  3. Hardware debounce?
Hardware debounce?
5 Posts 4 Posters 2.6k Views 3 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    I want to use debounce in a sketch that also uses sleep until interrupt witch won´t work with software debounce as I understand.
    Is there some way to still be able to this by software or do I have to do it by hardware? I have found some examples where they use capacitators, but how do I know witch size capacitaor I need for a 1000ms debounce for example?
    I have a optocoupler connected to Pin3-GND, but I always get two triggers from the optocoupler.
      Debouncing can be done in software. A simple solution is to turn off interrups inside the interrupt handler and do delay 1000ms in the main loop before you go to sleep again. That ensures a maximum of 1 interrupt per second.
      TheoLT 1 Reply Last reply
        TheoLT
        TheoLT
        TheoL
        @mfalkvidd If you happen to have a code example, I'd be much interested.
          Attachinterrupt(...)
          Gw.sleep(SLEEPTIME)
          Delay(1000)
          • L
            L
            lafleur
            For something that slow, try a MAX6816... cheap, sot-4 case
