  3. Handling NACKs in the gateway
gateway
9 Posts 3 Posters 1.2k Views 3 Watching
  • 4
    4994james
    I have set up a 2 way channel from an MQTT gateway (into openhab as controller as it happens but not really relevant) and a wireless sensor / actuator. The sensor detects humidity and sends to the gateway, openhab logic picks up the MQTT message and applies some calculations and sends back a fan speed. Most of the time this works fine however I have noticed that sometimes there are NACKs. In particular there are NACKs on the controller to node direction so that the node doesn't get the new fan speed. My question is: how can I handle these NACKs in the gateway? I haven't actually written any code as it all just done for me in the libraries. Here is the gateway code:
    #define MY_RADIO_RF24
    //#define MY_RADIO_RFM95
    // Set MQTT client id
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable these if your MQTT broker requires username/password
    #define MY_MQTT_USER "openhabian"
    #define MY_MQTT_PASSWORD "X17572gM"
    #define MY_IP_ADDRESS 192,168,1,20
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 13
    #define MY_PORT 1883
    #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xE1
    #include <Ethernet.h>
    and here is the node:
    //#define MY_RS485
    #define CHILD_ID_HUM  0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_FAN_SPEED 2
    // Define pwm pin
    int PWMpin = 6;
    //for RS485 connection or if using MQTT gateway  then you must manually define the node id before including mysensors.h
    #define MY_NODE_ID 100
    static bool metric = true;
    // test every 10s
    static const uint64_t UPDATE_INTERVAL = 10000;
    //temp humidity module library
    #include <SI7021.h>
    static SI7021 sensor;
    int fan_speed = 0, humidity = 0, humidity_last = 0;
    float temperature = 0, temperature_last = 0;
    Serial.println(F("presentation!"));
      // Send the sketch info to the gateway
      sendSketchInfo("PWM humidity controlled fan", "1.0");
      // Present sensors as children to gateway
      present(CHILD_ID_HUM, S_HUM,   "Humidity");
      present(CHILD_ID_TEMP, S_TEMP, "Temperature");
      present(CHILD_ID_FAN_SPEED, S_COVER, "Fan speed");
      Serial.println(F("setup!"));
      pinMode(PWMpin, OUTPUT);
      //TCCR2B = TCCR2B & B11111000 | B00000001; // for PWM frequency of 31372.55 Hz
      //TCCR2B = TCCR2B & B11111000 | B00000010; // for PWM frequency of 3921.16 Hz
      //TCCR2B = TCCR2B & B11111000 | B00000111; // for PWM frequency of 30.64 Hz
      TCCR0B = TCCR0B & B11111000 | B00000010; // for PWM frequency of 7812.50 Hz
      analogWrite(PWMpin, fan_speed);
      while (not sensor.begin())
        Serial.println(F("Sensor not detected!"));
        delay(1000);
      delay(1000);
      // Read temperature & humidity from sensor.
      temperature = float( sensor.getCelsiusHundredths() ) / 100.0;
      humidity    = float( sensor.getHumidityBasisPoints() ) / 100.0;
      #ifdef MY_DEBUG
        Serial.print(F("Temp "));
        Serial.print(temperature);
        Serial.print('C');
        Serial.print(F("\tHum "));
        Serial.print(humidity);
        Serial.print(F("\tSpeed "));
        Serial.println(fan_speed);
      //if humidity has changed significantly since last report then send to controller
      if ((abs(humidity - humidity_last) > 5 ) or (abs(temperature - temperature_last) > 0.5))
        static MyMessage msgHum(CHILD_ID_HUM,  V_HUM );
        send(msgHum.set(humidity, 2));
        static MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);
        send(msgTemp.set(temperature, 2));
        static MyMessage msgSpeed(CHILD_ID_FAN_SPEED, V_PERCENTAGE);
        send(msgSpeed.set(fan_speed, 2));
        humidity_last = humidity;
        temperature_last = temperature;
      // wait until next update
      wait(UPDATE_INTERVAL);
    // handle inbound new fan speed message from controller
      String PayLoad = message.getString();
      #ifdef MY_DEBUG
        Serial.print("Value received: ");
        Serial.println(PayLoad);
      fan_speed = PayLoad.toInt();
      #ifdef MY_DEBUG
      //report back fan speed when changed
    So my thinking is that the node has periods where it is doing something else like reading the sensor and when it is executing that code it will be deaf to inbound traffic and hence the NACKs.
    Any help on how to program the logic IN THE GATEWAY to handle this would be gratefully received. I could, of course handle this in openhab but this seems should be something that is handled at the transport layer I think.
    Thank you
    • 4 4994james
      #define MY_SOFTSPI
      //#define MY_RS485
      // Define pwm pin
      int PWMpin = 6;
      // test every 10s
      #include <SI7021.h>
          delay(1000);
        delay(1000);
        #ifdef MY_DEBUG
          Serial.print('C');
        #ifdef MY_DEBUG
        #ifdef MY_DEBUG
      Thank you
      @4994james the nrf24 radio is able to buffer up to 3 messages, and your node doesn't do anything that takes a lot of time so I don't think the problem is that the node is busy doing something else.
      The gateway tries sending up to 15 times by default. If there are 15 failed attempts in a row, I don't think trying even more time will help much.
      Do you have capacitors on gateway and node? How are they powered? Stabilizing power helps in more than 99% of the cases I've seen.
      If stabilizing power doesn't help, the easiest way would probably be to let the node request the fan speed at regular intervals (maybe every 5th time the loop executes, depending on how often the speed is changed).
      Sorry for not giving you a solution to "program the logic IN THE GATEWAY" but I don't think that would be easy, nor effective.
      4 1 Reply Last reply
        4994james
        @mfalkvidd thank you for this helpful response. I will respond once I get a chance to have a look at this properly again.
        • 4
          4994james
          Hi
          I have read around this a little bit and also investigated my hardware.
          1. I did find an issue in the node (receiving) hardware that was causing the NACKs at the gateway. This is now fixed and consequently I now have far less occurrences which is good but...
          2. I still do occasionally get NACKs. Here is an example of the debug output from the gateway of an apparently successful message:
          TSF:MSG:SEND,0-0-100-100,s=2,c=1,t=3,pt=0,l=3,sg=0,ft=0,st=OK:220
          and one where there has been a NACK:
          !TSF:MSG:SEND,0-0-100-100,s=2,c=1,t=3,pt=0,l=3,sg=0,ft=0,st=NACK:220
          So I am assuming that the NACK at the end of this debug message is telling me that this is a software handled NACK. I am assuming (and the problem is I haven't easily found a documented explanation for this) that what has happened is that the radio hardware ACK has failed for all of its 15 attempts and the gateway did not receive a requested ACK message.
          What appears to be not possible is to handle that lack of an ACK in the code in the gateway sketch.
          Regardless of the fact I have made the problem less of an issue by fixing my hardware problem it seems to me that the ability to handle this is a must if I want to use the platform to reliably control actuators. The most logical thing would be to amend the code so that the occurrence of a NACK is reported to the controller. I think that would have to be done by either:
          1. amending the library code: I could have a go at doing that but will take some getting my head round the cpp code and i am sure i would end up doing this in a non-re-usable way (I am using the mqtt version of the gateway transport).
          2. somehow detecting the debug message in the sketch.
          Am I on the right track?
          • electrikE
            electrikE
            electrik
            If this is desired, the most transparent way would be to implement this function in the controller. You can request a software echo, and if you don't get that, you can send the message again
            • electrikE electrik
              4994james
              @electrik thanks. Good thought. Will report back once I have looked at this.
              • electrikE
                electrikE
                electrik
                Okay. Note there is a difference to the ack in the other topic and the echo. The echo status can be requested by the gateway, also if it is on mqtt.
                • 4
                  4994james
                  I have now "seen the light" about how this has been designed, amended the outbound mqtt message from the controller to request ACK:
                  and this is working and sending back an echo message:
                  mygateway1-in/100/2/1/1/3 100
                  mygateway1-out/100/2/1/1/3 100
                  So I can now build a rule round this in openhab to handle errors. I suppose I should have thought this through before pestering the forum but then again that is what it's for! Thanks again.
                  • electrikE
                    electrikE
                    electrik
                    Exactly. Better to ask then waste many hours 😏
