  3. Motion, Temperature and Relay in 1 node
5 Posts 3 Posters 3.1k Views 1 Watching
  • H Offline
    H Offline
    Hausner
    I've been thinking about building motion, temperature and relay in 1 node, but would that be possible with a mini pro or a nano?
    tbowmoT 1 Reply Last reply
    • H Hausner
      tbowmoT Offline
      tbowmoT Offline
      tbowmo
      It's possible to do it, however you probably need to use as wallplug for power.
      / Thomas
      H 1 Reply Last reply
      • tbowmoT tbowmo
        / Thomas
        H Offline
        H Offline
        Hausner
        @tbowmo
        Yes, I was aware of the necessary wallplug, but that is OK as I would need to run the mains power to the relay anyway.
        Well, I better start coding then :)
        • N Offline
          N Offline
          NotYetRated
          I have a node with the same sensors. Currently on a nano, moving to pro when I get step-down's in. Works just fine. It will be auto controlling a second intake fan to my electronics closet at X temperature. For now, I just have it always on, but controllable via Vera, and logging the temp. Motion is there, I want it to trip a second relay for a light, at some point.
          • H Offline
            H Offline
            Hausner
            wrote on last edited by Hausner
            Cool :)
            This is my initial sketch, but i'm still tuning it.
            http://forum.mysensors.org/topic/597/motion-relay-sensor-sketch-help
            I need to figure out only to send GW messages on an update.
            11.8k
            113.2k
