  3. How far does the mesh stretch?
9 Posts 5 Posters 2.1k Views 4 Watching
  • alowhumA
    alowhumA
    alowhum
    What is the maximum amount of hops people have been able to reach? Is there a theoretical limit?
    For example, let's say there's a big construction project over the length of a street, and a group of people there together wanted to measure all kinds of things.
    • Neighbour 1 has an air quality sensor on their balcony
    • The next neighbour has a vibration sensor on their windowsill
    • The next neighbour has a dust sensor on their balcony
    • The next neighbour has a noise level sensor on their balcony, and a seismic sensor in their basement.
    • Etc.
    All of them would be repeaters.
    How many hops could that realistically go, while still having the one central data storage gathering point?
    • alowhumA alowhum
      • Etc.
      @alowhum MySensors is not a mesh. MySensors uses a tree topology.
      The theoretical limit for the number of hops between a node and the gateway is SIZE_ROUTES which is 256 hops.
      • alowhumA
        alowhumA
        alowhum
        Thanks, good point on the mesh. I considered the 'auto routing around issues' functionality to be a bit mesh-like, but you're right, there is a central point.
        While 256 is great in theory, what is the maximum number of hops people have reached in practice?
        • alowhumA alowhum
          @alowhum any normal user should be good with node > repeater > gw . Atleast that's my maximum.
          But I guess you could test by building some repeaters with forced node and parent id.
            A larger topology would most likely have high latency, messages could get lost and need to be resent more often than usual small network
            • alowhumA
              alowhumA
              alowhum
              @gohan That's what I thought as well. But I don't know: how bad is it?
              @sundberg84 Sure, I could test it. But I'm here to ask if anyone else already has :-)
              • CrankyCoderC
                CrankyCoderC
                CrankyCoder
                I would be really interested to see this put in practice. For stuff like those sensors I can't imagine a little extra latency being a terrible thing.
                Kind of makes me want to make a bunch of battery/solar nodes and just hide them places and see how far you can get a network to go :)
                Home Automation Tinkerer
                www.CrankyCoder.net
                Gateway: MQTTClientGateway
                MySensors: 2.3
                gohanG 1 Reply Last reply
                • CrankyCoderC CrankyCoder
                  @crankycoder for sensor is not a huge problem, but if you have a button controlling an actuator then latency is bad. Also lost messages would require multiple send and thus reducing battery life.
                  • alowhumA
                    alowhumA
                    alowhum
                    @CrankyCoder I heard that in the Netherlands at least there are technically no laws agains placing sensors in trees :-)
