  3. RFM69 custom frequency
5 Posts 3 Posters 1.3k Views 3 Watching
  • O Offline
    O Offline
    olka
    For the pupose of testing, I would like to set up an additional gateway and I want this to be set at a different (custom) frequency to keep it seperated from my existing Mysensors network. All my RF modules are RFM69HW.
    It seems to be possible to set a custom frequency with the new RFM69 driver, but I'm not sure how to actually implement it in the sketch. Advice appreciated.
    • O olka
      Welcome to the MySensors forum @olka
      Use
      #define MY_RFM69_NETWORKID number
      where number = 0-255
      MY_RFM69_FREQUENCY is also available, but is only used to select different bands (433 and 868 for example).
      G 1 Reply Last reply
      • O Offline
        O Offline
        olka
        Thanks, and thanks for the tip, I will try to use MY_RFM69_NETWORKID.
          Use
          G Offline
          G Offline
          Grubstake
          @mfalkvidd said in RFM69 custom frequency:
          Use
          Is this current info? I haven't tried it, but the API doc (RFM69 new driver) refers to "Custom frequency in Hz":
          #define MY_RFM69_FREQUENCY (RFM69_868MHZ)
          The frequency to use.
          RFM69_315MHZ
          RFM69_433MHZ
          RFM69_865MHZ
          RFM69_868MHZ
          RFM69_915MHZ
          Custom frequency in Hz (new RFM69 driver only). <------------------------ NOTE
          See also
          MY_RFM69_NEW_DRIVER
          • G Grubstake
            Use
            RFM69_315MHZ
            RFM69_433MHZ
            RFM69_865MHZ
            RFM69_868MHZ
            RFM69_915MHZ
            See also
            MY_RFM69_NEW_DRIVER
            @grubstake yes it is still current info and works both for the new driver and for the old driver, which is used by default (and what OP asked about)
            If you are using the new driver you can set the frequency in hertz if you want to.
