  3. VEML6075 high sleep consumption
5 Posts 4 Posters 1.1k Views 3 Watching
    manutremo
    I've been reading the thread here, and decided to open a new one since that one is old, and there were no reports of the consumption being fixed.
    I'm in the same situation regarding consumption of my VEML6075 board being around 50 uA while sleeping, when it should be less than 1 uA according to the datasheet.
    My specific board doesn't contain any voltage regulators, just a capacitor and the I2C pullups. Specifically, it's this one:
    I'm using the adafruit library but I've tried 3 others with different sleep routines, all with the same result. When active, the consumption is much higher, so the chip is sleeping (sort of) it seems.
    Any help on reducing the sleep consumption would be appreciated.
    zboblamontZ Nca78N alexsh1A 3 Replies Last reply
    • M manutremo
      zboblamontZ
      zboblamontZ
      zboblamont
      @manutremo Disable I2C before sleep?
      50 uA is miniscule anyway but...
      • M manutremo
        Nca78N
        Nca78N
        @manutremo said in VEML6075 high sleep consumption:
        Datasheet says it's at 1.8V, and "Light condition = dark;". Have you tried to cover the sensor with opaque tape to check the sleep current ?
        Is the forced mode activated ?
          manutremo
          That's a good point, I missed that detail in the ds. The sensor is now in service, I'll measure it again when i have a chance. Thanks.
          • M manutremo
            alexsh1A
            alexsh1A
            alexsh1
            @manutremo
            Activate a forced mode. I bet your sensor is in standby mode right now
