Debug to a sd-card module?
Hi!
I have an idea i want to run by you guys before starting up.
I have sometimes random dropouts from my Nrf network - and i guess thats part of DIY. The node isnt fully tested and maybe behaves differently when the voltage drops, some hardware fails or the radio is re-oriented which causes bad reception...
My problem is, I want to know what happens and make my nodes more stable but removing the node from its position doesnt make the debug realistic.
My thought was to develop a second node, which have a sd-card module and writes the MySensors serial output to a sd-card. Is this possible? Am i re-inventing something here or making it to difficult?
I liked the idea @AWI had about remote debugging with V_TEXT but my major issues is the radio communication and I dont know it this is because bad hardware or the radio behaves worse when voltage drops.
Any ideas is appreciated.
Projectpage: https://forum.mysensors.org/topic/8040/the-logger-machine-short-and-long-term-serial-logging
It should be possible, with a couple of hacks to the core. I don't know if the atmega328 have enough program space for it though.
(the Sensebender GW have a SDCard interface directly on the board ;) )
@tbowmo Thanks!
To be clear, im talking about a second module/node which is removable and attachable to all other nodes with ftdi header. It would not have to include MySensors library/code if thats a problem with space.More of a clean arduino serial logger... attachable to all nodes which behaves bad (and have debug defined offcourse).
Great idea.
Creating a non-Mysensors "log node" that listens on serial and logs everything to sd card should be fairly easy. With serial debug on on the troublesome node, all that needs to be done is to connect the log node to the serial port of the troublesome node.
Hi!
@sundberg84 Is it the intention to make just a serial logger? i.e. attach the second node directly to the serial out of the "problem node". That would be very easy. In a few of my first postings and also I connected a bluetooth radio to the ftdi of the pro-mini. That way you can use a pc or phone bluetooth serial program to read and log the serial output.
@mfalkvidd - Thanks! My first thought was it should be easy... but i also thought that if it was easy someone else already made it.
@AWI - "just a serial logger" Yes, you are correct! A serial bluetooth output! Interesting... it meets my needs for most part! :) Hmmm... maybe one should make a new hardware... The MySensors Debug Logger or something...
Short term logging - bluetooth
Long term logging - sd-card
2xAA battery powered?This needs to be investigated! All input appreciated so keep it coming...
Thanks guys! -
Thanks guys!@sundberg84 I given one of my nodes the birth name "MySensors data logger" ;-). This one listens to a few of my nodes and writes the log data to an SD card.
If you search for 'Arduino serial logger" with google you get a plentitude of examples which do generic serial logging, either with or without time stamps. -
Another interesting option for debugging: http://jeelabs.org/wp-content/uploads/2015/06/24/ftdi-over-wifi-esp-bridge/index.html
But I did not test this yet. -
If you search for 'Arduino serial logger" with google you get a plentitude of examples which do generic serial logging, either with or without time stamps.@AWI - Ah, sorry :) I dont want to re-invent or steel something here (as you see in my first post). Im going to look more into whats out there. If you have a good working logger you can share im very happy! Its good with bluetooth but i also need a node which runs on battery if possible) to leave and log for say a week.
@karlheinz2000 - thanks - will look into that. It looks really promising!
Either way, im going to build or order something. I need a complete logger to make my system more stable.
hmm.. what about an ESP8266, with an sdcard interface, then you can attach to the serial port via WIFI directly, or read the log file stored on the sdcard, with a couple of web pages etc.
@tbowmo - also a great idea. I think the project mentioned by @karlheinz2000 was just that and it looks really promising. Ill dig more into this and let you know when I have some sort of solution for my needs.
Very nice ideas guys, which could really help the community diagnosing intermittent network issues!
I challenge you all to enter the Contest with a great design! :clap:@Yveaux - good idea! If someone with more spare time than me wants to give it a go, please do because I will never be able to finish for the contest ends :construction_worker:
I had a free day today and begun some sketching... any input?
Still going with the specs:- Battery (2xAA)
- Long term logging to SD card
- Short time logging through bluetooth
- Should last atleast 2 weeks on 2xAA
Old topic, and I will probably create a project on openhardware but im making some progress with this... hardware section is under testing... software for SD-card needs to be developed so still some time ahead before finished. 2 revision of the PCB and it probably needs another round (6 weeks delivery, yay!)
My next step as hardware developer will be some sort of sales from openhardware with assembled modules and not only PCB but my goal will be to sell them 1 and 1 for a resonable price for all that needs a debug machine.
And the name? Easy Debugger Module - The Serial Debug Killer! :joy:
Module is now working and can debug a MySensors node to both Bluetooth and SD card. Next and final step will be to check the booster circuit and make sure it can debug for 2 weeks on 2xAA bat (which was the goal).
I hope the next step will be a openhardware page with all the info nessecary to build one.
There's also OpenLog. Haven't tested yet, but just got one (China clone for about $4, Sparkfun $14.95). It's about the size of microSD card and logs all serial input. Spec says "2mA idle, 6mA at maximum recording rate" which means something like 2 weeks with 2xAA. One issue might be voltage, it says 3.3 - 12V input, don't know if it works unmodified with less, i.e. without step-up.
I might also like to use the BT you included in your version.
I'm actually using openlog for the software. Will post more info later. It's tested and open source so instead of reinventing the wheel Im trying to develop that code further for my module...
And then you will have Bluetooth and booster+ voltage regulator as well 👍
Specs with the sd card.module (without LEDs) are the same for my module so 2 weeks minimum are still the goal.
Coming along nice... some small bugs to kill but project alive and almost finished!
