  3. Repeater when available
9 Posts 4 Posters 2.3k Views 3 Watching
  • ร
    ร
    รอเรือ
    Hi there.
    I've got a coffee brewer that currently acts as a repeater. If I go for a vacation, I'll probably unplug my coffee brewer. Would that impact my MySensors network badly (more bad than if there were never a repeater defined), that is, should I better remove the repeater function if I have the need to turn it off 2 weeks per year?
    Thanks!
    • ร รอเรือ
      Hi there.
      Thanks!
      If your other nodes can communicate without the repeater, I don't see any benefit from defining it as a repeater
      => do not use the coffee brewer as repeater.
      If your other nodes can't communicate without the repeater, unplugging it will cause the nodes to fail
      => you'll need another repeater anyway so do not use the coffee brewer as repeater.
      ร 1 Reply Last reply
      • CrankyCoderC
        CrankyCoderC
        CrankyCoder
        mfalkvidd im sure you can confirm if i have my understanding correct here. If you have a repeater and it's gone, the nodes will eventually try to do a find par(ent) again right? at that point they may or may not be able to rejoin the network?
        Home Automation Tinkerer
        www.CrankyCoder.net
        Gateway: MQTTClientGateway
        MySensors: 2.3
          ร
          ร
          รอเรือ
          @mfalkvidd
          Thanks!
          • CrankyCoderC CrankyCoder
            @crankycoder said in Repeater when available:
            Correct. If they are able to join the network, the repeater was not needed. If they are not able to join the network, another repeater is needed.
            • alowhumA
              alowhumA
              alowhum
              From my understanding: if your device does not run on batteries, always set it to work as a repeater. There are no downsides, and it will make your network more robust. If any device goes down for a bit, the sensors will route around it. Just like on the internet.
              • alowhumA alowhum
                ร
                ร
                รอเรือ
                @alowhum
                I believe it's very important that a repeater has a good communication with the gateway. I can imagine that a repeater with less than optimal communication with the gateway could make things worse.
                • alowhumA
                  alowhumA
                  alowhum
                  Of course. But if more devices are repeaters, chances are that they might bridge that bad connection with an extra hop in between. In a mesh network, the more help form that mesh, the better.
                  • CrankyCoderC
                    CrankyCoderC
                    CrankyCoder
                    Does adding ack to messages help trigger any failures if something can't deliver? ... well that didn't make much sense.
                    So lets say i have 2 repeaters on my network. i have a sensor that wakes up to report info. it normally goes to repeater1 -> gateway but repeater1 is acting up. Could you tell it to wait for an ack? after X amount of time with no ack would it trigger to find a new parent?
                    www.CrankyCoder.net
                    MySensors: 2.3
