  3. Send message for another node.
6 Posts 3 Posters 4.1k Views 2 Watching
  • D
    D
    derrij
    From sensor with ID 3 want to send message for scene controller ID 10.
    Can't see if it possible?
    May be possible add this way ?
    MyMessage msgOn(CHILD_ID_SCENE, V_SCENE_ON, NODE_ID);
    hekH 1 Reply Last reply
    • D derrij
      @derrij
      msgOn.setDestination(10);
      • D
        D
        derrij
        not good enough explained first time.
        I got Arduino SceneCtrl 13:3 and i can control it from this node.
        13;3;1;0;19;3
        13;3;1;0;20;3
        And I want send the same command to the gateway
        13;3;1;0;19;3
        13;3;1;0;20;3
        but from Node 10
          You'll have to do two sends to archive this.
          • D
            D
            derrij
            one from Node 10 to 13 with msgOn.setDestination(13);
            and redirect message through 13 to gateway
            am i understood right?
            • J
              J
              Jonas
              @hek
              I am currently trying to send a message from one node to another, but am facing some trouble with it.
              I have two nodes, both of them with Motion Sensors attached to them. I want one node to send a message
              to the other node when there is motion detected. On the other node, the received message should be saved in a variable.
              Looking through other posts I wasn't capable of finding an example I could modify for my purposes. I know there is this function for receiving messages:
              but how do I continue? Also, how to send a message? Can you pls give me example code for that?
