  3. Wifi gateway is it working?
6 Posts 4 Posters 2.4k Views 1 Watching
    moskovskiy82
    Well have finally made my first sensor (humidity sensor with DHT22)
    With the sensor i see the following on the serial console
    find parent
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    T: 23.50
    find parent
    H: 28.00
    find parent
    H: 28.10
    find parent
    So it seems the sensor is working (although the humidity is offset)
    But on my wifi gateway i see none. I haven't connected them to any controller yet
    goes like
    ESP8266 MySensors Gateway
    Connecting to xxx
    .....Connected!
    IP: 172.16.1.93
    Am i supposed to see some data received from the sensor in the telnet session to gateway?
    • scalzS
      scalzS
      wrote on last edited by scalz
      Hi.
      I think it is because you have no controller yet. When gw.begin is in dynamic mode, it is the controller which give an id to your node. The GW does not give any id.
      So if you have no controller yet, you can play with mysensors by giving a static id to your sensor node.
      Here you have an example:
      http://forum.mysensors.org/topic/2676/mysensors-network-static-or-dinamic/2
      and here explanation for parameters ("Starting Up the Library Section"):
      http://www.mysensors.org/download/sensor_api_15
      If you don't need to receive any msg, you can use "null" instead of "incomingMessage"
      • E
        E
        ericvdb
        Change
        gw.begin();
        to
        gw.begin(null, 10, false);
        where 10 is the Node ID in this example.
          moskovskiy82
          Well still out of luck.
          Installed mysensors.org controller just for a quick check
          Chose mcc.ethernet.gateway.type=ethernet
          And that's about all the config
          In status gateway i see
          "Connection Status Reconnected Successfully"
          So it seems the gateway is working. This is what i see in logs
          Dec 31, 2015 6:54:13 PM	Sensor Internal	Received	[I_GATEWAY_READY], [NodeId:0, SensorId:0, PayLoad: Gateway startup complete.]
          Dec 31, 2015 6:52:08 PM	Sensor Internal	Received	[I_GATEWAY_READY], [NodeId:0, SensorId:0, PayLoad: Gateway startup complete.]
          Dec 31, 2015 6:50:19 PM	Sensor Internal	Received	[I_GATEWAY_READY], [NodeId:0, SensorId:0, PayLoad: Gateway startup complete.]
          Dec 31, 2015 6:50:03 PM	Sensor Internal	Received	[I_GATEWAY_READY], [NodeId:0, SensorId:0, PayLoad: Gateway startup complete.]
          But that's about it... (
            moskovskiy82
            This is what i get on gateway by sending a REQ from MYSController
            Client 0 connected
            Client 0: 0;0;2;1;1;
            Exception (28):
            epc1=0x4000bf80 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
            ctx: cont
            sp: 3ffefe40 end: 3fff00e0 offset: 01a0
            >>>stack>>>
            3ffeffe0:  3ffeebf1 3fffc6fc 00000001 3ffeee84
            3ffefff0:  00000000 00000000 3fff001e 4020102c
            3fff0000:  40217d96 3fffc6fc 3ffeee8b 40203cd8
            3fff0010:  3fff0130 00000001 3ffe88d5 40206168
            3fff0020:  3fff0130 00000009 3ffeebf1 00000000
            3fff0030:  00000002 00000000 3ffeef6c 40205d85
            3fff0040:  00000001 3ffeebe8 3fff0130 40205d85
            3fff0050:  3ffeebe8 3ffeebe8 3fff0130 3fff0130
            3fff0060:  3ffeebe8 3ffeee84 3ffeee8b 402023ec
            3fff0070:  3ffeedec 3ffeebe8 00000000 402026b4
            3fff0080:  3ffe8628 00000000 000003e8 402051e6
            3fff0090:  00000000 3fff1818 040510ac 3ffef0ac
            3fff00a0:  00000000 0000000a 00000000 00000000
            3fff00b0:  40205499 5d0510ac 00000000 3ffef0ac
            3fff00c0:  3fffdc20 00000000 3ffef0a4 402054c1
            3fff00d0:  00000000 00000000 3ffef0c0 40100114
            <<<stack<<<
             ets Jan  8 2013,rst cause:2, boot mode:(3,6)
            load 0x4010f000, len 1264, room 16
            tail 0
            chksum 0x42
            csum 0x42
            ~ld
              Try adding a cap on between GND/VCC to stabilise the power supply.
