Sensebender gateway local sensor
Just a small question that i hope has a simple answer.
Can you at a sensor localy to the sensebender gateway ... -
@mfalkvidd said in Sensebender gateway local sensor:
@deluka yes. Just use present() and send() as you would on a normal sensor node.
So when using send() it will send the data directly into my Domoticz, which I use as Controller?
I use Gateway Serial.
