nRF5 action!
    I may have found a clue as to why the reset pin (pin0.21) on the nRF52832 isn't working.
    On the nRF52832 DK, I read the following register values:
    PSELRESET[0]=21
    PSELRESET[1]=21
    which is as expected. However, on the Ebyte nRF52832 module, I read those register values as:
    PSELRESET[0]=4294967295
    PSELRESET[1]=4294967295
    which makes no sense. The values match, but they don't correspond to a pin number that can represent RESET.
    These two registers are described in the nRF52832 datasheet.
    @NeverDie not sure if you've already noticed, but 4294967295 is the maximum value for an unsigned 32-bit integer. So the value is 0xFFFFFFFF. That often means uninitialized. I don't know why it would be uninitialized though.
    @mfalkvidd
    Maybe because they just never were?
    Those particular registers are "The user information configuration registers (UICRs) are non-volatile memory (NVM) registers for configuring user specific settings." So, it would seem that initializing them just once would be enough, since they're non-volatile.
    In any case, good catch! It explains both why they are that value and also why they match.
    4294967295
    Also, since 4294967295 equals 0xFFFFFFFF, then bit 31 is a '1', which, according to the datasheet, means the pin is disconnected (see section 14.1.60 PSELRESET[0] of the datasheet for the detail].
    There's a chance we may have unwittingly done it ourselves! Remember back to when we were doing an explicit "Erase All"? From the datasheet:
    11.5 Erase all
    When erase is enabled, the whole Flash and UICR can be erased in one operation by using the ERASEALL
    register.
    Furthermore, from page 29 of the datasheet:
    After erasing UICR all bits in UICR are set to '1'.
    This is part of the arduino-nrf5 code -> https://github.com/sandeepmistry/arduino-nRF5/blob/dc53980c8bac27898fca90d8ecb268e11111edc1/cores/nRF5/SDK/components/toolchain/system_nrf52.c#L156
    I don't have any idea why this is not included in the binary. When the reset menu is selected then "-DCONFIG_GPIO_AS_PINRESET" is given to gcc.
    When system_nrf52.c is completely ignored, then the erratas are not handled.
    Here is some verbose code which properly sets the registers to use pin P0.21 as the RESET pin:
    Serial.println("Testing...");
    delay(10000);  //give preparation time to open serial tty
    Serial.print(counter);
    Serial.print(", PSELRESET[0]=");
    Serial.println(NRF_UICR-> PSELRESET[0]);
    Serial.print(counter++);
    Serial.print(", PSELRESET[1]=");
    Serial.println(NRF_UICR-> PSELRESET[1]);
    Serial.println();
    Serial.println("Write-enabling CONFIG.");
    Serial.println();
    Serial.println("Now designating pin pO.21 as the RESET pin.");
    NRF_UICR-> PSELRESET[0]=21;  //designate pin pO.21 as the RESET pin
    NRF_UICR-> PSELRESET[1]=21;  //designate pin pO.21 as the RESET pin
    Serial.println();
    Serial.println("Confirming that RESET pin assigment took hold:");
    Serial.println();
    Serial.println("Return CONFIG to read-only mode.");
    Running it once seems to be good enough, unless there were to occur another "Erase All" or "Burn bootloader" event.
    Here is the output from running the code which shows that it succeeded:
    Testing...
    0, PSELRESET[0]=4294967295
    0, PSELRESET[1]=4294967295
    1, PSELRESET[0]=21
    1, PSELRESET[1]=21
    Until a more elegant solution can be found, I'm using this in the setup() routine as the workaround:
      if (((NRF_UICR-> PSELRESET[0])==0xFFFFFFFF) && ((NRF_UICR-> PSELRESET[1])==0xFFFFFFFF)) { //if the two RESET registers are erased
        NRF_UICR-> PSELRESET[0]=21;  //designate pin P0.21 as the RESET pin
        NRF_UICR-> PSELRESET[1]=21;  //designate pin P0.21 as the RESET pin
    The code has the positive virtue of not writing to the RESET rregisters unless both registers are erased. That helps ensure that the non-volatile memory does not get worn out prematurely.
    Good news! I've confirmed that doing this does indeed solve the problem I previously had with the EByte nRF52832 module not reacting to a reset on pin P0.21. After inserting the above code block into the nRF52832's setup() routine, I can now, using ESP-LINK, remotely reset an nRF52832 module:
    With that issue now settled, I'm moving on to a different topic: what happens if you put the radio into Tx mode, but with an empty buffer (i.e. nothing to send)? In this scenario an RFM69 transmits a continuous pre-amble, and I'm wondering whether the nRF52832 does the same?
    With an empty buffer, does it transmit anything at all? Anyone happen to know?
    The reason I ask is that I want to program the radio to send a continuous signal so as to quickly wake-up a receiver. With packets, there's the lag time of receiving and decoding the packet, rather than just reacting to a high RSSI. In this way, I can use much narrower listen windows and thereby save a lot of current consumption.
    According to the datasheet, the typical RSSI sample period is just 0.25us. However, what spoils that a bit is that the radio has to come up to speed beforehand.
    Anyhow, on the receive side, I now have at least that much working.
    It looks as though the start-up time for the radio is about 390us. So, it does save a lot of current to first check the RSSI level rather than to always listen for a packet.
    When I measure RSSI on the nRF52832, I get what seems like a rather odd range of values: between about 94 and 127. If I have no other nodes transmitting, then the RSSI is generally around 100. If I set up another node which deliberately transmits on the same channel, then the RSSI is pegged at 127.
    Is that what others here are also seeing? Here's the test code:
    uint8_t theRSSI;
    NRF_RADIO->TASKS_RXEN=1;  //start revving up the receiver
    while (!(NRF_RADIO->EVENTS_READY)) {} //busy-wait until radio ready to receive
    NRF_RADIO->TASKS_RSSISTART=1;  //Take exactly one RSSI sample
    while (!(NRF_RADIO->EVENTS_RSSIEND)) {}  //Busy-wait until RSSI sample is completed.
    theRSSI = NRF_RADIO->RSSISAMPLE;
    Serial.println(theRSSI);
    Serial.flush();
    sleep(1000);
    Unfortunately, when I use the above code block and test the current using an oscilliscope, it becomes clear that the radio never actually goes to sleep:
    So, to do that, I add the line:
    NRF_RADIO->TASKS_DISABLE=1;  //turn-off the radio
    just prior to sleep(100). Doing that largely eliminates the current drain while sleeping:
    However, if I do that, then the RSSI that gets reported is always 127. Why? Do I need some other way to check the radio states? Maybe STATE from section 23.14.25 STATE of the datasheet would work better?
    Found a breakout board for the nRF51822-04: https://oshpark.com/shared_projects/zqDQaykJ
    The datasheet is possibly a bit misleading when it says:
    For the RSSI sample to be valid the radio has to be enabled in receive mode (RXEN task) and the reception
    has to be started (READY event followed by START task).
    I'm finding that the radio needs to be in either RXIDLE state or RX state to get a plausible RSSI measurement. I can't get a reasonable RSSI measurement while within the RXRU state.
    I'm finding that the radio needs to be in either RXIDLE state or RX state to get a plausible RSSI measurement. I can't get a reasonable RSSI measurement while within the RXEN state.
    In the ESB code, I use the bitcounter event to start the rssi sample task via PPI. The results are looking plausible.
    I've found that I get a slightly stronger RSSI signal by about 3dB if I measure it while in the RX state rather than the RXIDLE state.
    Do you know of any good PPI tutorials? The datasheet seems awfully skimpy on its explanation of exactly how to use it.
    Right now I have RSSI triggers working on the receiver (presently using the MCU, not PPI), but it takes 1400 samples to guarantee not missing any transmissions. That's because of the gap between single shot packets when they get sent. If I can reduce that to one sample, by finding a way to make a transmitter transmit continuously, then that will save a lot of energy on the receiver.
    There is a way to do more rapid fire transmission of packets, so that would be the fall-back plan if I can't find a way to, for example, send a continuous preamble.
    Answering my own question: it turns out that if you enter into TX mode without any payload, it just sends a null packet and returns to TXIDLE. So, it is not like the RFM69, which would simply send an indefinitely long preamble until there's a payload to send.
    The goal is to close the gap between packets as much as possible. So, I'm getting some improvement by just immediately switching back into TX mode (to send another null packet) the moment I've confirmed that TXIDLE state has re-occured.
    As it turns out, using the above method packs the null packets so tightly that I can rely on a single RSSI measurement (instead of 1400 of them) to guarantee that a transmission won't be missed. So, the goal is achieved.
    It sounds as though combining PPI with this would drive the energy consumption even lower! 🙂
    @NeverDie Thank you sharing your experience here. It helps me of better understanding some nRF5 internals. It would be awesome if you share your code.
    To understand PPI you have to be in mind that nearly everything is driven by tasks and events. If you want to do something, you have to start a task like 'NRF_RADIO->TASKS_TXEN=1'. If a task ends it generates an event like 'NRF_RADIO->EVENTS_READY'. You can replace NRF_RADIO with another periphery the registers have an equal naming scheme.
    For an event an Interrupt can be enabled with the NRF_RADIO->INTENSET register. Each event correspondents with a bit in that register. In an interrupt, you have to reset the NRF_RADIO->EVENTS_READY register to 0 to allow triggering a new interrupt. For compatibility, you can use the NRF_RESET_EVENT macro in interrupts. This reads back the register on nRF52 to avoid caching effects. Interrupts doesn't matter for PPI 🙂
    The next fine thing are Shortcuts. Shortcuts are limited to the same peripheral unit. Bits in the NRF_RADIO->SHORTS register are corresponding to a connection between an event and a test. If the event is triggered the task is started. This allows to trigger things like send an packet after the radio is ready. To use this, you have to enable the shortcut in the NRF_RADIO->SHORTS register.
    To break the limits of shortcuts, there is the PPI unit with 32 channels. Some of the channels are predefined but interesting to see how things are implemented with BLE. The other PPI channels are flexible. To use one of these channels, you have to write a pointer of your event register, like '(uint32_t)&NRF_RADIO->EVENTS_END' to the NRF_PPI->CH[YOUR_CHANNEL].EEP register and a pointer to your task you want to start in the NRF_PPI->CH[YOUR_CHANNEL].TEP register like '(uint32_t)&NRF_TIMER0->TASKS_START'. Then you have to enable the PPI channel by setting the corresponding bit like 'NRF_PPI->CHENSET |= (1 << COUR_CHANNEL)' that's all.
    The nRF52, but not the nRF52 comes with NRF_PPI->FORK[YOUR_CHANNEL].TEP registers. in my reading you can start a second task with this register like writing to NRF_PPI->CH[YOUR_CHANNEL].TEP.
    I have no idea about using the PPI Groups.
    Arudino provides a PPI library for the primo: http://cdn.devarduino.org/learning/reference/ppi I think we have to use this library to be compatible in the future. I hope there is a chance to port things to arduino-nrf5 back.
    Edit: The arduino PPI library is not flexible enough to support radio events. 😞
    Thanks! At least notionally, the PPI sounds excellent. Presently, if I want to move the radio into a particular state which takes a few state changes to get there, using the MCU with a conservative coding style, I have to initiate the first state change, then busy-wait until the new state is confirmed, then make the next state-change, etc. It sounds as though the PPI is a good fit for this, because it would eliminate the busy-waits. It would automatically transition from one state to the next using just the interrupt scheme you outlined until the target state is reached. Well, at least in theory. Meanwhile the CPU could be doing other things or sleeping. This does sound like a definite improvement, especially for more efficient control over the radio. 🙂
    Here it is:
    #include <nrf.h>
      //guarantee RESET pin is working
      NRF_RADIO->FREQUENCY=123;
      NRF_RADIO->MODE=2;  //set 250kbps datarate.  May as well stretch out the NULL packet as much as possible.
      NRF_RADIO->TASKS_DISABLE=1;  //turn-off the radio to establish known state.
      while (NRF_RADIO->STATE!=0) {}  //busy-wait until radio is disabled
      NRF_RADIO->TASKS_TXEN=1;  //wake-up the radio
      while ((NRF_RADIO->STATE)!=10) {}  //busy-wait until radio has started TXIDLE
      //Assertion: radio is now in TXIDLE state.
        //assume radio is in TXIDLE state.
        NRF_RADIO->TASKS_START=1;  //Move from TXIDLE state to TX state.  This sends a NULL packet.
        while ((NRF_RADIO->STATE)!=11) {}  //busy-wait until radio is in TX state
        while ((NRF_RADIO->STATE)==11) {}  //busy-wait until radio is back to TXIDLE state
        //Assertion: radio is now back to TXIDLE state
    So, to make the above code work as a PPI, all I would need is some kind of linkage such that whenever the "event" of TXIDLE occurs, then a "task" (in this case it would be TASKS_START) is executed to move the radio back into the TX state.
    Hmmm.. Still not obvious though from just the datasheet how to actually setup even that simple linkage.
    This is a use case for shortcuts. PPI is not required.
    There is no TXIDLE event but looking at the state diagram is TXIDLE a result of ether READY or END event. You can enable following shortcurts:
    NRF_RADIO->SHORTS = RADIO_SHORTS_READY_START_Msk | RADIO_SHORTS_END_START_Msk;
    In PPI this should be the code (untested):
    #define CHANNEL (1)
    NRF_PPI->CH[CHANNEL].EEP = (uint32_t)&NRF_RADIO->EVENTS_END;
    NRF_PPI->CH[CHANNEL].TEP = (uint32_t)&NRF_RADIO->TASKS_START;
    NRF_PPI->CH[CHANNEL+1].EEP = (uint32_t)&NRF_RADIO->EVENTS_READY;
    NRF_PPI->CH[CHANNEL]+1.TEP = (uint32_t)&NRF_RADIO->TASKS_START;
    NRF_PPI->CHENSET = (1 << CHANNEL) | (1 <<( CHANNEL+1));
    Thanks! That helps my understanding quite a bit. I've tested the following shortcut code, and it works:
    #include <nrf.h>
      NRF_RADIO->SHORTS = B100001;  //Implement shortcuts: READY_START and END_START
      NRF_RADIO->TASKS_TXEN=1;  //wake-up the radio transmitter and move it into state TXIDLE.
      //The shortcuts will take-over the moment the state TXIDLE becomes activated.
    Is there any example code which illustrates the use of interrupts on the nRF52832?
    Looks as though it should be possible to send tightly packed meaningful packets, not just null packets, using almost the same methodology.
    https://github.com/sandeepmistry/arduino-nRF5/issues/52
    https://github.com/mysensors/MySensors/blob/development/drivers/NRF5/Radio_ESB.cpp#L500
    Interestingly enough, it turns out all I need to do is transmit one packet, and afterward just leave the radio in TXIDLE mode. That's because, as indicated in the datasheet, it transmits a carrier wave of one's (or any pattern you program) after the packet, expecting that another packet will be sent soon. This is illustrated in Figure 37 of the DS.
    So, I've got the transmit side of this problem figured out. Next up: the receiver side, which already works using the MCU.
    The next step will be to see whether I can setup timed events from the RTC which can be used to trigger the PPI to measure the RSSI without waking up the MCU. Also, I'll need some way for the PPI to evaluate the magnitude of the RSSI without involving the MCU. Ideally it would also trigger a Rx sequence if the RSSI is above threshold and wake the MCU if something gets received. Not sure how much of this will be possible, but that's the wish list.
    I'd say the energy consumption is already pretty good after switching to the RSSI paradigm, but if this succeeds, then it may cut what remains of the energy consumption roughly in half. At that point, I think we will have wrung just about every possible bit of efficiency out of this radio, with the remaining to-do's as mostly mop-up and maybe some fine tuning (e.g. to better mitigate against false positives on the RSSI threshhold trigger).
    So, I figure the way to get started is to do something "easy", like maybe use the PPI to blink an LED.
    We want the lower power RTC, not the system clock. We want to use the RTC TICK event, so that the mpu can be powered down while the PPI is running.
    So, because I want a timer event every 100ms, that means the prescaler should be 3276.
    So, just starting on this, where I'm at is:
    #include <nrf.h>
    #define LED_PIN 18
    bool toggle=false;  //track whether or not to toggle the LED pin
      NRF_RTC1->TASKS_STOP=1;  //stop the RTC so that we can set the prescaler
      NRF_RTC1->PRESCALER=3276;  //once per 100ms
      NRF_RTC1->TASKS_START=1;  //start the RTC so that we can start getting TICK events
      hwPinMode(LED_PIN,OUTPUT_H0H1);  //establish P0.18 as the LED pin.
      if (NRF_RTC1->EVENTS_TICK) {
        toggle=!toggle;
        digitalWrite(LED_PIN,toggle);
    Unfortunately, this does not work because (NRF_RTC1->EVENTS_TICK) always reads as zero. Not sure why(?).
  • @NeverDie you will need long range capabilities on both sides of the link. So two preview kits work great. Long range is supported by SDK 14 and the current softdevice.
  • @scalz the nRF52832 has a hotter receiver. ( better sensitivity.) at 1 mb/ s then the nRF24l series. Overall link Budget is better. 840 even better with a 8dB output.
    @Jokgi
    of course I agree !
    that's why in the past i preferred rfm69 modules (better range of course, but more power hungry). 832 being better than nrf24, i'm now using it. And I also like the 840dk (neat package) 👍
    That said, if i remember well, nrf52832 is not fully BLE5 long range compatible as 840 is.
    I'm not disagreeing, but presently modules for it (other than the preview DK) aren't yet available. Meanwhile, hopefully nearly all of what's being learned here about the nRF52832 will be of direct relevance. For instance: PPI.
    It should be working, but it isn't. Nor do I see a way to check it with an oscilliscope. So, my current theory is that it gets set but cleared so quickly that it can't be read by the MCU. So, the next step will be to assume that it is, in fact, working, and to use it as a PPI trigger, which is what this is all building toward anyway.
    On the other hand, perhaps there's an easy way to have the EVENTS_TICK set an interrupt bit, which would persist until it was cleared? Hmmm. No, not quite, but there is INTENSET, which will set an interrupt on an EVENT_TICK. That will do. Exactly which interrupt gets triggered though? Figure 46 shows that an IRQ signal is sent to NVIC ( the Nested Vectored Interrupt Controller). According to the table in sectoin 7.3, the NVIC has 37 interrupt vectors. According to section 15.8:
    A peripheral only occupies one interrupt, and the interrupt number follows the peripheral ID. For example, the
    peripheral with ID=4 is connected to interrupt number 4 in the Nested Vectored Interrupt Controller (NVIC).
    So, based on that, we need to know the ID number for the RTC, and then we'll know which interrupt number to track. According to Table 10, the Peripheral ID for the RTC is 11 (well, at least it is for the RTC0, so I will recode to use RTC0 instead of RTC1).
    Now, according to Table 10, the memory location that corresponds to Peripheral ID 11 is 0x4000B000. Therefore, it is this memory location we need to examine to know if a TICK interrupt has occured.
    Close, but no cigar. What I found out is that if I set the TICK interrupt with:
          NRF_RTC0->INTENSET=1;  //set the TICK interrupt bit
    then at the following memory addresses, the value stored there immediately becomes 1:
    4000B300
    4000B304
    4000B308
    and if I clear the TICK interrupt with:
          NRF_RTC0->INTENCLR=1;  //clear the TICK interrupt bit
    then the values at those same memory addresses immediately becomes zero. I can toggle back and forth as much as I want, and this is always true.
    However, none of this is telling me whether the TICK interrupt has actually triggered. Where do I find that?
    Based on the current pre-scaler, COUNTER increments once every TICK (i.e. once every 100ms). However, is there an actual TICK flag somewhere that goes high at those times and then low again after getting cleared? Or, is it only accessible indirectly by using PPI?
    OK, I came up with a simple equivalent. Basically, every time COUNTER is incremented, I reset it to zero. It then effectively acts much the way a TICK should. For whatever reason, once EVENTS_TICK goes high, it just stays high forever. So, it doesn't seem very useful per se, though maybe there's a way to clear it that I haven't yet found.
    Strangely enough, the overflow is the same: once it goes HIGH, it stays that way:
    https://pastebin.com/vypuVJeh
    So, I would think there must be some way (?) to clear them.
    I found the answer. Unlike EVENTS in other peripherals, which are read-only, the EVENTS in RTC are RW. So, the way you clear the TICK and OVRFLW events is just by setting them to zero manually:
    e.g.
    NRF_RTC0->EVENTS_TICK=0;
    LOL. Of course, the DS never mentions this.
    In any case, with that change, it can now work properly:
    https://pastebin.com/nHWAGFkd
    However, it does raise the question: if I were to use EVENTS_TICK to trigger some PPI actions, how could PPI also be used to set EVENTS_TICK back to zero so that those actions can be repeated on the next TICK? I haven't yet found an PPI TASKS that can directly manipulate, or even just clear, a particular memory location.
    Since there are no apparent shortcuts pertaining to the RTC, it looks as though all non-MCU manipulations will have to happen via PPI.
    I don't see how to clear a TICK using PPI, so I think the simplest thing would be clearing the counter back to zero if it hits one.
    If there's no way to do this basic thing, then I see no way to have a "listen mode" equivalent for the nRF52832 that runs via PPI.
    So, adapting what @d00616 wrote earlier, maybe the PPI code to do that would be:
      #define CHANNEL (1)
      NRF_PPI->CH[CHANNEL].EEP = (uint32_t)&NRF_RTC0->COUNTER;  //when COUNTER goes from zero to one.
      NRF_PPI->CH[CHANNEL].TEP = (uint32_t)&NRF_RTC0->TASKS_CLEAR;  //clear COUNTER back to zero.
      NRF_PPI->CHENSET = (1 << CHANNEL) ;
    Well, it does compile, but it doesn't work. 😞 I think it doesn't work because COUNTER is not an event.
    Unfortunately, changing COUNTER to EVENTS_TICK fails also:
      NRF_PPI->CH[0].EEP = (uint32_t)&NRF_RTC0->EVENTS_TICK;  //when TICK occurs.
      NRF_PPI->CH[0].TEP = (uint32_t)&NRF_RTC0->TASKS_CLEAR;  //clear COUNTER back to zero.
      NRF_PPI->CHENSET=1;   //Enable Channel 0.
    Unfortunately, the PPI Example code from Nordic's SDK doesn't look even remotely similar to what we're doing here.
    Anyhow, the last thing I tried was this:
      NRF_RTC0->INTENSET=1;  //Allows TICK to create an interrupt.
    hoping that it might make a difference, but it still fails. Why? What is wrong with it?
    EVENTS_TICK
    From the datasheet:
    15.6 Events
    Events are used to notify peripherals and the CPU about events that have happened, for example, a state
    change in a peripheral. A peripheral may generate multiple events with each event having a separate
    register in that peripheral’s event register group.
    An event is generated when the peripheral itself toggles the corresponding event signal, and the event
    register is updated to reflect that the event has been generated. See Figure 10: Tasks, events, shortcuts,
    and interrupts on page 68. An event register is only cleared when firmware writes a '0' to it.
    Events can be generated by the peripheral even when the event register is set to '1'.
    Maybe I don't get the problem here, but the way I see it, you have to actively write a '0' to the event register to clear it, but in fact it shouldn't matter, because the timer can nevertheless generate an event.
    This is right. I later confirmed it (see above), but thank you for the passage in the datasheet. I could have sworn that somewhere the DS said that events were read-only, but the passage you quoted contradicts that recollection. So, thank you again.
    Any thoughts on the PPI question (directly above your post)?
  • So, you want to shut the CPU down, leaving only RTC and PPI running, and generate a wakeup event every 100ms, did I get that right?
    I didn't dig that far into the datasheet, and also I don't have any board for testing (yet).
    Also, I didn't check whether the debugger will survive a power down/up cycle.
    Does it?
    Yes. I hope to do more than only just that using the PPI while the CPU sleeps, but that does seem like the first step.
    Does it?
    Don't know. I haven't started using the debugger yet.
  • In this example from Nordic, they're using the RTC's compare interrupt:
    http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.nrf52%2Fdita%2Fnrf52%2Fapp_example%2Fsolar_beacon%2Fintroduction.html
    Average current consumption is 19µA, including sensor reading, data transmission and Bluetooth advertizing.
    Not too bad, I'd say.
    Yeah, but that part of it is running on the MCU, not the PPI.
    void RTC0_IRQHandler(void)
        NRF_RTC0->EVTENCLR = (RTC_EVTENCLR_COMPARE0_Enabled << RTC_EVTENCLR_COMPARE0_Pos);
        NRF_RTC0->INTENCLR = (RTC_INTENCLR_COMPARE0_Enabled << RTC_INTENCLR_COMPARE0_Pos);
        NRF_RTC0->EVENTS_COMPARE[0] = 0;
        m_rtc_isr_called = true;
    Anyhow, I don't see a way to do an RFM69 style "listen mode" using just the PPI on the nRF52832. I think this may be a dead end.
    Looks as though there is EVTEN, which on the RTC needs to be enabled to get the PPI to work. Shown in Figure 46.
    Bingo! Added this, and it now works:
      NRF_RTC0->EVTENSET=1;  //enable routing of RTC events to PPI.
    More good news. As far as the PPI is concerned, an event such as OVRFLW is still just as active as if it had been cleared, even if it hasn't. Here's the proof:
      NRF_RTC0->TASKS_TRIGOVRFLW=1;
      NRF_PPI->CH[0].EEP = (uint32_t)&NRF_RTC0->EVENTS_OVRFLW;  //when RTC overflow occurs.
      NRF_PPI->CH[0].TEP = (uint32_t)&NRF_RTC0->TASKS_TRIGOVRFLW;  //set COUNTER to be near another overflow.
      NRF_RTC0->EVTENSET=B10;  //enable routing of RTC OVRFLW events to PPI.
    functions as follows:
    https://pastebin.com/Z09e7tMK
    It looks like you are implementing a new radio protocol and you are coming forward.
    What do you think about forking the MY_RADIO_NRF5_ESB into a new one? The nRF5 code is designed to implement additional protocols for nRF5.
    If you remove the address reverse code, there are no OTA conflicts with the ESB protocol. The address width can be enhanced by 2 bits to allow better AES encryption and lager packages.
    Yes, I'm presently focused on trying to reduce the amount of energy consumed by probably the hardest case of all: a battery/solar/supercap receiver that needs to be both highly responsive (within 100ms) and listening 24/7 without running out of juice. Of course, one can always throw bigger batteries or bigger solar panels at the problem, but I'm first trying to be as ultra efficient as possible so that won't be necessary. The benefit will be smaller size, not to mention lower cost.
    I am posting my findings as I go because there is precious little in the way of working examples, so I may yet still be of help to others in that way. From the view count, it does seem that people are reading this thread, even if not many are posting.
    btw. Thank you for sharing you knowledge here. In my option this is very helpful for me.
    @d00616
    I think you'll find this interesting:
      NRF_RTC0->TASKS_TRIGOVRFLW=1;  //set COUNTER to trigger an overflow after 16 TICKS.
      NRF_PPI->FORK[0].TEP = (uint32_t)&NRF_RADIO->TASKS_RXEN;  //turn on the radio receiver
      //When Radio state TXIDLE is reached, perform an RSSI sample.  There is no shortcut for this, so we must use PPI.
      NRF_PPI->CH[1].EEP = (uint32_t)&NRF_RADIO->EVENTS_READY;  //After event READY, radio shall be in state TXIDLE.
      NRF_PPI->CH[1].TEP = (uint32_t)&NRF_RADIO->TASKS_RSSISTART; //Take the RSSI sample
      NRF_PPI->CH[2].EEP = (uint32_t)&NRF_RADIO->EVENTS_RSSIEND;  //After event RSSIEND, RSSI measurement is finished and radio will be in state TXIDLE.
      NRF_PPI->CH[2].TEP = (uint32_t)&NRF_RADIO->TASKS_DISABLE; //Sleep the radio
      NRF_PPI->CHENSET=B111; //enable Channel 2, Channel 1 and Channel 0.
      sleep(1000000000);  //sleep a million seconds so as not to interfere with current measurements.
    It sleeps the MCU, and using just PPI, it wakes up the radio every 16 TICKS (each tick is 100ms) and measures the RSSI. Then it puts the radio back to sleep.
    So, looking at the current consumption from a macro viewpoint, it's this:
    The taller peaks are when the RSSI measurements happen. Zooming in on one of the RSSI measurements, the current consumption is this:
    As you can see, very little, and only for a very short time!
    So all I need now is a way for the PPI to compare the RSSI measurement it obtained above with a threshold benchmark to decide whether or not to wake the MCU, which can take it from there. From that point onward, the regular ESB code could be used. 🙂
    Nordic could have taken this a lot farther if they had included some comparison tasks, so that the PPI could make decisions about what to do next. However, I don't see that there are any that can be used for comparing an RSSI measurement against a benchmark. Too bad. 😞
  • Great that it works.
    But I'm not so convinced about the usefulness of this method, anyways.
    I know that a lot of receivers use simple RSSI measurement to implement a low power listening mode, but when you are in a noisy environment, the system will wake up quite often, draining the battery fast. And unless you live in a very remote area, 2.4 GHz IS a noisy environment.
    And your better alternative is....?
    I'm following your work with interest of course 😉 On my side i'm pretty busy on other stuff (rpi and my HA) so i'm missing time for try..I'll be back soon on this!
    I thought too, about implementing this kind of listenmode for rfm69 in my HA. What i don't like so much, is I think i would need a dedicated node for the scheduling and it complicates a bit thing. I'm not fond of using gw resources for the wakeup broadcast.
    I think, maybe I'm wrong, that, ideally, the best would be "time slots" so everything would be in sync, no flooding broadcast, lost msg, collisions etc.. but that implies some work regarding the lib, and some hw issues (with simple 8bits without precise rtc).
    Keep the good work!
  • @NeverDie None, unfortunately. The manufacturer would have to take care of that, by implementing a low power mode in the receiver (maybe with reduced sensitivity), and an additional low power wakeup pattern detector.
    There are transceiver that can do that, but the nRF52 can't.
    Some of the simple 433MHz OOK receivers have a low current consumption, but they're pretty insensitive, high bandwidth and low speed, so of not much use except switching some battery powered lamp, or such.
    Some time ago I searched for a transceiver with low current receive mode, to use it in a battery powered node, that could be woken up by rf, but found nothing.
    All of the standard data transceivers are pretty power hungry.
  • @Toyman Indeed:
    Nonetheless, larger AA or AAA type
    batteries are still required to reliably achieve operation times
    of a year or longer with high advertising rates.
    As I thought.
    And for more advanced modulations, like LoRa, the power consumption is even higher.
    TI and Silicon Labs have both had chips with "wake on radio". e.g. http://www.ti.com/lit/an/swra126b/swra126b.pdf
    The Rx current consumption of the nRF52832 seems pretty good, especially with DCDC regulator enabled. Seems to me that the RSSI detection implemented in PPI is a big improvement, even in noisy environments for the following reasons: the RSSI measurement takes only 0.25us, according to the DS. That's very little overhead. If the Radio gets switched on due to a false positive on the RSSI, well, it would have had to be switched on anyway even without the RSSI. I don't see the downside to this. The more noisy the environment, the less effective the technique is, but I don't see that you'd ever really be worse off for using it.
    @d00616
    If I'm using
    sleep(1000000000);
    to sleep the CPU while keeping the PPI active, is there a way for the PPI to subsequently wake the CPU so that the CPU can resume where it left off? I'm not seeing any TASKS which look suitable for doing that. Or do I need an altogether different configuration for sleeping the CPU?
    Back on August 5, @RMTUCKER had suggested using:
    If I were to go that route, I could probably have the PPI toggle PIN 10 to do a wake-up, but I found that, for whatever reason, that method of sleeping had a much higher current draw.
    [Edit: scratch that. I just tried "sleep(digitalPinToInterrupt(10), FALLING,0);", and it appears to turn-off PPI. Oddly enough, it appears to leave the RTC running, which is actually just fine by me. However, I need the PPI running too. ]
  • @Uhrheber not really. If you read carefully, they claim almost 1year battery life with 1hz (once per sec) advertising.
    Typical MYS node sends data once per minute? So, actually, 2-3 years are easily achievable.
    It turns out the cost in current consumption of waking the MCU merely to check the RSSISAMPLE result is relatively high:
    The first hump is the current drawn by the PPI and RSSI sample. The second hump is the current drawn by MCU.
    Measurement Scale: 1mv=1ma.
    Anyhow, the RSSISAMPLE measurement, as reported by the MCU, is abnormally high. It may be that I need to put the radio into RX state, instead of just RXIDLE, before taking the RSSI measurement.
    @d00616
    Are there special reserved names to always use for the IRQ handlers? e.g. RADIO_IRQHandler(void), and so on?
    The PPI cannot wake up the CPU. You can try to trigger events to a timer which resumes the CPU.
    Are there special reserved names to always use for the IRQ handlers? e.g. GPIOTE_IRQHandler(void), and so on?
    The names are defined there:
    https://github.com/sandeepmistry/arduino-nRF5/blob/dc53980c8bac27898fca90d8ecb268e11111edc1/cores/nRF5/SDK/components/device/nrf52.h#L65
    Does the current development software support the use of at most one ISR in total at any one time?
    @d00616
    I changed your example to use sleep(...) instead of delay(...) in the main loop, but what then becomes obvious is that the interrupts don't wake up the MCU. Well, in a sense they do, because the ISR is executed, but the MCU doesn't remain awake like it would on an Arduino. So, how does one escape the sleep mode after it has begun without waiting for it to simply time out?
    // This code is public domain
    #include <nrf.h>
    //#define RTC NRF_RTC0
    //#define RTC_IRQ RTC0_IRQn
    int interrupt = 0;
      Serial.begin(250000);
      Serial.println("Start");
      // Configure RTC
      NRF_RTC0->TASKS_STOP = 1;
      NRF_RTC0->PRESCALER = 31; //1024Hz frequency
      NRF_RTC0->CC[0] = NRF_RTC0->COUNTER + (3 * 1024);
      NRF_RTC0->EVTENSET = RTC_EVTENSET_COMPARE0_Msk;
      NRF_RTC0->INTENSET = RTC_INTENSET_COMPARE0_Msk;
      NRF_RTC0->TASKS_START = 1;
      // Enable interrupt
      NVIC_EnableIRQ(RTC0_IRQn);
      Serial.println();
      Serial.println();
      Serial.print(millis());
      Serial.print(" ");
      Serial.print(NRF_RTC0->COUNTER);
      Serial.print(" ");
      Serial.println(interrupt);
      sleep(10000);
     * Reset events and read back on nRF52
     * http://infocenter.nordicsemi.com/pdf/nRF52_Series_Migration_v1.0.pdf
    #if __CORTEX_M == 0x04
            event = 0;        \
            (void)event
    // This must be in one line
    extern "C" { void RTC0_IRQHandler(void) { NRF5_RESET_EVENT(NRF_RTC0->EVENTS_COMPARE[0]); interrupt++; NRF_RTC0->TASKS_CLEAR = 1; }}
    I guess maybe the answer is to clear the SLEEPONEXIT bit in the System Control Register (SCR) before exiting the ISR? The SCR is described on page 4-19 of: http://infocenter.arm.com/help/topic/com.arm.doc.dui0553a/DUI0553A_cortex_m4_dgug.pdf
    At the moment, though, I'm not even sure how to access that register, as so far I've only seen the API for the nRF52832 generally, not the code interface for the ARM Cortex M4 per se that's inside it.
  • @NeverDie
    I am a little lost with this,I am using sleep and wake from ext int on the nrf51 and it has been working every second for the last 2 weeks.
    What kind of int are you trying to implement?
    This is for the case where the PPI is doing things (like, for example, getting the radio to periodically listen for incoming packets) all while the CPU is sleeping. If, for instance, a packet is received in that mode, the CPU needs to be awoken to process it.
    So, this is different than the easier case (which I already have working) of sleeping the CPU, then it wakes up every, say, 100ms, and then the CPU controls the radio to listen for packets and then takes action if one is received. Instead, this is a case where the PPI is controlling the radio while the CPU sleeps.
    The PPI has a lot of power saving potential, so we're figuring out how best to exploit that potential.
    Also, the more general topic of how to use interrupts and ISR's on the nRF52832 (such as how many different ones can be active at once, as supported by the current development code) needs to be addressed, independent of the regular sleep(..) function.
    All we need right now is a controller that covers the majority of home use.
    Tried domoticz for 2 years and it covers energy use and cost really well but then is limited to saving data every 5mins and no mixed/multisensor graphs to any extent so useless for my current needs.
    Tried myHouse for 6 months and it,s graphing was great but the display of binary sensors were not in real time and it does not do energy use at all.
    I can not find a controller that seems to cover average needs for automation/energy/and realtime feedback.
    I know it's a little off topic but it is a big problem when you can build the range of mysensors using the nrf5 but then not be able to get the feedback and energy/cost stuff on the screen.
    Maybe i am just disgruntled that the controllers do not seem to keep up with the electronics very well.
    Yes, agreed, but please let's not go into that here, because it would seriously throw us off topic. You might try: https://forum.mysensors.org/topic/7178/are-folks-here-happy-with-domoticz/63 which has some useful suggestions, especially regarding Node Red and MQTT.
  • @NeverDie
    Sorry mate i have deleted it i am just a little miffed with the controller searching😠
    OK, the file core_cm4.h is where the structure that contains the SCR is defined:
    typedef struct
      __IM  uint32_t CPUID;                  /*!< Offset: 0x000 (R/ )  CPUID Base Register */
      __IOM uint32_t ICSR;                   /*!< Offset: 0x004 (R/W)  Interrupt Control and State Register */
      __IOM uint32_t VTOR;                   /*!< Offset: 0x008 (R/W)  Vector Table Offset Register */
      __IOM uint32_t AIRCR;                  /*!< Offset: 0x00C (R/W)  Application Interrupt and Reset Control Register */
      __IOM uint32_t SCR;                    /*!< Offset: 0x010 (R/W)  System Control Register */
      __IOM uint32_t CCR;                    /*!< Offset: 0x014 (R/W)  Configuration Control Register */
      __IOM uint8_t  SHP[12U];               /*!< Offset: 0x018 (R/W)  System Handlers Priority Registers (4-7, 8-11, 12-15) */
      __IOM uint32_t SHCSR;                  /*!< Offset: 0x024 (R/W)  System Handler Control and State Register */
      __IOM uint32_t CFSR;                   /*!< Offset: 0x028 (R/W)  Configurable Fault Status Register */
      __IOM uint32_t HFSR;                   /*!< Offset: 0x02C (R/W)  HardFault Status Register */
      __IOM uint32_t DFSR;                   /*!< Offset: 0x030 (R/W)  Debug Fault Status Register */
      __IOM uint32_t MMFAR;                  /*!< Offset: 0x034 (R/W)  MemManage Fault Address Register */
      __IOM uint32_t BFAR;                   /*!< Offset: 0x038 (R/W)  BusFault Address Register */
      __IOM uint32_t AFSR;                   /*!< Offset: 0x03C (R/W)  Auxiliary Fault Status Register */
      __IM  uint32_t PFR[2U];                /*!< Offset: 0x040 (R/ )  Processor Feature Register */
      __IM  uint32_t DFR;                    /*!< Offset: 0x048 (R/ )  Debug Feature Register */
      __IM  uint32_t ADR;                    /*!< Offset: 0x04C (R/ )  Auxiliary Feature Register */
      __IM  uint32_t MMFR[4U];               /*!< Offset: 0x050 (R/ )  Memory Model Feature Register */
      __IM  uint32_t ISAR[5U];               /*!< Offset: 0x060 (R/ )  Instruction Set Attributes Register */
            uint32_t RESERVED0[5U];
      __IOM uint32_t CPACR;                  /*!< Offset: 0x088 (R/W)  Coprocessor Access Control Register */
    } SCB_Type;
    Unfortunately, I just checked its status, and it's already cleared. So, something else is causing the MCU to go back to sleep at the end of the ISR.
    The problem is that an ISR needs to be as short as possible. If something more elaborate needs to happen as a result of an interrupt, whether it be printing a bunch of debug information or something else, it should happen outside the ISR. Right now I don't see how to do that, because the MCU always immediately goes back to sleep after the ISR finishes. I suppose it must be something inside the sleep(..) routine that causes this?
    I suspect it may be the while statement in this part of the library code that's doing it:
    int8_t hwSleep(unsigned long ms)
    	hwSleepPrepare(ms);
    	while (nrf5_rtc_event_triggered == false) {
    		hwSleep();
    	hwSleepEnd(ms);
    	return MY_WAKE_UP_BY_TIMER;
    Yup, that was it. I excised the while-loop and re-wrote it as a differently named function, which I now call instead of sleep(..):
    int8_t myHwSleep(unsigned long ms)
      hwSleepPrepare(ms);
      //while (nrf5_rtc_event_triggered == false) {
        hwSleep();
      hwSleepEnd(ms);
    and it now works "correctly"--well, at least what I want it to do. 🙂 I'll flag it for @d00616, who may have good reasons for keeping it as-is.
    I follow your journey with great interest, one day Ill find the time to do something with it 🙂
  • Just wondering if ota updates are possible with the nrf5 because it does not have the usual memory constraints?
    Epilog: It turns out that the reason I was getting erroneous readings of RSSISAMPLE by the CPU is that the radio must be turned-on when that register is being read. I had hoped it was being stored somewhere else in memory, but it's not. So, probably the best that can be done from an energy standpoint is to have the PPI pipeline the waking of the radio and the CPU from sleep, such that neither is waiting for the other to wake up in order to get work done. Ideally, the moment the RSSI measurement is taken by the PPI, the CPU would have just then fully woken up and be able to evaluate RSSISAMPLE, while the radio is still turned on.
    A different approach would be to have the PPI cyclically wake the radio into Rx mode for a period of time and then shut it down. If it received a packet, it would trigger a wake-up on the CPU. This is more or less how the RFM69's "listen mode" works. I may give this a try also so as to measure whether total current consumed is greater or less than the current consumed by the revised RSSI approach (above). I think it might. Although the radio has to remain on longer than it would if it were doing purely an RSSI measurement, it has the advantage that the CPU can remain asleep until an actual packet is received. Given that the radio spends a lot of time just ramping up after being disabled, I'm guessing the incremental Rx time needed for packet detection won't seem so much in comparison. The hard part to this approach will be timing just how long the Radio is in RX mode. Although there are technically three RTC instantiations that can be used, they all share the same prescaler.
    So, in order to create a short delay timer, I set one GPIO pin high, which charges a second GPIO pin through a very small capacitor and diode in parallel. Then, when the first GPIO pin goes low, the voltage on the second GPIO pin decays. By setting a PPI event on the second pin to trigger from a Hi2Lo transition, I'm able to create an analog delay, which varies in duration depending on the value of the capacitor. Presently, using a 2.2nF capacitor creates about a 2ms delay between the first pin going LOW and the second pin detecting a Hi2Lo event. It is that event which could be used to trigger turning off the radio after it has listened for packets, whereas it is the first pin going LOW that would have triggered turning on the radio and putting it into RX mode. This is all controlled by the PPI, so no energy needs to be used by the CPU. 🙂
    If anyone can think of a better or more of a digital way to create a predictable time delay, please do post. However, I'm using this method for now just for proof of concept purposes.
    Here's a scope capture of it:
    The yellow line shows the rapid charging and then subsequent decay of voltage on the second pin. The blip on the blue line shows that after slightly more than 2ms, the Hi2Lo event was triggered, because the voltage on the second pin had dropped enough for the Hi2Lo transition to occur. As you can see, it happens at around 1v. I was able to capture it on the scope because I used that event to very briefly set a third pin (the one whose voltage is being tracked by the blue line) HIGH.
    Again, all of this is being managed by the PPI while the CPU is asleep. 🙂
    If your goal is to minimize the RX-on time, then you can trigger the RX start and stop by a timer for your minimal window where the frame must be start. Then use the bitcounter top stop the timer in case a packet is received. A shortcut to the end is disabling the RX mode. You can wakeup the CPU with the END event.
    P.S.: you can reduce the RX/TX time by enabling fast ramp up in MODECNF0 if you haven't to care about nRF51 compatibility.
    Thanks! It finally dawned on me that having the PPI use the RTC's CC registers would be a far better way to schedule turning on and off the radio's RX than using the stopgap analog delay that I had devised (above). Your interrupt handler example helped me see what had been staring me in the face the entire time, but without my recognizing it as the answer to the problem. Funny how that can sometimes happen, where the whole gestalt can just suddenly change. So, thanks again for sharing your example code. This will be a much less awkward solution! 🙂
    Where exactly do I look to find all the pin mappings that are assumed for the "Generic nRF52" board? For example, what are the pin numbers that are assumed for RXI, TXO, MISO, MOSI, etc.?
  • @NeverDie
    /variants/Generic/variant.h i think
    I just now posted a source code example and hardware demo for my recently completed breakout board which uses "MyNRF52Board nRF52832" board as the reference when compiling within the Arduino IDE:
    https://www.openhardware.io/view/471#tabs-source
    I think from this point forward I'm going to use "MyNRF52Board nRF52832" for any custom boards I develop. Thanks to @d00616, it is a very convenient framework for organizing and enabling the preferred pin mappings. 🙂
  • @NeverDie That is a meandered Inverted F Antenna (IFA). It will give you better performance then a standard meandering antenna and a much smaller size then a standard 1/4wave trace antenna. Not as easy to tune however. You can read about the one that TI designed for their 2.4Ghz dongle. http://www.ti.com/lit/an/swra117d/swra117d.pdf
    Of course this is not Device dependent as you need to feed it with a 50 ohm feed point. A Pi network before between the Chip's ANT output and the Antenna is desired from a tuning standpoint.
    Note that on the nRF52 designs, the two components (Cap and Inductor) connected to the ANT pin are used for harmonic filtering AND impedance matching and has nothing to do with the antenna tuning other to present a 50ohm feed point.
    It looks the same as the antenna on the Ebyte E73-2G4M04S nRF52832 module. Is there any difference? i.e. are you just supplying background information, or are you making a suggestion for improvement?
  • @NeverDie nRFgo Studio uses the Segger J-link firmware. When using the Softdevice make sure that your application does not start below the top of the Softdevice or you will get a error on most programmers that there is something located in that protected space. If it does not see this as a protected area then you will corrupt the Softdevice.
    Most programmers only need the two SWD lines, ground and a voltage reference from your target board back to the programmer. This is to tell the programmer you have a target board connected and what voltage it is running on. Note that the nRF52-DK does NOT have voltage translators on the programming lines (P19 and P20) so you must be powering your target boards with 3vdc to 3.3vdc. (I have tested down to 2.8vdc but it is not guaranteed to work consistently.) Not sure about ST or other programmers.
  • @NeverDie someone did not read the datasheet. The harmonic filter / impedance matching network on the output of Pin 30 (ANT) is connected incorrectly. There needs to be abolded text Cap from ANT out to Pin 31 ONLY. (Not connected to any other ground pour as it seems they did here. Seems to be a few "extra components between there and the Antenna matching network too.
    From the nRF52832 datasheet.
    bolded text53.8 PCB layout example
    The PCB layout shown below is a reference layout for the QFN package with internal LDO setup.
    Important: Pay attention to how the capacitor C3 is grounded. It is not directly connected to the
    ground plane, but grounded via VSS pin 31. This is done to create additional filtering of harmonic
    components.[link text](link url)
  • @NeverDie Pretty much a reference only. In a previous post you inquired about the grounding on the meandering antenna. I posted the TI application note as a frame of reference only. However if you do create your own module you should be aware that the two matching components coming off the ANT pin are NOT antenna matching components but are three for output impedance matching and also acts as a low pass filter. Pi network is still required for tuning of the antenna. (may not use all three components after tuning)
    Thanks for reminding me of this. It turns out to be true for the J-Link programmers which are for sale on Aliexpress.com as well.
  • 90
