  3. No forward link or gateway feature activated, but I did.
sonoffesp8266library
7 Posts 3 Posters 3.8k Views 4 Watching
  • nicomediaN
    nicomediaN
    nicomedia
    I made some code for a Sonoff relay, which has an esp8266 chipset. I defined MY_GATEWAY_ESP8266, but when I compile it gives me this error: No forward link or gateway feature activated.
    How can I solve it? I did define my gateway.
    • F
      F
      Fabien
      did you define the radio ?
      nicomediaN 1 Reply Last reply
        Did you define that before or after including MySensors.h?
          nicomediaN
          nicomediaN
          nicomedia
          @hek Tried both, doesn't make a difference. I'll include my sketch below.
          #include <MyConfig.h>
          // Modalità debug
          //#define MY_DEBUG
          // Baud rate seriale mod. debug
          #define MY_BAUD_RATE 9600
          //#define MY_RADIO_NRF24
          #define MY_GATEWAY_ESP8266
          #define MY_ESP8266_SSID "SSID"
          #define MY_ESP8266_PASSWORD "Password"
          //#define MY_USE_UDP
          #define MY_ESP8266_HOSTNAME "Sonoff1"
          //Porta in ascolto
          #define MY_PORT 5003
          // Numero massimo di client
          // Enable inclusion mode
          // #define MY_INCLUSION_BUTTON_FEATURE
          #define MY_REPEATER_FEATURE
          #define RELAY_1  12  // Pin del relè
          #define NUMBER_OF_RELAYS 1 // Numero di relè
          #define RELAY_ON 1  // Stato del pin per relè attivo
          #define RELAY_OFF 0 // Stato del pin per relè inattivo
          #if defined(MY_USE_UDP)
          #include <WiFiUdp.h>
          #include <ESP8266WiFi.h>
          void before()
              // Imposta il quale pin è quello del relè
              pinMode(pin, OUTPUT);
              // Imposta il relè allo stato precedente (in caso salti la luce)
          	  // Invia informazioni versione al gateway
              // Presenta i sensori locali al gateway
              present(sensor, S_BINARY);
            // Controllo il messaggio inviato
            if (message.type==V_STATUS) {
              // Cambia stato relè
              // Memorizza stato relè
              // Informazioni debug
              Serial.print("Cambiamento relè:");
              Serial.print(message.sensor);
              Serial.print(", Nuovo Stato:");
          • F Fabien
            nicomediaN
            nicomediaN
            nicomedia
            @Fabien I did but I got the same error
              Always put the include after the defines. The sketch posted above is wrong and will fail at compile time. And remove the MyConfig.h include.
                nicomediaN
                nicomediaN
                nicomedia
                @hek That did it! I included the library with the Arduino IDE and it put it on the top. Didn't know that, thanks!
