  3. Arduino UNO + serial gateway
12 Posts 3 Posters 6.3k Views 4 Watching
  • E
    E
    erangel
    Hi, it is my first post in forum.
    I have a raspberryPi 2 and an arduino UNO with a relay module. I am a newbie with arudino, but I am a developer with more 10 years experience.
    I want to connect raspberryPi to arduino using just a USB serial cable. My intention is automate house like turn on/off lights, to open gates and in the future, measure consumption of water and energy.
    I downloaded the libraries from MySensors, and I am using serial gateway. I compiled and did upload to arduino, but when I check a serial monitor, the output is:
    0;0;3;0;9;check wires
    I do not know what is this problem. Someone can help me ?
      It means that your radio isn't connected correctly to the Arduino.
      • E
        E
        erangel
        I don't have radio. Because this, I just want to use serial usb.
          Then you must use the development branch.
          • E
            E
            erangel
            Thanks for information. I downloaded the development branch, but the SerialGateway is "empty". Is it correct ? The version 1.5 is compatible ?
            • G
              G
              georgep56
              If you mean that there is no code in setup{} or loop{} then yes, that is correct.
              The new development branch code works differently.
              • E
                E
                erangel
                How can I take some sample to create a relay actuator using the development version ? Do you have some documentation of this version ?
                  All the examples has been converted. Among them is the RelayActuator. But instead of defining MY_RADIO_NRF24 you must enable the serial gateway by defining MY_GATEWAY_SERIAL
                  So basically only one little change.
                  • E
                    E
                    erangel
                    Tks Hek!
                    I changed the source, but now I do not compile the code.
                    Do you know what is that ?
                    MyGatewayTransport.cpp:In function 'void gatewayTransportProcess()
                    MyGatewayTransport.cpp:54:16: error: cannot resolve overloaded function 'receive' based on conversion to type 'bool
                    :if (receive) {
                    Error compiling project sources
                    I am using RelayActuator.
                      Just tried it here and I'm not getting any errors here when compiling.. You must be doing something wrong.
                      • E
                        E
                        erangel
                        @hek said:
                        MY_GATEWAY_SERIAL
                        Hi @hek!
                        Do you know if the feature - MY_GATEWAY_SERIAL - it is in 1.5 version ? Or jut in development ?
                          It is a development branch define.
