          // Enable serial gateway
          #define MY_GATEWAY_SERIAL
          // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
          #if F_CPU == 8000000L
          #define MY_BAUD_RATE 38400
          // Enable inclusion mode
          #include <Bounce2.h>
          #define DIGITAL_INPUT_SENSOR 6   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
          #define DIGITAL_INPUT_SENSOR_2 7   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
          #define CHILD_ID_2 2   // Id of the sensor child
          // Initialize motion message
          MyMessage msg2(CHILD_ID_2, V_TRIPPED);
              pinMode(DIGITAL_INPUT_SENSOR_2, INPUT);
              sendSketchInfo("Motion Sensor", "1.0");
              present(CHILD_ID, S_MOTION);
              present(CHILD_ID_2, S_MOTION);
              // Read digital motion value
              bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
              Serial.println(tripped);
              send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
          {// Read digital motion value
              bool tripped = digitalRead(DIGITAL_INPUT_SENSOR_2) == HIGH;
              send(msg2.set(tripped?"1":"0"));  // Send tripped value to gw
              sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE,digitalPinToInterrupt(DIGITAL_INPUT_SENSOR_2), CHANGE, SLEEP_TIME);
          This script generates a lot of different sensors in the domoticz and should only two.
          I don't now why? :(
          When it erases:
           sleep(digitalPinToInterrupt(CzujnikRuchu1), CHANGE, digitalPinToInterrupt(CzujnikRuchu2), CHANGE, SLEEP_TIME); ``````
          It's the same
          Could you help me with this?
