  3. Sensor + Interrupt questions
14 Posts 5 Posters 4.0k Views 4 Watching
  • CrankyCoderC
    CrankyCoderC
    CrankyCoder
    Hey All,
    I have done some stuff with normal buttons and interrupts to wake up a node. I am wondering if anyone has done other stuff on the interrupts? Like a moisture/water sensor? im checking the feasibility of doing battery powered leak sensors. Seems like it would work since it's basically doing a button press by conducting through the water.
    Now, I know what the first response is.... just try it!! I would, but alas i don't have my water sensors here yet :laughing:
    thanks!
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • CrankyCoderC CrankyCoder
      Hey All,
      thanks!
      zboblamontZ
      zboblamontZ
      zboblamont
      @crankycoder :mag:
      • CrankyCoderC
        CrankyCoderC
        CrankyCoder
        I swear I did a search. But apparently I searched on one of my other community forums that had nothing to do with arduino or mysensors :laughing:
        helps when i search the right forum.
        www.CrankyCoder.net
        MySensors: 2.3
        • JohnRobJ
          JohnRobJ
          JohnRob
          wrote on last edited by JohnRob
          @CrankyCoder
          I have a similar (same?) sensor type running on a Pro mini.
          I uses a PNP to gain up the sensor current and ran it into INT1 . My RFM69 uses INTO.
          Works perfect. I've been running it on 3 AAA *** Carbon! batteries for a few months to see how long the batteries work. I can't yet estimate the battery life because I'm using the internal measurement of Vcc (which goes through the regulator).
          John
          *** updated, the original post stated 2 AAA batteries. This was in error.
          gohanG 1 Reply Last reply
          • CrankyCoderC
            CrankyCoderC
            CrankyCoder
            nice :)
            I ordered a couple of sensors yesterday so as soon as they come in ill start doing some testing with them.
            www.CrankyCoder.net
            MySensors: 2.3
            • JohnRobJ JohnRob
              @CrankyCoder
              John
              @johnrob why are you using the regulator?
              • JohnRobJ
                JohnRobJ
                JohnRob
                @CrankyCoder
                For sensors I'm using 4 stainless steel screws extending out the bottom of a plastic housing. They are spaced at the corners of a 5/8 square. I tested it with 2 screw and it worked fine but I went with 4 for the extra sense current.
                @gohan,
                I'm using 3 AAA batteries, my 2 AAA carbon battery statement was in error. When fresh the voltage exceeds the RFM69 input voltage specification.
                John
                  you could use 3 ni-mh and get rid of the regulator, that drains battery fast unless you use a low quiescent current one.
                  • D
                    D
                    David Cabañero
                    Hi CrankyCoder,
                    I have door/window sensors running using interruptions. I got rid of the regulator and the power led and I am using a step up converter to take as much juice as possible from the batteries. The oldest node has been running for a year already on 2 AA batteries so your project is definitely doable.
                    The problem could be in case the leak sensor throws a lot of false positives in which case it would drain the battery quicker.
                    I hope it helps.
                    David
                    [http://www.smarthomeblog.net]
                    CrankyCoderC 1 Reply Last reply
                    • D David Cabañero
                      Hi CrankyCoder,
                      I hope it helps.
                      David
                      CrankyCoderC
                      CrankyCoderC
                      CrankyCoder
                      @david-cabañero Thanks David, i just got a few of the step ups so I will give that a shot. Because of some of my other projects I have TONS of 18650 cells laying around so I figure those are decent batteries for this.
                      www.CrankyCoder.net
                      MySensors: 2.3
                        are you running your nodes at 5V?
                        • CrankyCoderC
                          CrankyCoderC
                          CrankyCoder
                          no, i have a couple that i am running at 3.3 off the 18650s. so far it's been pretty good just using the sleep
                          www.CrankyCoder.net
                          MySensors: 2.3
                          • D
                            D
                            David Cabañero
                            Hi @CrankyCoder ,
                            I think that 18650 will have plenty of juice for a project like this one.
                            Do you have an idea on how much does the water sensor consume in sleep mode? I am curious and I might actually go for the same project.
                            Which one are you using?
                            • CrankyCoderC
                              CrankyCoderC
                              CrankyCoder
                              not sure about in sleep mode. But here is the sensor i am using.
                              https://smile.amazon.com/gp/product/B00Q9YBIJI/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
                              www.CrankyCoder.net
                              MySensors: 2.3
