  3. CE line on sensor node?
29 Posts 6 Posters 10.1k Views 1 Watching
  • A Offline
    A Offline
    aquapro
    hello,
    very good project!
    I currently testing version 1.4b1 and I have a problem. Only if I disconnect the CE line on the sensor, the values ​​are transferred.
    If the CE line is connected, only one part will be sent, see Figure 1, the LED on the sensor remains on. As soon as I disconnect CE line, all values ​​are not sent are transmitted (Figure 2) and the LED goes out and lights up briefly in the next transmission.
    Does anyone have an idea?
    greeting
    aqua
    Figure1
    Figure 2
    D 1 Reply Last reply
    • Y Offline
      Y Offline
      Did you check-double-check the connections? You didn't swap e.g. the CE/CSN pins by mistake?
      • A Offline
        A Offline
        aquapro
        I have tested 1000 times, wasted complete weekend. Rechecked with built up the wiring from scratch. Same Problem.
        Suppose I have swap the cables, which I doubt, why it works when I disconnect it completely?
        • Y Offline
          Y Offline
          Can you check with a different radio and/or Arduino?
          • A Offline
            A Offline
            aquapro
            Yes, checked with 5 Arduinos (all different vendor's) and 8 radios. Same Problem. I am totally confused.
            R 1 Reply Last reply
            • A aquapro
              R Offline
              R Offline
              RJ_Make
              @aquapro
              Have you tried all new wiring?
              RJ_Make
              • H Offline
                H Offline
                If you show a few pictures also (closeups!) it might help.
                • A Offline
                  A Offline
                  aquapro
                  If I disconnect orange wire (red marker on first sensor picture), sensor works fine.
                  Sensor figures:
                  Gateway figures:
                  R Y 2 Replies Last reply
                  • A aquapro
                    Sensor figures:
                    Gateway figures:
                    R Offline
                    R Offline
                    RJ_Make
                    @aquapro
                    I think I would connected the radio directly to the breadboard pins next to the Arduino with new wiring.
                    RJ_Make
                    • A Offline
                      A Offline
                      aquapro
                      @aquapro sagte:> Hi,
                      I have all the cables replaced, also new from different suppliers. I used the next pins on the Arduino. For the pictures I have to build something stretched to better overview.
                      • A aquapro
                        R Offline
                        R Offline
                        RJ_Make
                        @aquapro
                        So the pictures don't reflect the current wiring?
                        RJ_Make
                        • A Offline
                          A Offline
                          aquapro
                          Pictures reflect the curren?t wiring! Same Problem with closer wiring
                          • A aquapro
                            Sensor figures:
                            Gateway figures:
                            Y Offline
                            Y Offline
                            @aquapro The MySensors site (http://www.mysensors.org/build/connect_radio) gives the following wiring:
                            Arduino     nRF24
                            9           CE
                            10          CSN
                            13          SCK
                            11          MOSI
                            12          MISO
                            2           IRQ
                            These are the defaults for the library. CE & CSN you can adapt through the constructor of MySensor (did you do that?)
                            Looking at the pictures I have a hard time figuring out the connections for pins 8..12, while these are just the interesting part...
                            A 2 Replies Last reply
                            • A aquapro
                              hello,
                              very good project!
                              greeting
                              aqua
                              Figure1
                              Figure 2
                              Damme
                              Code Contributor
                              wrote on last edited by Damme
                              @aquapro Hmmmm
                              The chip on your looks like a blob more than this; You might have gotten a chinese ripoff .. I dont remember the chip name... Hmmmm hard to see!
                              edit:
                              maybe : http://forum.mysensors.org/topic/300/rfm73-experience/ ?
                              inverted CE?
                              Y R 2 Replies Last reply
                              • D Damme
                                @aquapro Hmmmm
                                edit:
                                inverted CE?
                                Y Offline
                                Y Offline
                                @Damme Sharp observation, dude!
                                Have a look at these: http://www.aliexpress.com/item/Free-shipping-10pcs-lot-NRF24L01-wireless-data-transmission-module-NRF24L01-wireless-module/1996222121.html
                                Claimed to be nRF24L01+!!
                                • D Damme
                                  @aquapro Hmmmm
                                  edit:
                                  inverted CE?
                                  R Offline
                                  R Offline
                                  RJ_Make
                                  @Damme
                                  Nice Catch Indeed!
                                  RJ_Make
                                  • Y Yveaux
                                    Arduino     nRF24
                                    9           CE
                                    10          CSN
                                    13          SCK
                                    11          MOSI
                                    12          MISO
                                    2           IRQ
                                    A Offline
                                    A Offline
                                    aquapro
                                    wrote on last edited by aquapro
                                    @Yveaux yes I checked wiring with (http://www.mysensors.org/build/connect_radio)
                                    more detail picture, hope so. (bad light)
                                    @Damme
                                    Chip is covered.
                                    • Y Yveaux
                                      Arduino     nRF24
                                      9           CE
                                      10          CSN
                                      13          SCK
                                      11          MOSI
                                      12          MISO
                                      2           IRQ
                                      A Offline
                                      A Offline
                                      aquapro
                                      @Yveaux
                                      Pin 8?
                                      Y D 2 Replies Last reply
                                      • A aquapro
                                        @Yveaux
                                        Pin 8?
                                        Y Offline
                                        Y Offline
                                        @aquapro said:
                                        Pin 8?
                                        It looked like you could have a connection to pin 8, but apparently (in the better pictures) you haven't...
                                        • A aquapro
                                          @Yveaux
                                          Pin 8?
                                          Damme
                                          Code Contributor
                                          @aquapro I dont think you got a nordic semiconductor nrf24l01, What I can find they are only in QFN package.
                                          http://www.nordicsemi.com/eng/Products/2.4GHz-RF/nRF24L01
                                          So the specs on that chip may be different. Maybe CE is inverted?
                                          12.2k
